Things that Rattle in our Cars
The First: The Rear View mirror cover was removed, apply fabric tape to all contact points and spray MB special sliding compound lubricant to all points. The rattle is still there as it comes and goes depending on road conditions. The next time I'm at MB Dealership I'll ask to have them replace the Rear View Mirror cover.
The Second: Rattle from right corner of passenger dash. MB replaced rubber seal for wind-up window right roof frame replaced.....Right front upper door seal was deformed. Replaced right front upper door seal. This seemed to have fixed the rattle from this area. Been over a month and no rattles.
Attached Invoice shows what work was done and hopefully can help others with similar rattles issues in these areas.
Next rattle I need to tackle is the the trim/headliner that the passenger side seatbelt is coming out of (so not the seatbelt actually hitting the AMG seats which have plastic sides).
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Alignment was because I just replaced all four tires and the place that did the tires doesn’t do alignments.
Anyway, I drove home on the crappy roads in sport+ mode with the top up just to make sure there were no more rattles so I’m happy. They didn’t clean the inside of the windshield though and there are smudges all over it on the inside.
While it did not drive me crazy I did want it corrected.
After taking all the steps listed on the Invoice (3 photos) below it was determined the rattle was coming from the drip rail passenger side roof . The part was replaced and aft er r another test drive by the AMG Tech. stated no more rattle.
SA stated that if rattle continues the next step would be removing the Headliner and would need the car for 2 weeks.
After driving for 5 days , 4 days were void of any rattles and none from the rear view mirror area. NYC area roads.
Also, while at Dealership had 2 software updates performed for 2019 C63s coupe.
Let see what. The car runs great.
Those with rattle issues can see the process the Tech did. Note photos are out of sequence.
did.
So, if you have a constant dash rattle you might check your strut tower bracing to see if that is the cause.
