Noob tuning question
This is kinda a weird example, but think about it this way. You have a TPMS sensor inside of each of your tires/wheels. It reads the pressure of each tire and then sends that signal back to the car. If you were to install a device between the TPMS sensor and the car, you could use that device to manipulate the reading shared between the sensor and the car. The sensor reads an actual 38 psi, but my device changes it to read 5 psi less (33 psi) inside the car. I then go, thinking my tire is low, to fill up my tire until the reading in the car says 38 psi. In reality, the tire is now at 43 psi, but the car only ever sees it as being at 33 psi and needing to be bumped up to 38 psi. It never sees the higher 43 psi reading.
I can't speak for other tuners, but if you're referring to how much power we add with the vehicle, our performance maps are determined through years of experience with turbocharged engine tuning including thousands of miles, repeated dyno runs, 1/2 mile and quarter mile pulls on our development vehicles, and reviewing hundreds of logs. Based on this information, we make recommendations based on map use for available octane, other modifications on the vehicle, etc.
A prospective buyer could think they are buying a car with say 50000 miles not knowing that additional stress has been placed on engine components and drivetrain/gearbox
I just love it when tuners state ‘within safe limits’
So clearly the M177 Block and other key components can handle more power. Whether the C63S's Turbo's themselves are over stressed is another story. I'm sure it'll be fine though.
I haven't tuned my car, not because I am worried about long-term reliability, but because I'm worried about voiding my warranty and affecting my resale value. In Canada, we don't have as many rules protecting us, so the dealer could easily void the warranty on the entire car, even if that failure was totally unrelated to the tune.
I don't plan to keep the car past the warranty period, so I want to make sure the car stays "marketable" so that I can sell it and upgrade in the near future.
