C63/C63S AMG
panamerica a grille distronic problem
Old Dec 12, 2019 | 04:09 AM
Acerboo's Avatar
C63s
i have a panamericana genuine merc grille retrofitted to my car. recently i’ve had a problem when cruise control is activated the distronic works perfectly when approaching a vehicle in front but it’s also slowing the car when overtaking a vehicle. dealer says no problem with the distronic but says it’s probably the “aftermarket” grille. has anyone had a similar problem. thanks
Old Jan 2, 2020 | 01:48 AM
srO_Michael_Orz's Avatar
C63s(lost)/E250/GTR(Sold)/GTS(Carbonerre)
Did you use original front emblem?
Old Jan 2, 2020 | 05:23 AM
Acerboo's Avatar
C63s
hi no I got a new star with the grille
Old Jan 2, 2020 | 08:11 AM
as I except, , that s the problem. You have to use original star. The material is special made for millimeter wave radar penetration.
Old Jan 2, 2020 | 09:31 AM
untamedd's Avatar
2019 AMG GT R
why would that be a problem if it is an OEM grille and OEM star?
In the 1.5 year ive had the car I think I only used distronic once and noticed that the car hesitates and brakes unnecessarily when it comes to overtaking a vehicle so that is why I am curious as to why would that be an issue if the new grill is OEM which in my case it is. Would the dealer just have to re-calibrate the system maybe?
Old Jan 2, 2020 | 09:47 AM
I doubt distronic is working just like that, no problem sounds from me. Mine do the same hesitates like that. Its not AI like LEVEL 5 self driving car. BTW DTR sensor calibrate themselves over the time, and no software update so far.if you force dealer to calibrate it, some times even worse.
Old Jan 2, 2020 | 09:50 AM
untamedd's Avatar
2019 AMG GT R
I doubt distronic is working just like that, no problem sounds from me. Mine do the same hesitates like that. Its not AI like LEVEL 5 self driving car. BTW DTR sensor calibrate themselves over the time.
I guess its just one of those Mercedes quirks errr... I had distronic on a 2012 Dodge previously which worked flawlessly and here I am in this mercedes where the car hesitates so much that I have to turn distronic off.
Old Jan 2, 2020 | 09:51 AM
Try Tesla, You are not going back.
Old Jan 2, 2020 | 09:53 AM
untamedd's Avatar
2019 AMG GT R
not ready to go electric yet. Love the v8 rumble.
Old Jan 2, 2020 | 09:54 AM
If its really bad, there is two possible, your camera is out off calibrate, have you ever changed windshield? If not then check alignment.
Old Jan 2, 2020 | 12:10 PM
Acerboo's Avatar
C63s
windscreen not changed I had a good bodyshop fit oem grille and badge. supplier says they have retrofitted many and had no problems. I tried it again yesterday and the distronic display shows a car in front when there is a car in left hand lane but nothing in front in my lane it seems to think theres a car directly in front. other than that it works perfectly when theres a car directly in front. bodyshop said the radar is fitted to the car not the grille so did not distub it when fitting grille.. I often get a warning that sensors are dirty even when the car is clean
Old Jan 2, 2020 | 02:15 PM
i HAVE ALREADY told you, you have to use original star emblem, its not wrong with grill.
Old Jan 2, 2020 | 09:00 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
It's the way the car is designed. Namely, you'll notice that the distance between you and the vehicle you come up on will adjust ~1 car length per mph. When it senses 6 car lengths doing 60mph, the car will slow so you don't run up its crack. It will stay there until the vehicle moves over or you do. And, then it will pick the speed up to where it was.
Old Jan 3, 2020 | 05:21 PM
Acerboo's Avatar
C63s
problem is it thinks there’s a car in front when there isn’t and slows the car down
Old Jan 3, 2020 | 05:22 PM
Acerboo's Avatar
C63s
you cant as the original badge does not fit the facelift grille. many people have fitted the panamerica a grille with no problem
Old Jan 3, 2020 | 05:45 PM
jopsis_c63s's Avatar
C63s Estate
Because they buy compatible grille, not original.
From Aliexpress:
https://a.aliexpress.com/Zjm5dJh2b
