C63/C63S AMG
C63s 0 to top speed.
Old Feb 22, 2020 | 01:59 PM
fjp63amg's Avatar
2019 C63 AMG S; 2016 BMW 340i MPPK; 2020 Mini Cooper
Still working on the best way to launch it with low wheel spin.
This is the best I got so far.
Dragy results
Old Feb 22, 2020 | 02:08 PM
rbohgan's Avatar
c63s sedan
What app is that? i need that lol
thne i can compare mine with yours. mines a 2015 sedan
Old Feb 22, 2020 | 02:15 PM
fjp63amg's Avatar
Its this
https://dragymotorsports.com
You use it connecting by Bluetooth to your mobile phone. Very easy to use, and you can use it in several cars.
I m still trying to reach the 4s 0-62 MPH. The times could improve 0,5 second.
Old Feb 22, 2020 | 02:19 PM
rbohgan's Avatar
c63s sedan
Originally Posted by fjp63amg
Its this
So its a box you put on dash then phone connects to it too. i was looking at vbox stuff this seems cheaper tho. another birthday present? lol
Old Feb 22, 2020 | 02:23 PM
fjp63amg's Avatar
Yes, a very small box. It s what YouTube Channel Autotopnl uses.
In this video you can see what shows in your phone
Old Feb 22, 2020 | 02:25 PM
rbohgan's Avatar
c63s sedan
thanks! found it on amazon prime for $50 cheaper for me here in canada lol. ordered!! (im such an impulse buyer...)
Old Feb 22, 2020 | 07:25 PM
superswiss's Avatar
2019 C63CS
Not sure if you are aware, but once you have Race Start engaged, you can use the shift paddles to adjust the launch rpm up/down in increments of 100 rpm. I have yet to try Race Start one of these days, but the instructor at the AMG Driving Academy recommended 3200 rpm at least for the coupe. The sedan has less rubber in the rear, so you may wanna try an even lower launch rpm. Also a better tire will launch faster with much less wheel spin. The PS4S is currently the leader in longitudinal grip among UHP tires. It's not the fastest tire around a track, but it beats all its competitors consistently putting down the shortest braking distance in the wet or dry, which also means it'll have the most grip during acceleration. I definitely have significant less wheel spin now that I'm running the PS4S. Didn't even have to go wider in the rear. Just went for my first 200+ mile canyon run of the year today and it's a new animal with these tires. Much more communicative than before and much better road contact. The stock PSS crashed over road bumps and regularly skipped and lost traction under acceleration on less than perfect roads. It was a completely different experience today with the PS4S. Used to have to put the suspension in Comfort mode on some sections with the PSS to keep it on the road, but with the PS4S I could drive the entire run with suspension in S+ and the tires just stayed glued to the road. I'm very happy with the transformation. It was a super enjoyable day today.
Old Feb 22, 2020 | 07:57 PM
fjp63amg's Avatar
Yes superswiss, I am aware. Thanks!!
here in the original video you can see that I used the paddle shifter to lower rpm. Did the launch around 3000rpm.
the tires, for now still are the original PSS. When it s time to change I will see what’s the best solution. I think this tires will still last sometime.
Old Feb 22, 2020 | 10:13 PM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
How do you adjust the launch RPM w/ the paddles ?? ...I had no idea you could do that
Old Feb 22, 2020 | 11:01 PM
superswiss's Avatar
2019 C63CS
Only 2019+ FL models. Pressing the downshift paddle lowers by 100 rpm at a time and pressing the upshift paddle increases it by 100 rpm at a time.
Old Mar 10, 2020 | 09:30 AM
fjp63amg's Avatar
​​​​​​​You can see it in the beginning of the video.
You start the LC, and before releasing the brakes using the paddle shifter you can adjust the rpm, lowering with the downshift or improving rpm with the upshift.
In my case I was spinning a lot with 3500 rpm, and lowered it to 3000rpm. It did 4,64s to 62 mph. I still have to try launching it around 3200/3300.
Old Mar 10, 2020 | 08:56 PM
d4md's Avatar
C63S
Didn't you have 2 more gears to go or did you hit the top speed limiter? I'd also try auto shifting in race mode
Old Mar 11, 2020 | 08:57 AM
fjp63amg's Avatar
Yes, the Sedan hits the limiter in 6th gear. When you see 293/294 you can feel the 290 Km/h limiter.
The Sedan has a very diferent gear ratio than the Coupe.
You can see here a Coupe. In 5th it reaches 238, while the Sedan goes to 250.
PS Sorry guys I m from Europe, I talk in Km/h instead of MPH
Old Mar 15, 2020 | 09:23 AM
fjp63amg's Avatar
Well, another attempt. This time I let the gear do all the job. The results are improving
Almost bellow the 12s mark for the 1/4 mile.
Old Mar 15, 2020 | 09:59 AM
d4md's Avatar
C63S
Have you checked your tyre pressures? Mine came really high from factory and my results improved noticibly after I lowered them
Old Mar 15, 2020 | 10:06 AM
fjp63amg's Avatar
Good point d4md, I have my tyre pressures in the recommended pressure to reach the 290km/h speed. They are high.
When it’s a little bit hotter I will try with lower tire pressure, little gas in the tank, and a few pounds less in my body ( I hope)
Old Mar 22, 2020 | 05:22 PM
rbohgan's Avatar
c63s sedan
Learning how to use the Dragy lol these are my fastest so far. I didn't have the best road. was dust all over it, traction was an issue even with my brand new PS4 295s on rear and i let off gas a bit at quarter mile as road had a bump ahead so had to brake for that a little early. I'll try some more soon! Want to get the best i can possibly do before renntech stage 2 goes on end of this month!
Old Mar 22, 2020 | 07:45 PM
PayKoHan's Avatar
AMG C63S T-Model
Someone have dragy or pgear times with stage 1-2? more interessant (:
Old Mar 28, 2020 | 11:49 AM
LessIsMore's Avatar
2017 AMG C63
https://mbworld.org/forums/c63-c63s-...ragy-runs.html
Old Mar 28, 2020 | 05:48 PM
fjp63amg's Avatar
This RWD cars, have a learning curve.
It’s not like the AWD that do the 1/4 mile almost always the same since day one.
Old Mar 28, 2020 | 06:45 PM
rbohgan's Avatar
c63s sedan
yeah for sure. ill wait for warmer weather to test again. car is getting renntech with downpipes right now
