C63/C63S AMG
2019 rear diffuser/ tailpipe swop now completed.
Old Jul 24, 2019 | 05:42 PM
NJ 1161's Avatar
2018 c63
So, I’ve recently posted a few times on swopping out a 2018 rear diffuser to the facelift rear diffuser and bigger tailpipes. I had reservations as had an edition 1 lower spoiler ready to go but got to say I’m really pleased I went with the 2019 rear as the bigger tailpipes looks great!
I’ve already done the front grills, front spoiler, side skirts and rear spoiler and love the change.
Today I got my garage to do the rear swop. I help where I can. Said it would take an hour tops so they would squeeze me in. Hmm, could of been a bit optimistic!
Exhausts off easily, 4 bolts. Various pot rivets need drilling out and a couple of bolts. Some un clipping and eventually the rear diffuser comes off. Then more pot rivets to remove the brackets that hold the exhaust tips on. Need to unplug 2 rear sensors and boot opener.
Then first problem became apparent. Inside the diffuser is a plastic part and this contains the boot opener / gesture sensors. These didn’t line up with new diffuser. Not sure if the 19 has a different part, but after a bit of modding and a couple of pot rivets we got the part fitted, but not a simple swop and one to be aware of if you have gesture boot opening.
Tailpipes on. Two little tabs on each slide in and replace 2 screws per side.
Inner exhaust mounting bracket on both sides needed these drilling out and replacing.
went to refit and another problem. 2 small clips either side left and right, need cutting off as no slots on 18 bumper. No biggy, just cut them off. The diffuser had 2 screws provided so used these, 1 per side on the outer edges of the diffuser to secure.
Lastly, rear tray clips in on the sides and then add screws on the bottom to secure and finally push fit the last trim bit on that covers up the clips from the tray.
Anyway, wouldn't say this was a simple swop but all done. If you have gesture rear boot either buy the 2019 part of be prepared to modify. Overall took 2 hours with a ramp and 2 people ( well one mechanic, and me so maybe 1.5 people!) and very happy with results.
Couple of extras,
Old Jul 24, 2019 | 06:10 PM
velosdesignwerks's Avatar
Former Vendor of MBWorld
Mercedes C63S AMG (W205)
Very Nice, well done!!
Old Jul 25, 2019 | 09:07 AM
1 SIC DR's Avatar
2017 Benz C63S Coupe
Looks great !!!! Where did you order the diffusers and tips from ?
Old Jul 25, 2019 | 09:59 AM
playalistic's Avatar
2019 C63s Coupe
Nice, but I'm biased Is that an edition 1 spoiler and splitter? Where did you get it from and are they OEM?
Old Jul 25, 2019 | 04:12 PM
NJ 1161's Avatar
2018 c63
Bought all direct from MB. All Oem. If in uk and need contact pm me but he won’t send abroad, sorry.
Old Jul 25, 2019 | 04:55 PM
NJ 1161's Avatar
2018 c63
Rear spoiler is edition 1. I got this Oem piece that I believe to be the same as facelift c63s but could be wrong from cks performance for £290:ish. It’s the only item I’ve eve bought fro them as normally they over inflate MB prices and sell on. In this case I got lucky. They are now listing it for £600 so I’d check with MB what they are selling it for as bet it’s cheaper.
Rear diffuser is c63s facelift standard diffuser, also from merc. I can pm you my parts guy details if needed. Thought you had 19 so don’t you have this already?
Old Jul 25, 2019 | 04:57 PM
NJ 1161's Avatar
2018 c63
Sorry, mis read. Front splitter also from merc, Ed 1 but again think the same pics as facelift?! From merc Oem, Circa £400 for front splitter iirc.
Old Oct 30, 2019 | 11:31 AM
Star4life's Avatar
2017 C43 AMG
do you have part numbers for new exhaust brackets?
i understand all the main parts needed but you didnt post the bracket part numbers for diffusor or for exhaust tips right?
edit: figured it out.
saw another thread of yours with brackets.
sedan night package c63s parts if anyone runs across this thread.
1. Bumper Holder
Part # 205-885-55-03
2. Bumper Holder
Part # 205-885-56-03
3. Lower Trim Panel Rivet
Part # 003-990-94-97 x 12 pieces
4. Trim Bezel
Part # 190-490-51-00
5. Trim Bezel
Part # 190-490-52-00
6. Wind Deflection Channel
Part # 205-885-54-03
7. Spoiler Clip
Part # 003-994-75-45 X 8 Pieces
8. License Plate Bracket Screw
Part # 001-984-64-29 x 8 pieces
9. Trim Bumper
Part # 205-885-46-03
10. Ornamental Molding
Part # 205-885-51-03
11. Cover, Towing Eye
Part # 205-880-60-08
12. Cover, Towing Eye
Part # 205-885-33-03
Old Jan 18, 2020 | 12:52 AM
pussgalore's Avatar
na
1. Bumper Holder
2. Bumper Holder
4. Trim Bezel
5. Trim Bezel
7. Spoiler Clip
9. Trim Bumper
You might also need a bumper bracket A2058855303 for sedan in addition to #1 and #2 above.
Old Jan 18, 2020 | 03:18 AM
Jimmy_c63s's Avatar
Beautiful write up, detail and car. I wish there was a nice write up like this for installing and fitting the facelift grille too (then we would be complete)!
Old Jan 19, 2020 | 03:32 PM
Star4life's Avatar
2017 C43 AMG
yes this list is semi incomplete. i ended up just buying from a guy on ebay. his price was close enough to dealer price to not worry about the hassle of figuring out if it would fit.
Old Jan 25, 2020 | 09:00 AM
Acerboo's Avatar
C63s
Couple of extras,
looks good especially the gloss black. any chance you have the part number for the flat grille star
Old Feb 14, 2020 | 11:35 AM
deftronix's Avatar
17 C63S coupe
Coupe looks amazing, thanks for sharing. Do you have any further details/pics of the retrofit you did on the gesture sensor?
Old Mar 5, 2020 | 01:13 AM
Jimmy_c63s's Avatar
One of my favorite C63 coupe's here. Using this thread i'll be doing this update soon. Could you tell us what rear spoiler you have there mate? Is it in Gloss Black too?
Old Mar 5, 2020 | 04:44 AM
NJ 1161's Avatar
2018 c63
Hi - the gesture unit mounts in the diffuser.
it has small slots and click into plastic tabs. Top tabs were fine and lined up. Bottom tabs didn’t. We tried making slots slightly wider but still wouldn’t line up. From memory I think we put two small screws in it to hold in place. They are right at the back underside and not visible.
Old Mar 5, 2020 | 04:47 AM
NJ 1161's Avatar
2018 c63
Hi- thanks. It’s the standard merc edition 1 gloss back spoiler. I think it may be the same as the rear facelift spoiler.
Old Dec 30, 2020 | 06:24 AM
DialDforDan's Avatar
GTS
Just a quick note to say thanks. Super helpful write up, helped heaps when doing mine.
By chance, can anyone confirm which bootlid spoiler I have on this? I'd like it in gloss black now too but would prefer to buy a replacement than paint over this. Can't seem to find one that looks the same.
Cheers,
Dan
Old Dec 30, 2020 | 04:36 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
Merc is for Mercury. Benz is for Mercedes Benz. Not the same. Although I do like you SWAP...
Old Jan 12, 2021 | 04:46 AM
RobertsC63's Avatar
C63
Have sent PM - interested to get the part numbers including fittings - thanks for doing the write up.
Old Jan 13, 2021 | 06:07 AM
NJ 1161's Avatar
2018 c63
Hi Robert, not receiving the pm for some reason, but sold the car now and all receipts with part numbers on went with the service folder so afraid I don’t have them anymore other than what listed in the thread.
Old Jan 13, 2021 | 11:46 AM
RobertsC63's Avatar
C63
Ah O.K. not to worry - which dealer did you use by interest, feel free to PM if prefered.
Old Feb 6, 2021 | 01:23 PM
NJ 1161's Avatar
2018 c63
Hi, just wrapping this thread up as after 2 and a bit years of enjoyable ownership as Ive sold the car mid December so won’t be around here much going forward. I tend to get a pm every month or so asking for part numbers so just to be clear I only have the part numbers listed in this thread.
Do have a coupe of parts if anyone U.K. based interested which I will pop in the classifieds.
ASR c63 exhaust flap module with 2 remote controllers ( one still with film on) 9 months old and can provide receipt. £240 posted next day.
BMC c63/ c63s air filters (pair). Brand new £115 posted.
https://www.cksperformance.com/produ...SABEgLnWvD_BwE
Old Apr 10, 2022 | 10:21 AM
noremaC's Avatar
17 C63S Coupe PTG1000
I’m going to carry out this facelift retrofit for my 2017 coupe. CKS Performance carries a genuine Mercedes kit (link) with the facelift tailpipes, brackets and diffuser. However, judging from another post it seems there are other pieces required for a PFL to FL diffuser retrofit? If so, does anyone have the part numbers handy?
I may go with the CKS package but the other option I am considering is getting the required brackets and parts from Mercedes’ (the dealer), purchasing the facelift tailpipes separately (RW carbon sells them standalone) and then buying RW carbon’s full carbon FL diffuser or the DTM ‘big fin’ FL diffuser.
Old Apr 11, 2022 | 02:05 AM
Jimmy_c63s's Avatar
Did this back in 2020 just steer clear from CKS if you can they're crooks
Old Apr 11, 2022 | 07:53 AM
noremaC's Avatar
yeah I bought my grille from them which was fine but a multi-part package for $1k+ probably is not the move.
@Jimmy_c63s - you mentioned a while back you have a google doc with the part numbers for the coupe - are you able to share?
