DME ST2 Dyno Results
- My car: 2018 C63-S with 13k miles.
- Conditions (if anyone cares): 91F, 43% humidity.
- With the downpipes on, but no tune, the car made 512rwHP.
- With the downpipes on, and the tune uploaded, the car made 574rwHP and 650TQ.
Much love to the guys at DME.
I am either missing something big (not impossible) or that dyno needs a calibration. Typically Stage 2 tunes get us into the 520-530 range on the wheel.
I am either missing something big (not impossible) or that dyno needs a calibration. Typically Stage 2 tunes get us into the 520-530 range on the wheel.Trending Topics
. I am particular impressed with the gain at low RPM...increasing boost that low down has that much impact, is that real? I asked the same on a different thread where Renntech also shows those huge gains at low RPM (I run Velos and their curve does not separate until about 3000).
. I am particular impressed with the gain at low RPM...increasing boost that low down has that much impact, is that real? I asked the same on a different thread where Renntech also shows those huge gains at low RPM (I run Velos and their curve does not separate until about 3000).This was strictly a “let’s slap these downpipes on with the DME stage 2 tune and see what happens” kind of thing. The car is much louder, it doesn’t have any traction in 1st/2nd, and sounds amazing under load. The TQ increase on the low end is very real, and extremely noticeable.
I’m perfectly happy with how it turned out. When the loudness gets annoying, just silence the exhaust, and it quiets it a good bit.
I think Dynapack is known to be 8-10% higher. A reputable shop in Santa Ana explains them below. This just means not to read these numbers as baseline to others.
Did OP take off their wheels for the dyno run?
From the website:
With the Dynapack (my favorite), you remove the rear wheels, attach the hubs of the car to the "pods", and make your pass.
The load is simulated on the car via a hydraulic pump. Because these are effectively inertia-less, they will read HIGHER than the standard Dynojet numbers by 8-10%. That number will vary depending on how "fast" your dyno run lasts (sweep time), but as a rule of thumb, they'll read ~8-10% higher. So with this dyno our car will now read ~109rwhp on average.
The pods are always red, but these are easiest to ID. If they are taking off your wheels, it's a Dynapack!"
