C63/C63S AMG
Rough Idle Issues :(
Old Feb 9, 2020 | 06:14 PM
Haji3978's Avatar
C63s Coupe
Unhappy Rough Idle Issues :(
Hi Guys,
New to the Forum, haven't posted anything up until now.
My car has a rough idle but drives fine even when I push it hard, it has a stage 2 - Down pipes, tune and BMC filters.
I took it to a performance shop and the guy thought it may be the tune so he flashed it stock but the rough idle is still there with factory tune.
Any ideas? Spark plugs? Coil packs? no CEL except the P0420 & P0430 becasuse no CATS.
Old Feb 9, 2020 | 08:36 PM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
Could be plugs as tunes will eat them up .....I'd change those first
Old Feb 9, 2020 | 10:26 PM
Haji3978's Avatar
C63s Coupe
Thanks bud, booked into Mercedes for a change
Old Feb 10, 2020 | 06:26 AM
tekfoc's Avatar
Veteran: Army
18 E63S
Have coil packs checked also
There was a bad batch in the pass
They were all replaced on my car
Old Feb 11, 2020 | 12:06 PM
Stevestil's Avatar
2020 C63S Coupe , 2014 BMW M5
which tune are you running
Old Feb 11, 2020 | 05:59 PM
Haji3978's Avatar
C63s Coupe
Thanks @C3504matic turned out to be one spark plug that was causing the issue - Mercedes replaced it under warranty - idles smooth again!
@Stevestil - Car was tuned by theses guys https://dyneperformance.com.au/ - im looking at getting it re-tuned though - Id lobe to get a DME tune but they are so expensive.
Thinking of going to see Gordi at https://etunersmotorsport.com.au/ - Heard he does some magic for the C63s
Old Feb 11, 2020 | 06:54 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
Easy fix!
Plan B could be to throw a JB4 on top of your existing flash map if you just want to dial it up (or down) a little.
Old Feb 11, 2020 | 08:44 PM
Haji3978's Avatar
C63s Coupe
Not really a fan on piggy back stuff @BMS - I've texted Gordie just waiting on a reply on when I can take it in. In the interim I hope the cat less P0420 & P0430 CEL codes don't cause issue to my engine ...
I've been reading about the different tunes available and the different power outputs - wonder how some tunes are making extra power without getting heat soak hmmm.....
Looks like the DME tune is the most aggressive and most power making tune from what I read
