C63/C63S AMG
Those with BC Forged Wheels .... take a read
Old Oct 31, 2019 | 01:41 AM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
I decided to take my rear wheels off to do some work and when I pulled the wheels off I found water had entered the wheel through the ctr hole and pooled in the hub area and the hub had started rusting as the water had been in there quite some time . The stupid design of their ctr cap allows water to enter through this small hole in the cap which is behind the cap and it has a ring around the cap . It doesn't allow the water back out and keeps it inside ..there was quite abit of dirty rusty water inside and that poured out . I ended up grinding all the rust out and painting the hub and then sealed the hole in the ctr cap so it cannot allow water back it ..... what a stupid design , not sure what they were thinking so I suggest you guys take a peek inside yours
Old Oct 31, 2019 | 11:21 PM
LessIsMore's Avatar
2017 AMG C63
A pic would have been great. But good to know thanks for the heads up.
Old Nov 1, 2019 | 12:25 AM
C3504matic's Avatar
Sorry , didn't take any photo's ... was too pissed off about it and fixed it right away
Old Nov 1, 2019 | 12:29 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Originally Posted by C3504matic
So I decided to take my rear wheels off to do some work and when I pulled the wheels off I found water had entered the wheel through the ctr hole and pooled in the hub area and the hub had started rusting as the water had been in there quite some time . The stupid design of their ctr cap allows water to enter through this small hole in the cap which is behind the cap and it has a ring around the cap . It doesn't allow the water back out and keeps it inside ..there was quite abit of dirty rusty water inside and that poured out . I ended up grinding all the rust out and painting the hub and then sealed the hole in the ctr cap so it cannot allow water back it ..... what a stupid design , not sure what they were thinking so I suggest you guys take a peek inside yours
It doesn’t matter anyway. There will always be rust build up between the rotor hub and the wheel meet.
Old Nov 1, 2019 | 01:28 AM
C3504matic's Avatar
Its not the face of the rotor its the actual ctr bore of the hub ...there shouldn't be any water in there ... it was filled 3/4 full ( ctr of actual wheel) and rusted pretty heavy and in the inside of the ctr cap turned to almost black
Old Nov 1, 2019 | 08:00 AM
alexasa's Avatar
c
so irrationally bothered lol
this is not exclusive to bc wheels
Old Nov 1, 2019 | 08:46 AM
C3504matic's Avatar
Talking
Ive had lots of wheels on my cars and I work for Mercedes and have never one come in with this issue so it's not that common ...... its a design flaw but this is just a warning for others to check their wheels or don't ...their choice
Old Nov 1, 2019 | 08:56 AM
hyperion667's Avatar
2012 CLS63
You started a sentence/paragraph with the word SO...no I am not the grammar police, it's just I see it so often now it's really annoying.
Old Nov 1, 2019 | 09:32 AM
C3504matic's Avatar
Just for you I fixed it .....
Old Nov 1, 2019 | 04:04 PM
GuardianVA's Avatar
'19 C43
Old Nov 1, 2019 | 06:56 PM
Schulminator's Avatar
2015 C63s Sedan
No issue with my wheels....
