C63/C63S AMG
Heat Exchanger mesh covers
Old Mar 6, 2019 | 10:41 AM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
Since these stock units are prone to damage from road debris, causing leaks and potentially leaving you stranded has anyone come up with mesh covers for additional protection for the heat exchangers?
Old Mar 6, 2019 | 10:52 AM
skim7x's Avatar
Mercedes-Benz E63s AMG
Problem is the more mesh you put on there, the more you'll impede airflow :-/
Old Mar 6, 2019 | 11:25 AM
raudiace4's Avatar
Negligible loss of flow, I would think if it's a thin wire mesh.
Old Mar 31, 2019 | 01:09 PM
DonC63's Avatar
C63
shmee has screen mesh installed on his GTR by Renntech he said they add the mesh to all there race cars
Old Mar 31, 2019 | 02:06 PM
DonC63's Avatar
C63
about 4:20 in his video
Old Mar 31, 2019 | 04:50 PM
skim7x's Avatar
That mesh is probably about the same density as the stock mesh on my car... Maybe putting that sort of mesh behind the stock mesh might help a bit... Not too restrictive...
Old Apr 1, 2019 | 11:04 AM
raudiace4's Avatar
Originally Posted by DonC63
Nice might give this a shot. Mesh isn't going to cause noticeable disruption in air flow to the coolers, I wonder if shmee's car had any changes in normal trans/oil temps after bc of the mesh. Highly doubt it.
Old Apr 3, 2019 | 05:41 PM
jinnsound2's Avatar
2016 AMG C63s
I know a company called Frog Skins, they make a really thin breathable mesh, they use it for snowmobiles and I'm thinking this would be a great solution for our cars
