C63/C63S AMG
Burger Motorsports 2018 C63 Dyno Testing
Old Oct 28, 2018 | 06:15 PM
  #151
White C400's Avatar
2015 mercedes c400
Originally Posted by ezatnova
Not sure of the event details and if there is just a slow roll-on or what, but the 1/4 mile times look way slow for the mph, right? I’d think those trap speeds would equate to very low 11’s?
They are slow for the mph but look at the 60ft 2.2 to 2.3. with good traction and tires should get 1.7 maybe 1.6 which will give you 11.0 to 11.2 1/4. So on 93 octane prob run 11.2 11.3 at 124ish if I had to guess. Which in my opinion is pretty good. Any pricing on the intake yet.
Old Oct 28, 2018 | 06:25 PM
  #152
White C400's Avatar
2015 mercedes c400
Originally Posted by BMS
We got lots of good data at the Shift Sector event. We'll be integrating what we learned into some changes to the prototype mapping. Hit the speed limiter on all the JB4 runs. Map 0 which disables the JB4 ran 11.5mph less at 144.4!
All runs on a mix of about 80% race gas with the BMS intake prototype installed.
Im surprised the tune doesnt take the speed limiter out. How much more do u think it had before hitting limiter or was it hitting the limiter right on the line in the half mile.
Old Oct 28, 2018 | 07:18 PM
  #153
ezatnova's Avatar
2016 C63S
Surprised as well. That’s a shame it’s a non-S. S wouldnt cut until 180.
Old Oct 28, 2018 | 09:11 PM
  #154
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
You'd have the flash the ECU to raise the limiter on this platform. And then the car is flagged. Not sure what the S speed limiter is set to but unless you're racing at half mile races, probably most of you won't be going over 155mph very often.
The trap delta between stock and JB4 was much higher than we expected!
Old Oct 28, 2018 | 11:03 PM
  #155
rekrul's Avatar
2018 C63 AMG
What are the main advantages of this over the Dinan tuner? I currently have the dinan tuner and love it. Would there be a downside to running your intake with the dinan tuner? I would think not given how the piggybacks work. More importantly what gains are expected from the intake?
Old Oct 28, 2018 | 11:12 PM
  #156
ezatnova's Avatar
2016 C63S
Most is covered earlier in the thread, but CANBUS, map switching, logging (all via an actual phone app that works, not just promised and a year later isn’t out), boost limiting by gear to promote traction. Lots of things.
Old Oct 29, 2018 | 06:24 AM
  #157
White C400's Avatar
2015 mercedes c400
I was just wondering not to consurned I have the S anyway. But my question before is that it hitting the limiter in the half would it have gotten a higher mph if it didn't hit limiter or was it pretty much right at the end of the 1/2. Or did it have another mph or 2.
Old Oct 29, 2018 | 11:01 AM
  #158
BMS's Avatar
BMS
2018 C63 Sedan
Probably had some more trap speed in it on the more aggressive maps.
Old Oct 29, 2018 | 11:04 AM
  #159
BMS's Avatar
BMS
2018 C63 Sedan
All of that but more fundamentally, fuel control. Dinan doesn't seem to offer any fuel control based on this photo. It's just the 4 MAP sensor connections. JB4 has 4 MAP sensor connections, 2 fuel connections, 1 OBDII connection, and an optional boost_solenoid connection: http://files.dinancars.com/webresour.../D440-0054.jpg
Old Oct 29, 2018 | 11:28 AM
  #160
ezatnova's Avatar
2016 C63S
Good info. What makes the boost solenoid connection optional? Does it just provide boost readout, so if you don't care to see what it is then you don't need it? Or is there an operating difference when using it or not using it?
Old Oct 29, 2018 | 11:49 AM
  #161
AlexZTuned's Avatar
2017 Porsche 911 C4
Yes, Dinan uses 4 connections. Two MAP sensor connections, and two boost pressure sensor connections. There are also a few piggybacks out there that have a 5th connector for the camshaft position sensor.
Old Oct 29, 2018 | 01:49 PM
  #162
BMS's Avatar
BMS
2018 C63 Sedan
It allows the JB4 to to directly control the turbo wastegates. We're evaluating now in what situations it will be beneficial. But it's intended more for the aggressively tuned race gas or water/meth crowd who want every last horsepower.
Old Oct 29, 2018 | 02:50 PM
  #163
Mr. Pink's Avatar
W205 c63s AMG
Boost solenoid? Does this mean the future may hold a single turbo conversion? Would be same as n54 no? Jb4 having the capability to control a Mac solenoid?
Old Oct 29, 2018 | 03:03 PM
  #164
BMS's Avatar
BMS
2018 C63 Sedan
Yes, very useful for singles, hybrid turbos, etc. Want to make sure we have all the future bases covered with the hardware design. We're also working with customers who already have flash tuning in place and want to use the JB4 for fine tuning, boost by gear, logging, WMI control, etc. Got that covered too.
Old Oct 29, 2018 | 06:26 PM
  #165
Mr. Pink's Avatar
W205 c63s AMG
Awesome! Very exciting stuff! I will be one of your customers with an ECU flash already done, but will 100% be running in combination for the map switching and logging capabilities and fine tuning. Extremely excited for a map 5 and some e blends if possible!
In regards to e85, have you guys tried full e85? Or only e30-40 blends? If you have tried full, is there big limitations to our fueling that would need to be addressed?
Old Oct 29, 2018 | 06:37 PM
  #166
BMS's Avatar
BMS
2018 C63 Sedan
Straight E85 no go, a mix is workable, but we're running in to fuel pressure issues at higher power levels on any E85 mix that need to be further evaluated. We'll definitely include an E30 map though with it. Just not sure yet where it's performance will wind up.
Old Oct 29, 2018 | 08:52 PM
  #167
gOt BoOsT's Avatar
‘17 GT F1A E85 Monster ‘16 C63s
Is there a high pressure fuel pump upgrade available? I was able to upgrade my hpfp on my Audi with an Autotech unit to keep up with higher boost levels and 33% ethanol blends. Is that an option on this platform? If not, 100% meth injection could add some fuel to the fire.
Old Oct 29, 2018 | 11:25 PM
  #168
BMS's Avatar
BMS
2018 C63 Sedan
On pump I'm not sure what hardware yet exists, but the JB4 supports progressive water/meth control with safety. So we'll definitely be working on that.
Old Oct 30, 2018 | 01:06 AM
  #169
RNS-11Z's Avatar
09 C63
Off topic question, what’s the chances of using the jb4 on a supercharged m156?
thanks
Old Oct 30, 2018 | 02:00 AM
  #170
Mr. Pink's Avatar
W205 c63s AMG
I was talking to a guy who has ventured off on his own R&D on this platform and doesn't post much about it. He told me the stock pump is 400l/hr however the line from factory is 8mm od and claimed going to a 10mm line made a big difference, he also claimed adding a second line would help also. Last we talked he was upgrading and adding a second pump.
Maybe something to look into.
Old Oct 30, 2018 | 02:49 AM
  #171
silverstar11909's Avatar
c class
You mentioned earlier that you guys are offering a 5 year warranty...
is that any different then what Dinan offers?
I think for a lot of people that’s the only reason why they wouldn’t switch. More HP is always amazing. But on more aggressive tuning mapping and being able to adjust boost levels, kind of scares me on a product that hasn’t been released if that makes since.
Old Oct 30, 2018 | 10:42 AM
  #172
Star4life's Avatar
2017 C43 AMG
i run jb4 on my c43 and have increased the top speed via oem ways. if anyone wants their top speed increased, pm me. I do not need to flash or crack anything open. Just plug into OBD and can increase it. I make it sound simple as I have done all the leg work on the back end but pm if you are interested. It pairs nicely with the jb4.
Old Oct 30, 2018 | 11:26 AM
  #173
BMS's Avatar
BMS
2018 C63 Sedan
We warranty the JB4 tuning hardware not your tuned vehicle. There are tens of thousands of JB4s out in the wild since 2008 so it's not a new approach by any stretch. One that has proven to be very reliable especially on the default maps. But there are always risks running higher than factory power levels and the the more power you add the higher the risks so consider that when deciding whether or not to tune it.
Old Oct 30, 2018 | 11:27 AM
  #174
BMS's Avatar
BMS
2018 C63 Sedan
thanks
We only support specific turbo platforms, sorry.
Old Oct 30, 2018 | 11:29 AM
  #175
BMS's Avatar
BMS
2018 C63 Sedan
It's a 1/2 mile race, not much effort went in to starting the runs as all their timing equipment measures is your trap speed at the end of 1/2 mile. With dragy in the car though you can at least get a good idea on how 1/4 mile traps look. Given the high DA we were happy with both. Especially the stock to tuned delta.
