C63/C63S AMG
19x11 on a sedan with 305/30/19 tires
Old 02-27-2022, 05:51 AM
  #51
anwar_hamoude's Avatar
2016 C63 AMG
Originally Posted by RDO247
I’ve been daily ing my AR-1’s on my sedan for the last 2 years and now daily them on my coupe.
The below are fronts off my sedan after 2 years.
AR-1's look to have held up well. Are they finicky with temperature and tire pressure?
I am wondering about cooldown; heat up and cooldown. Or its all hype?
Old 05-18-2022, 08:58 AM
  #52
2016 C63 AMG
20x11 +55ET looked perfect but the fuel inlet is in the way on the right side. I added 12mm spacers, maybe could get away with 10mm spacers. +55ET clears the shocks but touches the fuel inlet.
I’m wondering how you got it to work?
I rolled and pulled the rear fenders.
1slick_c63amg (05-18-2022)
Old 05-18-2022, 09:14 AM
  #53
1slick_c63amg's Avatar
C63 AMG
Looks awesome, nice setup! Remember, he is running 19s, not 20s. You're probably at the limit with your setup, hard to tell if you are on stock height... but if you plan to lower you would probably need to run a bigger spacer.
I'm running 20x10.5" et57 with 295/30 rears. Fits perfectly, no rubbing. I'd love to drop the car a touch all around and have 5mm spacers to help with clearance by the shocks/inside fender if need be.
Old 05-18-2022, 05:46 PM
  #54
2016 C63 AMG
I am at stock height & use Sport+ suspension setting to limit bounce. I stretched the fender, its stretched near the bumper cover connection to allow the bumper cover to be pulled outward so the tires don’t rub. I am considering cutting and welding- a small slit and filling in the gap, in a way the bumper cover will fit without modifying it- If I go to 325/25 on 12”.
Tread width on Continental SportContact 295/30ZR20 is 11.1”, which is correct width for 11” wide rim. I am looking at having custom spring made, slightly heavier and a few millimeters longer. That is so I don’t have to select Sport+ suspension every time I drive the car and/or worry about the tires bottoming out if someone (mechanic or valet) drives the car without putting it in Sport+.
Old 07-12-2022, 04:18 PM
  #55
SolidC63S's Avatar
2019 C63S Cabriolet
Damm So I got a 275 35 19 and Rears 305 30 19- Would this fit in a 19x10 +25 and an 19x11 +47 Wheel set up ? I'm lowered 1.4 around there.
Old 07-12-2022, 05:45 PM
  #56
2016 C63 AMG
You’re going to have some wheel poke both front and back. There’s an undesirable amount of difference in wheel diameter for that setup. 275/30R19 might be considerably better, and match the rear wheel better. 35 ratio makes the front wheel larger diameter than the rear. Clearance with the lowering might be less of an issue running the smaller diameter. I am almost sure +47ET would rub on the inside with the tires I have. Keep in mind the rear fenders are going to need to be pulled. Tires would otherwise shred on the fenders. Having an experienced bodyshop do proper body modification to fit those 19x11’s would likely cost $15K. Regarding rear offset, take a very close look at the fuel tank inlet and the fuel system apparatus inside the wheel well on the right side. Higher offset is definitely possible with some modification to the fuel inlet. In that case, I think 11 inch wide with 295 would definitely fit without pulling the fenders.
SolidC63S (07-13-2022)
Old 07-19-2022, 05:12 PM
  #57
SolidC63S's Avatar
2019 C63S Cabriolet
what are your front tires spec, man I have this Same setup with 15mm Spacers on the STOCK 2019 Wheels NONforge? I was looking to get this done also but I have the following tires Front 275 35 19- and 305-30-19 with 15mm Spacers all around. looks amazing, but I wanted that look with aftermarket wheels. on an 11 rear and 10 front.
Old 07-21-2022, 03:51 PM
  #58
SolidC63S's Avatar
2019 C63S Cabriolet
Originally Posted by Mr. Pink
What suspension?
I'm on kw v3 and I'm all the way maxed up rocking 295/30s on my stocks til I build my bbs'
Definitely wanting to go a bit lower to get the stance right on it but I'm worried about that when I get my wheels and tires.
Hey dude, how are you liking the KV3 Coils? compare to KWHas on OEM springs and what do you think about durability on both, comparing it, etc.
Quick Reply: 19x11 on a sedan with 305/30/19 tires
