C63/C63S AMG
Black badges...
Old Feb 24, 2020 | 06:12 PM
japamg's Avatar
Final Edition C63s / RS3 Sportback
Black badges...
Hi guys
What´s the best way to go? Replace all of them or just plasti dip...
You did it on your cars?
Old Feb 24, 2020 | 06:28 PM
magno.amg's Avatar
C63S coupe ed.1
Personally, i think that replacing them is the easiest and cleanest way. Plasty dip is a mess, and it will get all over paint and you won’t be able to get it off. When you replace them they are solid color and the edges won’t peel off while plasti dip will. I believe that plastic will also fade over time. i’ve included a few pics of mine, I replace the badges with gloss black ones.
Old Feb 24, 2020 | 06:52 PM
tobeit's Avatar
AMG C63s
Originally Posted by japamg
Hi guys
Replace hands down - except the chrome trunk strip, which I wrapped as I could not find an aftermarket piece.
Did them all including rear, side, and door handles. With night package no chrome left on my car.
Old Feb 25, 2020 | 06:01 AM
japamg's Avatar
Very nice!
Where did you get those from?
Old Feb 25, 2020 | 07:58 AM
magno.amg's Avatar
C63S coupe ed.1
Very nice!
I actually just ordered them from ebay 😂
They were perfect.
https://rover.ebay.com/rover/0/0/0?m...2F223674528998
Old Feb 25, 2020 | 08:44 AM
japamg's Avatar
They were perfect.
Thanks! 👍🏻
Old Feb 25, 2020 | 08:45 AM
japamg's Avatar
What about matte finish?
Old Feb 25, 2020 | 09:21 AM
gilmdjd's Avatar
2019 AMG C63s coupe
How do you get the factory ones off the car?????
Old Feb 25, 2020 | 11:36 AM
deftronix's Avatar
17 C63S coupe
Dental floss, heatgun and set of nitrile gloves. Fishing line works better than dental floss if you have it. Used painters tape to outline the original emblems so you have a reference for alignment of new ones but still able to clay & polish the area with a buffer before you apply replacements which I highly suggest you take advantage of at the time. Ex - the "C63" emblem does not come with the proper spacing on the backing paper so be sure to use tape to mark where the "C" and the "6" start on the original emblems on the car because you will want to align accordingly if you want it to look factory. Nitrile gloves to save your skin using your fingers with a lot of pressure to roll the remaining adhesive off if you dont want to use googone or some other adhesive remover on the paint.
Did mine last week..
Old Feb 25, 2020 | 01:17 PM
magno.amg's Avatar
C63S coupe ed.1
Looks nice! I think that may be the wrong a badge though.
Old Feb 25, 2020 | 01:29 PM
SandSnip3r's Avatar
2021 E63s Sedan & 2019 C43 Coupe
They're just held on by adhesive on all models?
What did you do for the star?
Old Feb 25, 2020 | 01:31 PM
SandSnip3r's Avatar
Did you have to remove it to wrap it? If so, what was that process like?
I'd love to see how the handles look. Did you do the inner part of the handles also? Do you still maintain that touch functionality for locking/unlocking?
Old Feb 25, 2020 | 01:40 PM
deftronix's Avatar
17 C63S coupe
Thanks. Realize its the facelift "S" but like it better, haha. Plus I run the panamericana grill and will probably get the new diffuser and tips down the line. On another note anyone know where to get the upper chrome door handle replacement covers? Want to strip them and get them color matched.
Not sure on all models but most likely. Was on mine.
Heated it up very carefully keeping in mind that heat was getting to the camera and plastic behind the back side seams and slowly working floss around the outside. There are 3 grommets that fit into holes in the middle so you cant work the floss up/down all the way through you have to work your way around.
Old Feb 25, 2020 | 03:01 PM
tobeit's Avatar
AMG C63s
Trunk strip - no, you don’t have to remove it to wrap it. Btw, I did not paint it as paint does not adhere well on chrome surfaces
Door handles - the chrome is still a little bit visible when looking close up as the covers don’t fully wrap around. But not noticeable. Yes, touch still works fine.
Btw, on the sedan the star on trunk is held with 3 small screws and to properly remove it you need to take the trunk lid liner off. All others are just taped.
Old Feb 25, 2020 | 07:27 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
Do you have the tilting star with hidden camera? The 2020 does and I cannot get that star to budge one bit with even a heat gun.
Old Feb 25, 2020 | 07:56 PM
tobeit's Avatar
AMG C63s
not sure who are you asking but my star is not tilting. It’s a coupe thing?
Old Feb 25, 2020 | 09:26 PM
deftronix's Avatar
17 C63S coupe
Yes, I have the tilting star. It is the hardest emblem of the bunch to do. Really recommend using floss while heating up the emblem to work your way around and through the adhesive. As you can see by the picture below there is only adhesive around the ring of the star with 3 guide pins in the center.
Old Feb 25, 2020 | 09:32 PM
///Bruce's Avatar
Thanks. Looks like it's gonna be a struggle.
Old Feb 26, 2020 | 09:17 AM
magno.amg's Avatar
C63S coupe ed.1
the same process as a gloss but just have to be more careful and cant use any gloss detail sprays.
Old Feb 26, 2020 | 09:19 AM
magno.amg's Avatar
C63S coupe ed.1
This happened to me too, I have the coupe so you have to remove the little backing plate. You then have to pry the star off with something. I used a plastic tool.
Old Feb 26, 2020 | 12:32 PM
SandSnip3r's Avatar
Does anyone know of a guide to get to this? Or at least some parts lists so that I can see where the different clips are and such?
Old Feb 26, 2020 | 01:40 PM
Encore818's Avatar
2019 C63S Coupe, 2020 G550
Be SUPER careful.
I tried doing mine on my magno paint and it was painful.
You have to be more careful about the products you use to remove the remaining adhesive. The chemicals strong enough to remove adhesive may be strong enough to damage your matte finish as well.
Also the star is the biggest pain in the ***. I ended up needing to use some tools to wedge it up and remove it from the piece its on, and ended up scratching the matte piece. Had to get it repainted.
Old Feb 26, 2020 | 01:58 PM
deftronix's Avatar
17 C63S coupe
You don't have to remove the backing plate. Was able to do it with the method I listed above.
Originally Posted by Encore818
Be SUPER careful.
Don't use anything to pry the emblems. Floss and heat should be the only thing you need and wont have any chance of scratching the paint. Others replying should read my posts above more carefully. Cant help as far as the sedan mounting screw access though.
Old Feb 26, 2020 | 02:31 PM
Encore818's Avatar
At the time my car was only a few months fresh from the factory. The adhesive was ridiculously strong. I see your car is a few years old, maybe it has something to do with it?
With a lot of effort I was able to floss the other badges off, the star was the only issue. Even with all the adhesive removed I had to use a very fine screwdriver to push out the three grommets from the back of the plate.
Sounds like you were able to pull the grommets out without removing the plate. Either they changed the grommets on the facelift or with time things were just looser on your car.
Old Feb 26, 2020 | 03:42 PM
deftronix's Avatar
17 C63S coupe
Car only has 14K and was garage kept so not sure. The newer the less time it takes in my experience because its not all dried out and flaking everywhere but you're right in that it can be stronger. A steamer can also help in that situation.
Once I had the adhesive cut through around the whole ring I used floss to work it behind the star where the guide pins/grommets are and wiggled back and forth until the star came up enough to be able to pull it off. All the grommets stayed in during the process.
