Two coolant resevoirs?
Keep an eye on that central coolant tank that is in the middle of the engine. If it goes dry you have a problem. This does indeed feed the secondary coolant system for the turbos and gearbox. The pumps are not robust and fail frequently. It's a €250 part so not the end of the world and of course if you have warranty it should be covered.
Your gearbox oil temp will keep going up and there is no warning or shutdown - so check that reservoir every time you check your oil (which is every two weeks, right?).
And I've looked everywhere in the manual and there's no mention of this second expansion tank. When this tank runs dry, there is no warning or alert. You have to discover it on your own.
Hi All, I’m new to this first time using wondering if someone can help me.
I have a 2016 C63s coupe and was damaged by a friend who was borrowing it.
It only suffered damaged from passenger wheel, coolant pump passenger side and the coolant rad passenger side and also corner of 2 rads at the front one being the main rad and one at the front which is connected to the passenger small rad. The old pump was broken in half (maybe short too) I have now fitted everything brand new from MB. once fitted I filled up both water tanks one on the driver side and one in the middle of the engine.
the one in the middle of the engine didn’t take much water at all considering it was all empty.
I am now worried that the small electric pump isn’t working how as the water isn’t flowing in the small rad on the passenger side any ideas how I can check if it’s working or when does it work? Also if anybody knows if there is a fuse or relay for it.
thank you very much I would be grateful if someone can help
(if you only have water in there then I’d suggest shining a torch one side and looking the other, not long before getting proper coolant in there!)
I have a small leak on the coolant pipe leading directly from that small tank and so have been looking at this part of the engine for a few days now. By the way does anybody know the part number or name for that exact tube?
Does someone know whether it's normal for this second tank to empty over time.. as far as I thought coolant systems are closed systems and a drying of the reservoir would indicate there is a problem somewhere in the coolant system.
Took the car in for the annual maintanence and dealer showed me the lower coolant reservoir covered in dried/aged pink coolant. He said that the intercooler has an internal crack that significantly increases the pressure in the low coolant reservoir causing it to leak around the cap.
But I’m wondering if maybe the reservoir is just old and the sealing around it isn’t doing the job anymore?
Any feedback is much appreciated!
There are far too many examples (if you search for it) of coolant caps being replaced and fixing leaks like that.
I would replace the cap, and the reservoir at a push first.
Sure, I guess it’s not completely 100% impossible for the intercooler to have an internal leak through which compressed air enters and increases the pressure in the coolant system, but what would cause such a leak in the first place. Moreover I expect this kind of thing would decrease the car’s power/performance enough that it would be noticeable, right? Especially if the leak would be so pronounced that it causes the coolant to bubble up and out of the reservoir.
Are any of you 3 blokes getting a coolant smell as well? From outside of the car after you drive her hard?
Or is it just the empty reservoirs for now?
