Turbo blankets
Turbo blankets
Has anyone installed turbo blankets? I'm curious about experience with the hot-v configuration or if there's a concern about overheating the turbine side of the turbos. I had a turbo blankets on my 30R in my STI and it made a huge difference in under hood temps.
2020 AMG GTC Coupe & 2018 Macan Turbo
If you remember the early BMW X5M's, you might remember they were small block V8's (4.4L) with twin turbos mounted inside the V. I understand there have been issues with blown head gaskets and warped heads due to the excessive heat.
Turbo blankets contain heat, acting as an insulator between the turbine housing and the rest of the engine bay... they would help with problems like that. My question is more along the lines if anyone has done it on these engines because I'm curious how well the hot-v configuration (which is what you outline in your post) responds to such a mod.
Nobody? This seems like a particularly good mod for these cars if there's no worries of cooking the turbos... the underhood temps on this car are insane. Maybe I'll just try it out myself.
Heat blankets
The E63 comes with it from the factory and I think some of the GT models as well, Merc uses an adhesive type reflective tape on the hot side which if they are doing from the factory you can be sure it does give benefits
Hey guys, yes we have been working on a blanket for the turbos. They will be available early March. We found 2 blankets to be quite impossible to fit especially for those with larger turbos. Our blanket covers both, it will not wrap around the bottom of the turbo. But testing still found reduced under bonnet temps and further heat shielding.
Cylinder Head (03-31-2020)
700HP Facelift converted PFL C63 S Coupe
I think it would help temps but wonder about that heat building up in heads/etc and causing trouble.
I think a heat extractor on the rear of hood right over the turbos would be interesting but for a DD I wonder if water dripping on the turbos could be a proble.
Or if anyone else has come across ones that will work, would appreciate the help!
I don't get it ... I've felt the hood on my 2016 C63 S sedan when returning to the pits after a 20-min. on-track session (with a cooldown lap) and found that the hood doesn't get any hotter than it would if the car was black and it sat in the noon-day sun. I believe the AMG engineers have considered this issue (du-oh!) and that's why the fan often runs after shutting the car off (i.e., to cool down the turbos, etc.).
Has anybody found that their hood gets excessively hot in the area above the turbos?
I'm sure the engineer's looked into the placement of the turbos and effects of heat dispersion around them, and found that everything was suitable. However, the final production car has had MANY people look over it. Those engineers also work side by side with "the accountants" that cost analyze every single part of a car....and at the end of the day, the final product still does its job. There wouldn't be this huge aftermarket industry if every vehicle was the perfect version of itself.
The Engineering Explained video that references the University of Austin's study on turbo blankets is pretty interesting, if you haven't seen it. From that study, turbo blankets have a noticeable impact on the efficiency of turbos, more so than I thought.
The turbos are simply too close for 2 individual blankets. You have a wastegate actuator in the way too. Our blanket will cover both turbos around the top and down the sides. And still fits under the stock shield. Spool time is hard to measure on a dyno. But heat is inevitably reduced and all that heat is now going out the exhaust and keeping that hot air nice and expanded when you want it. Props to the guy who mentioned "engineering explained" get on YouTube and feel out on that channel!
Actually check our Instagram for a rear bonnet seal hack exactly for this reason.
Testing requests from me...
1. Do you think there is any benefit to removing the rubber seal at the front of the hood? I notice that is the general area where the car sucks up its juicy intake air.
2. Similar vein, is there any benefit to sticking the center air guide open at all times (probably in conjunction with a turbo blanket). Further airflow over the top of the engine would probably cool the rear (intake) side of the turbos even more.
What I did was remove the rubber seal, reinsert it out of the way and then use some gorilla tape to tape the excess to the existing seal that seals up the bonnet. Should work fine unless you have very old rubber seals that are hardened.
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/1500x2000/20200213_213740_li_7d53790b560c4b9764e5b735ec7c391eba199dcd.jpg)
All it does is seal the gap between the hood and the front end? Seems like a more direct route for cold air to get to the intakes to me (rather than around the lower radiators and into the intakes) - with the suction generated by the turbos it just seems to make sense to do this.
I did both mods at once, so I can see how propping that vent open may do nothing (especially because its the hot side of the turbos that face forward. That said, I am noticing betwen 2-3 Celcius lower intake temps generally speaking with those 2 mods done.
