Panamericana Grill
You will need to remove the coolers to install the grilles as the ducting is in the way
Here it is installed , perfect fit and goes on very easy .You can see how much damage mine have and I only have 15,000 miles
Here they are both installed
Close up of how the barbs such into the fins to hold in place
just curious did you go to MB dealership to install the grill? If so how much did it cost you if you don't mind me asking?
im looking to order the parts from MB and have them install it.
There is a white one in this thread from Ontario that has a black version new style grille , I'm thinking its aftermarket ,and it has the old style lower grilles so you can judge for yourself .
The Mercedes parts catalogue does not show any add't parts and the sensor seems to be the same part number as earlier years . For now I zap strapped mine in place but there must be another piece or something different about the sensor ......... anyone ?
I
i bought this dummy too. Do i have to connect this with the part that comes with the Panamera grill? Seem like i cant combine them. Pls see the otherr photo. Need help guys
this order include the 2 radiator protection grill on the sides and 1 in the center bottom
part numbers A0995030200 for the 2 on the sides
A0995030000 for the center bottom
