C63/C63S AMG
New Tire Question
Old May 9, 2019 | 05:34 PM
g2lujinn's Avatar
2017 C63S Sedan
I used the 19" wheels with a J value of 9.5 front and 10.5 rear, it has no fitment problem at all and I lowered my car with KW HAS, can't remember the exact amount of height, but it's pretty low, you can't insert a figure there. No rubbing issues at all.
With a 36 psi front and 32 psi cold rear, the car runs extremely comfortable.
Old May 10, 2019 | 06:16 AM
Zeek1's Avatar
W205 C63s
If you are running 295 on standard rear wheels you must increase Tyre pressure otherwise you feel the flex in the tyre sidewalls. If you have wider wheels then sidewall movement is not really an issue.
