C63/C63S AMG
Catted DP’s installed on 2020 C63 Coupe
Old Feb 11, 2022 | 05:35 PM
  #251
LBCWT's Avatar
'18 Mercedes-AMG E63S
Just had some ModalWorks catted DPs installed on my 17 and it's perfect!
Crisp snaps and cracks.
Old Apr 12, 2022 | 06:46 AM
  #252
noremaC's Avatar
17 C63S Coupe PTG1000
Reviving this thread. What are the monitors for emissions testing that need to pass? I’m sure it’s specific state to state, county to county, but typically? Is it “Catalyst”, “Oxygen Sensor” or “Heated Catalyst” as well?
I am catless with a tune, so no CEL.
Old Apr 12, 2022 | 10:24 AM
  #253
domjansson's Avatar
C63 amg edition 1
Originally Posted by AlexZTuned
Great results for no tune and just HFC downpipes, makes me want a set 👍
I made 425whp stock on dynojet that seems pretty accurate
Old May 1, 2022 | 03:58 PM
  #254
Bemads's Avatar
C63S Amg
I have 200 hi flow cats and the bigdaddy spacers and once in awhile the p2099 cel comes on. Anyone else have this happen to them? I think I’m just going to get a tune. But with that I might as well go catless
Old May 7, 2022 | 12:03 PM
  #255
Realbenz's Avatar
C45 amg
Catted 👍 yo
Old Jul 24, 2022 | 10:55 AM
  #256
dreupnu1's Avatar
AMG C63s and E300
Kinda disappointed
Originally Posted by elitex
Just picked up the car after getting the DP’s installed. Three words OMG! Pops, crackles on downshifts cracks on up shifts. It’s all there, loud and pronounced. Close the valves and put it comfort mode and it’s close to stock.
Remember that no tune is involved.
Absolutely worth every penny! I also did a dyno just to see. Picked some power and torque.
I just had this past Saturday downpipes cut it and start from logos engineering also a Euro charge stage 2 with wise take vTA's blow off valves. I noticed an increase in power but it takes a while for the boost to engage I have to really step on it I guess the most disappointing part is that I'm not getting the sound that I thought I would / crackles and pops only time that I hear it except I'm really up into RPM range and by that time I'm breaking the speed limit LOL I'll be reaching out to my tuner and Euro charge to see if maybe I need to add air intake filters or something else needs to be done I have a 2020 c63s amg. Or maybe do I have to wait till the downpipes actually break in but they are high flow catted
Old Jul 24, 2022 | 11:24 AM
  #257
SilverBullet18's Avatar
C450,GLC 63,VW GTI
The fl c63 and c43 I believe both have CPC modules that limit stuff. Since you have a FL, did you also get your CPC tuned as well?
Old Jul 25, 2022 | 09:49 AM
  #258
dreupnu1's Avatar
AMG C63s and E300
No I didn't, for the price I assumed it would have been included but after doing some research it appears that its an addition 2000.
Old Jul 25, 2022 | 10:11 AM
  #259
C450,GLC 63,VW GTI
That may also have to do with it- if you unlocked new found power especially in the lower rpm range, the CPC may be keeping it in check because it's programmed to do so. Not letting you reap the full benefits.
Old May 28, 2023 | 06:12 PM
  #260
W140King's Avatar
W140 S320
Which version of the HJS 200 cell dps did you end up going with? 121mm or 130mm? Redstar says you shouldn't get a CEL with the 130mm version of the HJS cats.
Originally Posted by BrianShaw23
Good to know, I was considering using the bigger o2 sensor restrictor from Fabspeed, the one with a small built in cat but I'll try the smaller one Red Star is sending me. I was surprised too and I think you're right, MB is making their cars more and more sensitive and strict. I did some research and I found out that the way the dps are built and the position of where the o2 sensor attachments are placed on the dps makes a difference whether or not you get a CEL with HJS 200 cats or not. Fabspeed and Renntech both apparently redesigned some of their dps to fix this issue. So it could be that for the Red Star dps.
Here are my Red Star HJS 200 cell dps with heat shielding:
Old May 28, 2023 | 07:10 PM
  #261
C450,GLC 63,VW GTI
I still think the 400 cell GESI won't cause a cell. Its heavily loaded with precious metals and have a no cell Guarantee and is EPA certified
Old May 28, 2023 | 07:12 PM
  #262
W140King's Avatar
W140 S320
Yes but I'm asking about the 130mm HJS 200 cell cats. They are listed on Redstars CEL free guide but I wanted to see which HJS 200 cell cats Brian had.
