C63/C63S AMG
Which ones quicker/faster?
Old Apr 1, 2019 | 02:07 PM
speedpeddler's Avatar
2014 E63, Cobra replica, 68 Camaro, 66 Chevy II SS, Z4 BMW, Honda Element, Birel 125cc Shifter Kart.
So, my brother and went out And found out. C63 is tuned with 600+.. Cobra is 473 HP AND 2200 lbs. I know, the garage is a mess
Old Apr 1, 2019 | 02:20 PM
FreddyG's Avatar
You've got a couple of Beautiful cars there, but you can't leave us hanging like that! Which one won and was it a close race or no?
That Cobra has to be a Beast to drive!
Old Apr 1, 2019 | 02:23 PM
Full report to come. Patience.
Old Apr 1, 2019 | 03:07 PM
Trying to work around some remodeling going on but here’s how it went down. I’m sure most knowledgeable car guys know the answer to both and truthfully so did we. As you’d suspect, form a dig it’s no contest. We run full time DR’s on the Cobra and it’s light weight make it a beast from a dig. Put two cars on the C in 60 ft and it got worse from there. Then we moved to roll racing from 60 to 100 where I felt the light weight of the Cobra and unlikely wheel spin from the C would make for a closer race and it did. Cobra still got the jump and won but the C was closing hard and I have no doubt had we kept on going the C was going to run away from the Cobra. Aerodynamically the Cobra is a brick and it takes a lot to push them at high speeds. The C just seems to pull forever. Fun times.
Old Apr 1, 2019 | 04:05 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
No doubt ... the tuned C63 is faster
Old Apr 2, 2019 | 01:03 AM
scrufy's Avatar
2019 C63 s
I’d normally just say the c63s because its Brilliant Blue and everyone knows that alone adds 25hp but the cobra looks to be almost the same blue so its too close to call haha
Old Apr 2, 2019 | 08:54 AM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
Beautiful cars. Like you said a tuned C63 will have little problems walking away from a classic muscle car up top.
Old Apr 3, 2019 | 12:01 AM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
Cobra will be faster depending on its motor ,rear gears and if you can hook it . I have a Factory Five Cobra with a Paxton Novi supercharged 302 , 5 speed and 3.73 and running 315 tires in the rear . In acceleration the cobra is definitely faster than my C63S , its a beast ,and it is definitely capable of a 10 second 1/4 . I ran 11:80s in my Vortech supercharged stock long block 92 5.0 mustang and the cobra is a 1200 lbs less running more boost .
Dyno tuning run in 3rd gear :
Old Jul 25, 2019 | 02:38 PM
Ph4tLyfe's Avatar
Toyota Prius
My money is on the Cobra, since the c63s is a fat pig.. even a BMW m4 is faster than c63s..
Old Jul 25, 2019 | 03:15 PM
jinnsound2's Avatar
2016 AMG C63s
Lol you got a M4 or something, Personally My Fat Pig has never had a problem beating an m3/m4
Old Jul 25, 2019 | 03:30 PM
PD46AG's Avatar
C63
[QUOTE=C3504matic;7722225]Cobra will be faster depending on its motor ,rear gears and if you can hook it . I have a Factory Five Cobra with a Paxton Novi supercharged 302 , 5 speed and 3.73 and running 315 tires in the rear . In acceleration the cobra is definitely faster than my C63S , its a beast ,and it is definitely capable of a 10 second 1/4 . I ran 11:80s in my Vortech supercharged stock long block 92 5.0 mustang and the cobra is a 1200 lbs less running more boost .
Dyno tuning run in 3rd gear : https://youtu.be/K5gbQJgWI9k[/QUOTE] Love the Dyno run. At WOT that thing sounds like what I imagine being caught in the vortex of a tornado would sound like. Scary.
Old Jul 25, 2019 | 04:15 PM
dutchboy's Avatar
911 Turbo, C63s Coupe, Raptor
My M4 with JB4 and downpipes is slower than my C63s coupe with a Dinan tune.
Old Jul 25, 2019 | 04:36 PM
gpdriver177's Avatar
2019 BMW M5
After some googling... C63s. MotorTrend tested a Cobra replica with 485 hp. It did 0-60 in 4.6 and ran a 12.7 at 112 mph.
Old Jul 26, 2019 | 06:22 PM
LessIsMore's Avatar
2017 AMG C63
Those results do not sound realistic. Like nowhere close. Should be MUCH faster. Maybe that was old school gross HP measurement? Maybe an inefficient original 4 spd trans? Even then the light weight would offset it.
Think about it ... a W205 non-S C63 has less hp and probably 1500+ lbs more ... and is faster?
