Burger Motorsports 2018 C63 Dyno Testing
Attaching The .CSV here.
and old video with hesitation
https://vimeo.com/348879382
https://vimeo.com/347098631
Thanks. Yeah I think my next steps are going to be trying to get some part throttle logs and see if we can dig into why things don't run as smooth as stock (and ensure that things are equally as smooth as stock on map 0, which they certainly should be since my understanding is that map 0 is a bypass). It's nothing violent by any means, but symptoms range from a random little hiccup at idle to a bit of hesitation/buck at lighter throttle in 1st, to revs hesitating somewhat and just not being smooth-as-stock in 3rd and 4th gear mid-throttle levels. Not sure if stuff like that is just the nature of the piggyback beast, or if it's something they need to study and improve as it moves out of beta status. What I have not noticed is any of that hesitation happening at WOT, like in notabenex's video.
How many people are sending their logs to BMS for fine tuning vs. just running the maps 'off the shelf'?
I seem to recall reading somewhere that you can't drop the boost below what is set in the ecu? So if this is the case, maybe having a custom tune with gears 1 and 2 set at a lower boost level, for example 6psi, and then using the JB4 to control it from there would be optimal for fine tuning the boost for the best hookup?
Initial quick review:
Map 1 - not bad but looking for more ...
Map 2 - found it!
- Map 0 felt like stock of course.
- Map 1 was noticeably faster, more power, tires spin more easily and throttle is responsive. But I definitely did not buy this thing for map one.
- Map 2 was the same but even more power. Feels close to my old 548whp N54 535i, but power delivery is more midrange which is nice.
I plan to try out map 3 this weekend! - after I swing by an E85 station, probably do a 20% mix to start and see how it logs. Expecting good results
I didn't notice any hesitation or odd behavior at idle, part throttle, or full throttle on any map. It did do a very slight stumble when I switched from map 0 to map 1 on JB4 app with engine running the first time but was not concerning. I switched maps after that with engine idling and did not notice it again.
Over all I'm very pleased so far! More to come ...
After running well on map 2 for a few days, I started exploring higher maps with an ethanol mix of E25.
Map 3 and 4 had no problems, and power was noticeably increased over map 2.
Running E25 and map 5 now, logs look good just had to raise FOL a bit more to 55.
Tracton at 50 mph WOT hit is a challenge!
Log attached for anyone interested.
- looks like you short shifted (manual mode maybe)? Car seemed to shift up at only 5800 rpm
- seems like really not more boost than I logged on Map 2. Aside from your quick spike in the 18’s, which I believe was a shift-spike, it was basically making mid 16’s, which is the same as I got on Map 2. (My graph is in post 397). Perhaps it’s the taper that’s different, and not peak?
- your AFR was more lean (and arguably “proper”) than mine was. Yours being in the 12-14 range while mine was in the 10-11 range. Perhaps this is where Maps over 2 make more power? Not by boost but by leaning out? Or is there even more to it behind the scenes?
- general question for BMS...since the logs show that the gear can’t be read (always shows gear: 0), I assume you’re sure that boost-by-gear reduction actually works?
OK looked at it: peak boost is similar but the way BMS maps on the JB4 work is that they add X PSI to to the ECUs requested boost. So you need to compare the delta between ECU PSI and boost. Yours is right around 5 which is correct for map 2 per BMS info. Whereas my boost is consistently 7PSI or so higher than requested ECU boost, which is correct per BMS info for map 5. So I think the tunes are operating correctly in both our cases. Question is really, why was your car requesting more boost… not sure where you live, but it has been a 100 plus degrees here lately so guessing that is driving down how much boost my ECU thinks it needs.
In your case you do probably have a little power left on the table with AFRs a little rich, but very much doubt that BMS designed their maps that way.
Hopefully Terry/BMS can chime in on why AFR is rich on your logs. Definitely more to it behind the scenes.
Map 3-5 peak should be progressively higher than Map 2, but also hold boost progressively more in high rpm as well. My logs of map 2 - 5 do show this progression clearly... Will check out your log...
I dont know how BMS designd the maps, but IMO all maps should be tuned to keep the AFRs in the same "safe" range. Too rich isnt good either.
Wondered the same thing when i started reading the C63 logs. Also would be really good to have cylinders 2 - 8 timing logged as welll.
Makes sense about JB4 adding X boost on top of the stock ECU request. And that is interesting how your car was calling for ~2 psi less than mine, making the tunes’ boost about equal between your map 5 and my map 2 (although more taper on my map 2, I think). My temps here around Philly were hot too. Was probably 85 or so then. Check out my IAT’s...even a bit warmer than yours.
If you don’t mind, maybe once you are back on pump gas, get a good map 2 run and we can compare that to my file. I run 93 octane FWIW.
Do you have an intake?
-Payam
