C63/C63S AMG
Check Engine Light at 7000 miles
Old Aug 28, 2018 | 04:09 PM
Jinggyjin's Avatar
C63S
Got a 2016 c63s sedan, no tune, no performance mods, currently has about 7000 miles on the clock.
Car is due for schedule B service for a few days, and yesterday I got a check engine light. Not sure what could be the reason, the only non-exterior mod is a hard-wired BlackVue dashcam. Scheduled the dealer visit next week, but would really appreciate if anyone who experienced it can share your insights. Will overdue service cause the check engine light, even though it is barely driven after the service was due? Could the dashcam cause any issue here?
Many thanks!
Old Aug 28, 2018 | 06:24 PM
KJ's Avatar
KJ
2020 GLE 53 AMG
The check engine light is on due to Engine Atrophy.
Old Aug 28, 2018 | 07:19 PM
tekfoc's Avatar
Veteran: Army
18 E63S
Probably a bad ignition coil
There's a possible TSB on some early builds
Old Aug 28, 2018 | 09:27 PM
Jinggyjin's Avatar
C63S
Sounds scary
Old Aug 28, 2018 | 09:29 PM
Jinggyjin's Avatar
C63S
Yeah, my car was built around Oct 15, so it seems to be in the recall range although I haven't really received any notifications. Did your 2016 c63s also experience the same thing?
Old Aug 28, 2018 | 10:08 PM
tekfoc's Avatar
Veteran: Army
18 E63S
Very early in purchase
one cold morning start the the check engine light came on and was running rough.
i shut it down restarted it and check engine light remained off.
engine was running normal.
took the car in for service A but came back with a clean bill of health.
but things could change when I take it back for service B.
maybe it might show up in there system for faulty coil.
The car has been running great so will see when I take it in.
my build date is August 2015
Old Aug 29, 2018 | 11:24 AM
msd3075's Avatar
'15 C63S
A check engine light (normally just called an MIL, or Multifunction Indicator Light) could be caused but hundreds of things within your vehicle, and the entire point of having the system is to report a specific code as to what it's seeing as a problem. Go to your local AutoZone (or equivalent store) and get them to pull the code for you. They'll plug an OBD scanner into a plug in the driver's foot well directly next to the hood release, and the entire scan will take under a minute if even that long. Once you have the code, you can look it up and see what it's saying is the issue. AutoZone will usually give you a generic-ish description of the code, but it's at least a good starting point to diagnosing what's wrong.
Old Aug 29, 2018 | 01:09 PM
tekfoc's Avatar
Veteran: Army
18 E63S
I have 3 different scanners nothing came up. hence the same from dealership.
I'M also extremely auto tech savvy that's why I suspected the coil .
it's been my hobby since a teenager.
Old Aug 29, 2018 | 02:22 PM
msd3075's Avatar
'15 C63S
My post was meant for the original question here, not your post. I
If the MIL turns itself off (as you described), it means there is no l ok nger a code for the scanner to pick up. It'll still more than likely be logged in the main ECU where the dealer can look for it, but the OBD scanner from the auto parts store will no longer get be able to pick it up. My dealer was able to see a misfire code on my car from several months earlier even though the MIL went away after a few restarts the day of the misfire.
Old Aug 30, 2018 | 08:51 AM
susman@eurogermantown.com's Avatar
Former Vendor of MBWorld
just out of curiosity...did you just fill up the tank before the CEL?
Old Aug 30, 2018 | 11:13 AM
Jinggyjin's Avatar
C63S
No, the tank is not even half full lol. Will that also cause the car to throw a code at you?
Old Aug 30, 2018 | 11:59 AM
chrisridebike8's Avatar
'10 C63
sometimes if the gas cap isn't tight it will throw a CEL
Old Aug 31, 2018 | 02:47 AM
Alexpark911's Avatar
2015 C63 S EDITION 1/ 2015 BMW X5M
I was going to say the samething. Gas cap can cause that!! If not, it could be from putting wrong octane gas
