C63/C63S AMG
High flow intakes can cause issues when not tuned?
Old Aug 7, 2020 | 10:09 AM
tobeit's Avatar
AMG C63s
I have a quick question. My car is in for B1 service. I removed my tune but kept the high flow K&N filters in (will be replaced with open cone soon). The technician pointed out that they have seen issues in the past with customers using these high flow filters but no tune that it has caused melted pistons .. but then said if car is tuned it should be fine. I asked to explain some more how some more air can damage a none tuned car...but wonder if anybody has every heard such a thing. Seems BS to me...
Old Aug 7, 2020 | 10:29 AM
sinister.c63s's Avatar
2020 s63 amg............2018 e63s amg w213............2017 C63s Coupe W205
lololololololololololololololololololol ahahahahahahahahahahahahahahahahhahahahahahhahaaha NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOO
Old Aug 7, 2020 | 11:28 AM
SJGetsome's Avatar
W205 C63 AMG Coupe
Sounds like he was trying to get you to admit to a tune in order to flag your car and void the warranty.
Old Aug 7, 2020 | 11:42 AM
Jimmy_c63s's Avatar
Melted pistons haha 🤣
Old Aug 7, 2020 | 11:52 AM
AlexZTuned's Avatar
2017 Porsche 911 C4
Drop-in filters with the OEM box? Yea no, that’s not gonna do a thing. When I had my large B service done, they removed my BMC drop-ins and replaced with new OEM paper filters - they put the BMC’s in a box in the trunk (they know they‘re valuable and reusable). No questions asked, they just did everything they needed for service (oil change, trans flush, etc.).
Old Aug 7, 2020 | 12:14 PM
tobeit's Avatar
AMG C63s
Thanks, yes, I also think its BS but because I never heard such a weird thing wanted to ask if anybody came across something even remotely similar.
Old Aug 7, 2020 | 12:15 PM
tobeit's Avatar
AMG C63s
Yeah, came to my mind too. But did not fall for that trick if that what it was. I countered with .."oh, how many tuned once have you seen?" ...so far crickets.
Old Aug 7, 2020 | 12:17 PM
skratch77's Avatar
2005 E55
The tech is 100% right. Oiled filters on cars do cause problems down the road. The oil coats the maf sensors and throws your fuel trims off.
Not sure if our cars use maf sensors or only map sensors but the tech is right.
Nobody uses k&ns on the 6.2 c63 because of this .
Old Aug 7, 2020 | 12:47 PM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
Second thats... looks like he just wanting to ask if its tuned or not.. lol
Old Aug 7, 2020 | 01:25 PM
tobeit's Avatar
AMG C63s
We have MAP sensors if I am not mistaken...well, good thing is my ZAC intake is on its way with a dry open cone filter.
Old Aug 7, 2020 | 01:36 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
No MAF sensors on the M176/M177/M178.
Old Aug 7, 2020 | 01:40 PM
skratch77's Avatar
2005 E55
Good to know! As oiled out flow everything
Old Aug 7, 2020 | 01:59 PM
skratch77's Avatar
2005 E55
Is this not a maf sensor?
Old Aug 7, 2020 | 02:04 PM
IvanC63S's Avatar
2016 C63S
No. It's an air filter quality sensor.
Old Aug 7, 2020 | 02:20 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
Time for a new mechanic!
Old Aug 7, 2020 | 03:15 PM
tobeit's Avatar
AMG C63s
yeah, not really my choice who works on the car when doing standard service...
Old Aug 7, 2020 | 04:20 PM
LessIsMore's Avatar
2017 AMG C63
It always amazes me how master technicians who are ASE certified and can tell you about how any oem mechanical system works on the car, can be so clueless when it comes to after market and performance aspects. Just because they know the car/engine does not mean they have a clue when talking about tunes, filters in this case, etc.
Most technicians nowadays do not have to be good at analysis, they just run scans and do what the machine and computer tells them.
You should be 100% fine running filters on a factory tune.
Old Aug 7, 2020 | 04:31 PM
ansonkk1's Avatar
2019 C63S Coupe
Anyone know if it would be fine to leave the ZAC intakes in during service?
Old Aug 7, 2020 | 04:39 PM
LessIsMore's Avatar
2017 AMG C63
It might be fine, but you will probably get a note made in the Tech department about your car or on the service record for any dealer to see. No good could come from it. Considering how easy the intakes are to put on, I would spend the 10 minutes and re install the factory and takes just to be safe.
