Race mode
I've been tempted to try covering the cameras to see whether that might disable this entirely, but worry about what other effects it might have, given the (often non-obvious) highly integrated nature of these sensors and systems. Interestingly, it seems that the system learns since (for me) this only seems to happen a few times during the first session on a track day (or maybe it's me that's learning?).
Why would you drive around with traction control off all the time? I understand putting is in Sport mode but not turning it all the way off. It isn't 2004 anymore. The systems on our cars will best 99%+ of drivers, especially when pushing it out on public roads.
RACE mode makes a lot of great noises, but the power delivery seems about the same to me...wonder if it is a whole different MAP or not? It would make sense if it was more linear for track use, and as others said the gearbox does not shift unless you use the paddles it's manual mode. I do like RACE for that reason also but then you get frustrated when you realize your paddles are on the steering wheel and they are upside down when you turn...damn MBZ put the freaking paddles on the column like every other floppy paddle trans!
I’ll ask the AMG team at COTA when I go later this month.
You are absolutely right though, there is a significant difference with the addition of AMG Dynamics.
In S+ with Pro dynamics, the car allows a LOT more slip than compared to S+ in the pre-FL (which really didn't change much handling at all, except for engine/transmission). It makes the car feel dynamic and fun. And Sport (Advanced Dynamics?) will also allow more slippage than in Comfort mode. I am going to guess that when pushed to the limit technically, AMG Dynamics will play an even bigger role. I've just not had the time to go for a pleasure drive, but this is something I need to do soon.
