C63/C63S AMG
AMG Exhaust always on? Possible?
Old Apr 18, 2018 | 12:36 AM
amalgam's Avatar
W213 E63
Is there any way to keep the exhaust on instead of having to press the button everytime? Thanks
Old Apr 18, 2018 | 02:47 AM
guhvies's Avatar
2017 C43 AMG Saloon
Yes, search for the Ukrainian and mid-city engineering.
Old Apr 18, 2018 | 10:39 AM
FirstMBAMG's Avatar
C43 AMG Coupe
No, is the correct answer, without aftermarket modification. feel free to dig through the forums and see other people’s experiences, but I think that answer should suffice.
Old Apr 18, 2018 | 01:42 PM
RDOCA's Avatar
2016 C63S Sedan
Sure --Just program it in the dynamic switch and when you go to I mode it is open which you do every time you start the car --correct
Old Apr 18, 2018 | 04:22 PM
Chigs's Avatar
2018 C63S Sedan
Is it really that hard to push a button?
Old Apr 19, 2018 | 06:04 AM
FDNewbie's Avatar
'17 AMG S63 Convertible, '17 AMG C63S Edition 1 Coupe
Yes. All outlined in this thread: https://mbworld.org/forums/c63-c63s-...nd-module.html
To summarize:
- When you push the exhaust button, the valves are not completely open; they're only 50% –70% open
- Valves only open 100% in Sport+ mode under heavy throttle at high rpm
- ASR makes a plug 'n play module that will open the exhaust valves 100%, regardless of speed/throttle input/driving mode
- The module literally connects to the OEM connector in the trunk. 5 minutes to remove the floor tray in the trunk, and about 5 seconds to disconnect the OEM connectors from one another and snap into their adapter.
- The module includes a "Sports" mode (exhaust valves 100% open all the time), "Comfort" mode (flaps are closed all the time), and "Original" mode (module is inactive, so you can resume OEM valve control using the OEM exhaust valve button).
- The ASR module automatically remembers the last exhaust mode the car was in on shut off, and restarts it in the same mode.
- You can select any one of those mods as the default start mode, and it can be changed at any time (via a remote included with the kit).
Direct link to the kit: http://asr-component.de/home/51-klap...erung-rx1.html
We're trying to get a GB going on the kit, so check out and subscribe to the thread I mentioned at the beginning of my post for updates!
Old Apr 19, 2018 | 01:00 PM
amalgam's Avatar
W213 E63
No it's not hard, but considering the car is pretty advanced and can remember seat, mirror, radio, drive settings, etc, one would think something as easy as leaving the exhaust on as default would be easy. Car is only 3 days new so I'm still learning.
Thanks RDOCA, the Individual setting actually does the trick, now if we can set I setting to default that would be perfect haha :p
Old Apr 19, 2018 | 01:25 PM
longbow0404's Avatar
2019 E63s
Yes there is a way!!! I have it with not issues. DM if you wanna know how
