C63/C63S AMG
Best scan tool??? C63S
Old May 27, 2020 | 12:02 PM
Jimmy_c63s's Avatar
Originally Posted by prktkljokr
I have sorted all codes from a 2012 W204 accident damaged apart from hard codes in airbag module with my Autel, even Xentry cant do it you need to replace the module once airbags have detonated.
Have also used it to change instrument cluster, radio, ABS module, seatbelts, reset SRS steering angle sensor and reset after repairs were done on a W204 that was in limp mode, calibrated steering angle sensor, calibrated parking sensors, plus many more procedures that I was told only the star could do,
Apologies for discounting you at the start. You're right mate this tool is the read deal. Buying one today $1500 but like you said it'll pay for itself in the long run
Thanks for recommending this professional tool man, I had no idea this existed until your recommendation.
Originally Posted by kmglamour
Legend. Ordering mine tomorrow and can't wait to get it. This thing is mega it's even got full TPMS functions. Your pics really helped me out dude. How have you found it? Been fiddling with it much?
Old May 28, 2020 | 12:10 PM
RyanL's Avatar
2005 C55, 2016 c63s
Autel AP200 bluetooth dongle 80usd
Does everything the tablets do thru your phone, except relearning tpms sensors
I work on cars and own 3 of the Autel tablets.
The main difference besides the obvious display size, is the dongle only enables one brand with a payment of 34 dollars to activate each other brand.
Pretty good option for the home guy though.
I will buy one just to have the Dongle in the car.
It also isnt vin Locked, so it will work on every Mercedes.
Old Jul 25, 2022 | 08:50 AM
gforc3's Avatar
C63 Coupe
This will clear soft codes for sure? Like exhaust flap or low voltage
Old Jul 26, 2022 | 01:52 PM
BenzNinja's Avatar
Former Vendor
With AUTEL online coding you will blow your coding and get wrong software errrors in many cases
There is 0 solution for coding and programming online replacement
All workshops I have as client tried Autel before joining
if you just want to scan, use a OBD plug and Torque application 50$ + 5$ right on your HU
That MP808TS is,just good for scanning and basic functions
try updating your headlights and you will likely loose the whole front of your car
Then come to daddy (me) to fix it or go to a dealer to do online coding
why would you buy a 1500$ fake not working solution instead of the real thing for 30% less services incl. ?
Old Jul 26, 2022 | 05:37 PM
gforc3's Avatar
C63 Coupe
No one’s coding headlights. I just need to know if the car is throwing soft codes that can’t be read with a typical scanner and clear them if they’re bs instead of taking it to a dealer.
how much is your system
Old Jul 26, 2022 | 06:47 PM
BenzNinja's Avatar
Former Vendor
just saying that because the Autel promises with "Online coding" and "Firmware Upgrade" and not working as they should on MB for about 25%
as far as resetting ecus, small coding changes ect Autel works fine
Old Jul 26, 2022 | 11:59 PM
  #32
Barbalatte's Avatar
C63S
I have an Audi and I use the Hex Rosstec dongle. Very easy to use. You can modify nearly everything in the car. It seems strange there is. I similar device on the market for a Mercedes. Cost was around $300-400 depending on how many cars you'd like coded on the dongle. Mine has 10 cars.
Old Jul 27, 2022 | 03:09 AM
  #33
BenzNinja's Avatar
Former Vendor
you think hat is because you have never tried a Real system
you can not even modify basic things like seat belt chime, and reverse gong or start & stop remember with your tool
Old Jul 27, 2022 | 06:03 AM
  #34
Barbalatte's Avatar
C63S
Originally Posted by BenzNinja;[url=tel:8605643
8605643[/url]]you think hat is because you have never tried a Real system
I don't follow. I've removed my door chime, seat belt chime, and deactivated my start/stop feature for good. For good measure I added the tweet beep when I press my remote button!
Old Jul 27, 2022 | 06:50 AM
  #35
BenzNinja's Avatar
Former Vendor
sorry
didn't read you well
I thought you where talking about Mercedes as this is a Mercedes forum
you where talking about a AUDI can plug
Old Jul 27, 2022 | 07:25 AM
  #36
Barbalatte's Avatar
C63S
Correct. I have both.
Old Aug 30, 2022 | 11:11 PM
  #37
gforc3's Avatar
C63 Coupe
Can anyone please confirm this autel model or something similar can clear soft codes/limp mode on our cars?
Old Sep 1, 2022 | 01:58 AM
  #38
Barbalatte's Avatar
C63S
This thread has been going on for a while. I find on this forum, people are scared or not willing to help each other!
If anyone one asks me for help and I know the answer, why wouldn't I help? Sad really.
I'm sure there is an answer to this thread beside the most expensive option... I also own an Audi RS3, and have a Rosstec HEX V2 and I can practically reprogram the whole car at will, clear codes etc. price is around $300-600 depending on how many cars you want to work on.
Old Sep 5, 2022 | 09:54 PM
  #39
DavidPetrisor's Avatar
W212,W220 S65 AMG
Autel
awesome I’ll buy one today, confirming it’ll work on my 2016 C63S?
Autel i think is best for reading and clearing codes even better then xentry for speed
Old Sep 6, 2022 | 02:01 AM
  #40
BenzNinja's Avatar
Former Vendor
just for reading and clearing it's fine
not the best as it does not contain many many tests
Old Sep 25, 2024 | 09:55 AM
  #41
rnbguy's Avatar
e240 w211
Bringing this back, what other tests do you mean?
Old Sep 25, 2024 | 11:58 AM
  #42
W205C43PFL's Avatar
Peter meant all the guided test.
Old Sep 28, 2024 | 10:20 PM
  #43
CRAZYAPRIL's Avatar
2020 AMG GT53 &:2014 E350
Need diagnostic and programming tool
Originally Posted by amg8
Just dropping a note here that I bought the Xentry kit aka Star Diagnostic tool, it does everything.. Clear any codes you want and a bunch of other awesome features like reset adaptions, fuel mix...and gazzilion other features. I would definitely recommend getting that instead of a generic system.
Hi there, I own 2 merc cars...a 2014 e350 and a 2020 AMG GT53
and want to find diagnostic tool that also has programming capabilities. can you recommend where to purchase one that has good support?
Old Sep 29, 2024 | 03:08 AM
  #44
BenzNinja's Avatar
Former Vendor
That's us
Old Nov 17, 2024 | 04:49 AM
  #45
CRAZYAPRIL's Avatar
That's us
ive replied to the email and await your message Thanks
Old Nov 18, 2024 | 10:28 AM
  #46
Roysup's Avatar
2018 C63S AMG Coupe, 2019 Jaguar F-Pace SVR
@CRAZYAPRIL I wanted to give a thumbs up for BenzNinja. It takes a little patience to get all the equipment delivered (laptop, SSD, and Starconnect C4) but once you have everything, his set up will do any diagnostic and programming that you need. Plus you'll have the dealer workshop manuals (WIS) for the vehicle which are essential for any work. And the best part is his virtual in-person assistance with any coding or programming work. For example, I called about 4 dealerships and a couple independent shops in my area to get Android Auto working on my car (only came with Apple Carplay) and they all said that it can't be done without buying a new module and possibly head unit / display. BenzNinja was able to program my existing equipment and now I have Android Auto. And if either of your cars have the ILS headlights you will be amazed at how great they work once he activates that programming.
