C63/C63S AMG
Burger Motorsports 2018 C63 Dyno Testing
Old Apr 5, 2019 | 10:08 PM
  #376
scrufy's Avatar
2019 C63 s
Originally Posted by crazy1eye
From what I’ve read & what I’ve managed with my C63S that has drop in low profile air filters & secondary cat delete, you can check my posts in the 1/4 mile thread, there’s definitely a gain in the 1/2 mile of at least 5 mph compared to my 144-145 mph runs.
Good to see improvements crazy, but I'd really like to see some dyno numbers.
Terry:
I have a '19 C63S and am only in Pasadena so very close if you want to try some (very) safe pulls.
Old Apr 6, 2019 | 05:45 AM
  #377
crazy1eye's Avatar
2016 C63S, 2012 ML350
Terry:
Sorry, as I added above, I do not have a jb4 yet, I know people are wanting to see dyno numbers & I was just adding my 2 cents regarding track numbers.
Old Apr 6, 2019 | 07:04 PM
  #378
mbfan219's Avatar
W205 C63s
Just finished installing the JB4 in my C63s. Ran it on map 2 for an hour or so with no issues. Definite improvement! Will try to get a dyno in the next few weeks. Had a small issue with forgetting to reconnect a wire that was removed for slack during installation but all fixed and Jon at Burger Motorsports was a huge help. I'm very pleased.
Old Apr 6, 2019 | 11:25 PM
  #379
scrufy's Avatar
2019 C63 s
On the mobile app.. Why not just make it car play and android auto compatible.
That way there wouldn't be any need for that funky suction magnet mount.
i know probably way too many hoops to jump through with Apple and Google but it would be nice.
Old Apr 7, 2019 | 06:59 AM
  #380
ezatnova's Avatar
2016 C63S
Is your car stock? Seems like map 2 was being mentioned as best used with other mods and also requires messing with plug gaps.
Hoping for an update from BMS soon with stock S figures, map recommendation on 93, and install video.
One other thing that I don’t get is why the boost reduction by gear is called some whacky parameter name...would really simplify and clarify if it were renamed “boost reduction” and had an input for each gear, and also the values should be entered as negative...confusing that they are positive when they have the opposite effect. Also, would be nice to come pre-set to the ideal boost reduction settings for a stock vehicle. Worst case, make it like “Map 1 BR”, “Map 2 BR” etc. One less thing to have to mess with.
Old Apr 7, 2019 | 07:32 AM
  #381
mbfan219's Avatar
W205 C63s
Stock C63s. 93 octane fuel. Didn’t mess with any settings (boost reduction by gear etc, or plug gaps).
Install wasn’t too difficult - definitely doable if you follow the instructions by any home mechanic. I used the guide on their website which worked great. Getting the map 1 and map 3 sensor connectors off was a pain since Mercedes buried them in the front under a plastic guard that you have to loosen a lot of stuff to get to it. Took me about 5 hours all in because this was the first time I had removed the air boxes, etc, so it took a little while to be familiar with everything. If I did the install again I could do it in about three hours.
Old Apr 8, 2019 | 01:45 PM
  #382
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
+1 in for Intake release date.
Old Apr 10, 2019 | 03:39 PM
  #383
DonC63's Avatar
C63
You guys all Suck
I just ordered me a JB4
Old Apr 10, 2019 | 05:00 PM
  #384
Vader-C63sE1's Avatar
2017 C63s Edition 1 JB4
+1 here too for Intake
Old Apr 17, 2019 | 02:20 PM
  #385
Just ordered the JB4 and the BT Wireless Connector, should be fun!
Old May 16, 2019 | 02:10 PM
  #386
V8rumble's Avatar
C63
Any updates on the intakes?
Old May 16, 2019 | 03:54 PM
  #387
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
They're at powder coating right now. Maybe another week or two at most!
Old May 16, 2019 | 04:53 PM
  #388
ezatnova's Avatar
2016 C63S
Trying to piece this together since there is no C63S dyno available... If the non-S car made 465 whp stock (rated at 469 crank), and then made 537 whp with the JB4, we see a 72 hp gain. The S is rated at 503 crank, and following similar logic, it should be about 500 whp stock. I believe we have been told that the peak power will be the same on JB4 between S and Non S cars, so it would end up with the same 537 whp. So, really all we are going to gain is ~37 whp on an S model?
Would be nice to have a stock S dyno as a baseline, then add just your JB4 on pump gas (not mixing in any E85 that 99% of us won't ever mess with) and then a third with JB4 on pump gas plus your intake.
Old May 16, 2019 | 07:06 PM
  #389
Gbango's Avatar
16' C63s
No idea on actual numbers for my S, but it definitely felt to be somewhere in between 540-580whp. Ended up trading in the car, so I have my 1 month old JB4 with Bluetooth for sale.
Old May 18, 2019 | 03:43 PM
  #390
scrufy's Avatar
2019 C63 s
Your math doesn't add up there. If a non S made 469 crank then there is no way it's making 465 whp. There is roughly 10-15 percent loss in the drivetrain.
I think the HP numbers from Merc would be usable - say 12% for an avg whp but the problem is I've read a few Dyno numbers that suggest AMG under rated the m177 by quite a bit so unless we use a before and after on the same Dyno and same day there really is no data. Just random shot in the dark. I think BMS posted one early on but this thread has evolved so much I don't think any of that info is valid anymore.
Might be time to get some updated numbers?
I probably won't be getting one for my S just because there are some differences between S and non S and the tuner has never even tested in house on an S.
Don't get me wrong, I used the JB3 then JB4 on my 335i for years back around 2009 to 2014 then a JB4 on my M3 . I just think there isn't enough going into my current car for a complete understanding.
Old May 18, 2019 | 05:33 PM
  #391
ezatnova's Avatar
2016 C63S
All I’m doing is using BMS’s own graphs. It shows whp is 5 shy of claimed crank. All I did was use the same logic for the S.
That aside, I agree, somewhat disappointing that there isn’t testing being published with an S at this stage of the game.
I too used the JB3 on my 2007 335i and was very happy with it.
Old May 18, 2019 | 08:32 PM
  #392
RDOCA's Avatar
2016 C63S Sedan
A stock C63S will have approx 470 WHP and and it is under rated by about 30 HP per Dinan. They say 533 HP stock and that would look correct using 470 WHP and a drive line loss of 12 % would give 534 HP.
Most stage 1 tunes will give some where around 70 HP increase. After watching these threads over the last 4 years I think this is quite close.
Old May 19, 2019 | 05:46 PM
  #393
scrufy's Avatar
2019 C63 s
Originally Posted by RDOCA
A stock C63S will have approx 470 WHP and and it is under rated by about 30 HP per Dinan. They say 533 HP stock and that would look correct using 470 HP at the crank and a drive line loss of 12 % would give 534 HP.
Yeah I think he missed the point I was making. AMG under rated the HP so BMS stock pull whp just shows that.
Old Jun 12, 2019 | 07:56 AM
  #394
ezatnova's Avatar
2016 C63S
Any new issues or updates? Been a long week!
Old Jun 12, 2019 | 01:09 PM
  #395
BMS's Avatar
BMS
2018 C63 Sedan
Everything has been delayed longer than expected as always
Once I get a firm answer, I'll update again.
-Payam
Old Jun 12, 2019 | 01:36 PM
  #396
ezatnova's Avatar
2016 C63S
-Payam
Sounds good. Looking forward to it!
Any action as far as an install video being wrapped up for the JB4? I believe there was talk about this a few months back?
Old Aug 7, 2019 | 07:10 AM
  #397
ezatnova's Avatar
2016 C63S
Installed my JB4 last weekend. As others have said, it’s not super easy the first time, but also not terrible. Sensor 1 and 3 took a while and four hands is definitely a help. Took about 3 hours. I also took extra time to RTV around the existing gasket of the JB4 enclosure, as well as in the wire sections entering the top and bottom of the enclosure to help ensure it is water tight.
Anyway, initial impression is overall positive. Personally I notice more of an improvement from stock to map 1 than map 1 to map 2, which makes sense given the delta is ~+3 psi on map 1 and ~+4 on map 2.
Have sent some logs to BMS and Terry seems fine with both maps’ results. I am otherwise stock, on 93 octane.
I need to explore boost by gear. But haven’t had time yet.
Also particularly on map 2, I’ve noticed some part throttle (20-50%) non-linear rpm increase (i.e. surge/lag). I need to explore more and compare back to back with map 1 and map 0.
In the meantime, can anyone give me a general sense of healthy results for some of the parameters in the logs? i.e. AFR, Trim, IGN, load, etc. I’m just not sure what to really watch for in the logs.
Map 2 log below:
Old Aug 7, 2019 | 08:47 AM
  #398
raudiace4's Avatar
Perhaps some of you JB4 guys can get some 1/4 track times to compare vs the ECU tune people. Stock vs JB4 vs Ecu Tune would be nice to see for people on the fence about their options.
Old Aug 7, 2019 | 09:22 AM
  #399
AlexZTuned's Avatar
2017 Porsche 911 C4
That’s what I’d like to see as well.
I ran 11.5 @ 127 mph in Texas heat with just a Dinan piggyback and 305 PS4S’s in the rear. Tank of straight
93 octane with no booster/ethanol. I haven’t seen JB4 best that time or mph even with their full intake and E30 blend.
I wish more people were active so we could get more JB4 results...
Old Aug 7, 2019 | 11:28 AM
  #400
GuardianVA's Avatar
'19 C43
Map 2 log below:
AFR looks a little rich (upper 10s low 11s) getting toward redline, but hard to know exactly what the numbers are just looking at the graph. Can you post the .csv file? Otherwise, looks fine. Even if it is running rich, it won't hurt performance appreciably, but is kinda wasting fuel.
