C63/C63S AMG
W205 C63 Downpipe kit - ECONOMICAL OPTION
Old Aug 10, 2020 | 03:52 PM
  #101
SJGetsome's Avatar
W205 C63 AMG Coupe
Originally Posted by FLC63s
I was gonna say the same thing, but didnt want to shove my foot in my mouth...
Haha. Although I'm no stranger to shoving my foot in my mouth, I'm pretty confident on this one. If a "mini cat" that size would be capable of doing the job of the OEM sized converters, there would be no need to make them that big in the first place.
Old Aug 11, 2020 | 11:09 AM
  #102
imedina86's Avatar
AMG C63s, e70 X5M, 335i,AMG glc63
Originally Posted by imedina86
Im in the process of installing these DPs, everything was going smooth until it came time to remove the stock DPs and find a way to snake them out, it was a pain. The driver’s side one gave me the most issues since the steering column is in the way. All I can suggest for people that are going to do this is when you are cutting the stock DPs from the bottom cut as high as you can after the secondary cat.
The bracket that the DPs are connected to is also dumb, i had to take off screws from under the car.
I finally took the stock DPs off, now im stuck getting the driver’s side catless DP installed, the steering column is in the way again, i know i just have to keep on playing with it and it will eventually go through just a pain.
That was all yesterday, after I get home from work ill try again. In my opinion if snaking the DPs in and out wasn’t a pain this would be an easy job. But I would rather be going through this than paying someone $700 to do it for me lol
I purchased two of these http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html to help with the CEL, ill let you guys know if they work once im done
Well DPs installed, went on a 15min drive and so far the defoulers are working, no cel, love the sound the DPs gave the exhaust, first time I dont hate my blink cams lol
Old Aug 12, 2020 | 10:02 AM
  #103
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
More sets will be in stock on Friday
Old Aug 12, 2020 | 12:56 PM
  #104
shardul's Avatar
Old Aug 18, 2020 | 11:51 AM
  #105
shardul's Avatar
Back in stock
Old Aug 20, 2020 | 09:54 AM
  #106
shardul's Avatar
View this post on Instagram
Old Aug 27, 2020 | 04:20 AM
  #107
C63_KB's Avatar
2019 C63 AMG
Purchased OP's downpipes from another user.
Did you ever get the driver side downpipe in? What did you do?
I did this job today and and got to the part of installing driverside downpipe in - It won't fit. From the top. From the bottom. With the steering shaft disconnected.
OP - how do I accomplish the install without taking it to a shop to fix my half completed job?
I ended up re-installing the cut in half stock downpipe on and the aftermarket passenger side on.
I'm pretty angry at myself for letting my car defeat me.
Old Aug 27, 2020 | 08:41 AM
  #108
imedina86's Avatar
I installed the drives side DP first from the top, after struggling for hours and noticing i only needed a tiny bit more space to get it through the drive shaft I decided to "massage" (hammer) in the area where it was hitting the shaft, it wasn't much, i was able to get it through, then i just bent it back into place with pliers (no exhaust leak). The passenger side was easy just went in without struggle.
Old Aug 27, 2020 | 08:52 AM
  #109
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
I am wondering why the OP @shardul has NOT chimed in on this..
From what I have seen/read on other DP installs, I dont think it should be this difficult, more so if you CUT the stock ones out.. (I have hear from some that have dropped the trans, etc , and that was a Major task, but by no means
should you need too be beating on items and then trying to bend back for a installation.. (IMO)
Old Aug 27, 2020 | 09:43 AM
  #110
shardul's Avatar
Person posted at 3 AM give us time time to review the post
As imedina36 said start from the top and snake it down. Steering shaft has to be disconnected.
Old Aug 27, 2020 | 09:50 AM
  #111
FLC63s's Avatar
well actually this started back on : 08-10-2020, 11:41 AM :
and with a post from @imedina86 , he never mentioned disconnecting the Steering Shaft, just that it was in the way..
I would have assumed that if you saw that post back then, you would have made a comment or statement to the people whom purchased afterwards that "disconnecting the steering column is required/recommended)
But hey, I dont have a dog in this fight, as I dont have your dp's ... so it was merely an observation on my part.
Old Aug 27, 2020 | 01:27 PM
  #112
C63_KB's Avatar
2019 C63 AMG
disconnected steering shaft. Didn’t work. The bend was still hitting heat shield/fire wall. Gave up and put the cut stock downpipe on.
A shop told me the subframe has to be removed.
There aren’t any guides out here or pictures.
Old Aug 27, 2020 | 02:04 PM
  #113
Rochviper's Avatar
2017 C63S AMG Coupe
If you read up the thread, I provided some pics of my install and where the stock downpipes were cut. I can assure you the subframe does not have to be removed.
Old Aug 27, 2020 | 02:07 PM
  #114
C63_KB's Avatar
2019 C63 AMG
That’s not my experience.
i couldn’t get the pipe through the top. I couldn’t get it from the bottom. It wouldn’t fit either way. Are the compartment spaces different on a 2019 C63?
Old Aug 27, 2020 | 02:09 PM
  #115
FLC63s's Avatar
Maybe there is a diff between the year models ....
Old Aug 28, 2020 | 05:24 PM
  #116
Encore818's Avatar
2019 C63S Coupe, 2020 G550
Is a full tune required to run downpipes? Or can a tuner knock off the single code?
Old Aug 29, 2020 | 10:43 AM
  #117
shardul's Avatar
Tuner can leave the OEM file and turn off the monitoring of the secondary O2
Old Sep 2, 2020 | 11:09 AM
  #118
shardul's Avatar
4 sets remaining in stock
Old Sep 4, 2020 | 02:07 PM
  #119
CCMoney's Avatar
2018 C63S Coupe
Entertaining the idea of GESI DPs or similar high flow DPs. Can you let me know what these will run if you have any? Thanks!
Old Sep 10, 2020 | 09:32 AM
  #120
shardul's Avatar
3 sets left in stock
Old Sep 21, 2020 | 10:25 AM
  #121
shardul's Avatar
Another C63 getting some downpipes installed
Old Sep 22, 2020 | 11:38 AM
  #122
shardul's Avatar
Old Sep 22, 2020 | 02:04 PM
  #123
randlelwa's Avatar
A205 C63s Convertible
Do these fit the a205?
Old Sep 22, 2020 | 02:20 PM
  #124
shardul's Avatar
only fit W205 C63 LHD
Old Sep 29, 2020 | 11:01 AM
  #125
shardul's Avatar
10 more kits back in stock.
