Apple CarPlay???
I just tried the engineering mode, but mostly everything is grayed out. How do I access it so it’s not grayed out?
Be careful not to accidentally change anything else. I lost my Sirius somehow, but I was able to turn it back on in the Engineering menu.
I guess I’m in dealer mode. How do you get to engineering mode?
red phone button , 1, & #.
Press these at the same time and hold them 10 secs .
I believe on the M's you have to press a 4th button. There should be several threads about entering Engineering Mode.
if you have command stock in your car (bigger screen), pretty much the only solution is aftermarket. (i sell the better ones). Or if you had audio 20 headunit (smaller screen), then you can do an oem carplay upgrade (i sell this retrofit as well stateside).
That guy is right about needing to have DTS monaco, or you can use vediamo, but either are useless without proper knowledge and database files. if interested pm me and i can explain options.
Would this OEM CarPlay work on a 2016 A180 Sport Premium? If so how much do you sell it for I’m based in the UK.
I have an aftermarket version from JoyeAuto as well as listed above. It is wireless carplay and one of the best ones on the market that I have tested. I have a special price for MBworld members thats cheaper than you can get through them. and I give USA support for install and such which makes language barrier not a problem.
pm if interested. i have 1 in stock. this is a side thing i run out of my main business to help forum users out. I originally bought for my own personal use and some others asked me to get one for them so I ordered 10 at a time and can get more. I wouldnt waste my time with any other aftermarket solution.
just trying to help the forum out! your best bet may be just to buy a obd module to activate. if you want VIM or other coding services then you may want to pm me to help you out as the cost for multiple obd modules will be more than 1 coding session.
I bought it on Aliexpress and it arrived by DHL in 2 days. I highly recommend this version since it's wireless and with auto-connect when you start the ignition. This system is amazing and the compatibility with the car has been great. When listening to Spotify, the sound of the audio is much better through the Joyeauto Carplay than the OEM Bluetooth or wired USB connection and I suspect it's because the sound is now being transmitted from the iPhone through WIFI to the Joyeauto system. There are now also 3 equalizers to manage the sound quality and even the phone sound quality from the internal speakers are even better.
The 3 Equalizers are:
1. Burmester equalizer
2. Joyeauto built-in equalizer
3. Spotify equalizer
For the install, there is a lot of large plug in play wires that need to go behind the head unit and not a lot of room. The microphone for the SIRI is installed next to the ashtray/12V and very hidden.
If anyone wants to buy a OBDII aux-in and VIM module activator, it's for sale as well. PM me if interested.
I received my Joyeauto wireless CarPlay kit today. Delivery was fast but after installation my Mercedes Radio function was displaying a "Device Unavailable" message. I expected all existing Mercedes functionality to work and have uninstalled the box for now.
Any ideas what might be causing the issue?
Anyone else installed this that can check if the Mercedes DAB (UK) Radio function still works for them?
Any help would be appreciated.
Hope you resolve it.
do you have AUX in activated?
***UPDATE***
Received the activator today and installed the Joyeauto kit again. Turns out there was an additional cable for the radio that wasn't mentioned in the install video. It had to be removed from the original 48 pin connector and plugged directly into the Joyeauto 48 pin connector. This solved my DAB radio issue. Everything is working now.
A few observations from my first few hours using the system.....
CarPlay works really well and connects wirelessly with no problems. The audio is good (I've got the Burmester package), and I can't really tell any difference when listening to Tidal Hi-Fi between the original setup and the new setup. Moving between the Mercedes system and the Carplay system is very quick and you can even listen to the Joyeauto system while using Mercedes system functionality that doesn't need audio (e.g car settings, air-con control, navigation, etc). Navigating CarPlay and using the apps with the Mercedes controls is easy enough. It's also worth mentioning the staff at Joyeauto were quick to respond when contacting them via Aliexpress messenger and provided additional photos and advice when I mentioned the issue I had with the radio.
The not so goods....
- If my phone is connected to the car's built in Bluetooth the CarPlay function gets disconnected. This means I've had to 'forget' the Mercedes connection as simply disconnecting it resulted in it automatically connecting again after a minute or so and therefore disconnecting CarPlay again.
- The steering wheel controls for answering and ending calls don't work with the JoyeAuto system. it's a bit annoying but a simple click on the jog-wheel answers a call and another click will end the call. Volume and other controls work fine controlling the Joyeauto system.
- Receiving calls through CarPlay is clear for me but, although the person I'm speaking to can hear me fine, they can also hear themselves. I'm guessing the Mercedes system has noise cancelling or some other trickery that the Joyeauto system doesn't have. Not a deal breaker for me but I'll probably connect to the Mercedes system when I have any lengthy important business calls to make.
- Fitting is easy but there is no room behind the Mercedes head unit in my C63 to hide the box. I've fed the cables through to the passenger footwell and the box is currently hidden between the bulkhead and the upper part of the footwell. You can't see anything unless you get out the car and stick your head right under there. I'll probably have a longer look at this another day to see if there is anywhere better to hide it. Removing the tray under the glovebox and fitting in there might be an option but it's fine where it is for now.
***UPDATE***
MFAMG i'm looking at the same product to use with android auto, were you able to use google maps and listen to the radio at the same time?
One problem you would have would be phone calls. Any phone calls coming through AA would have no audio if you're listening to the car's radio. I tried getting round that by connecting to the car's Bluetooth while connecting to CP, but CP won't let you can't connect to the car's bluetooth system and CP on the box at the same time. AA may be different.
You could just use TuneIn or similar internet radio app on AA so you don't have to listen to the car's radio.
