C63/C63S AMG
Are NEW Caliper Bolts required when removing Calipers?
Old Sep 1, 2020 | 02:04 PM
TexasBenzBandit's Avatar
2017 AMG C63, 2001 C5 Corvette
I read Caliper Bolts are Single Use and you should replace with a NEW Set if the Calipers are ever removed? Is this correct? Or is it OK to reuse the existing Bolts?
Old Sep 1, 2020 | 04:31 PM
user33's Avatar
That is correct. Furthermore, there's a specific method of tightening, depending upon the bolt type. Normally it's a pre-torque, then another turn through so-many degrees of rotation. It is something you want to get correct, according to your car's VIN.
Old Sep 1, 2020 | 08:16 PM
I appreciate it, but not sure I'd be able to do the specific method of tightening unless I can find that procedure somewhere. I likley will find the Torque Specs for the Bolts and that should be good enough, but appreciate the INFO!
I am asking because I am getting my Calipers PowderCoated and want to provide New Caliper Bolts and a Rebuild Kit to the place doing it. Sometimes you have to help people help themselves and make it easy for them to do it RIGHT unless you are at a Mercedes Place that knows their stuff....
Old Apr 5, 2021 | 10:00 PM
GunDriver's Avatar
2009 C300 4matic Sport
Torque spec
Its a German car so German torque. Guttentite! 🤣 Just kidding...
Old Apr 5, 2021 | 10:12 PM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
Most bolts on the suspension and braking system as one time use .... at the dealership we always change them but then there are lots of guys out there that do not
Old Apr 6, 2021 | 10:43 AM
sinister.c63s's Avatar
2020 s63 amg............2018 e63s amg w213............2017 C63s Coupe W205
I removed mine to paint them. Didnt replace any hardware and have had zero issues.
Old Apr 6, 2021 | 10:54 AM
Jimmy_c63s's Avatar
Where did you read that from? 🤔
I've done the brakes three times since new on my C63s Coupe and have never changed the caliper bolts. No issues what so ever in 45,000 miles. Ever.
Old Apr 6, 2021 | 11:06 AM
SJGetsome's Avatar
W205 C63 AMG Coupe
For what it's worth, I recently changed my rotors and pads and only the rear kit came with new caliper bolts. The front re-used the existing caliper bolts.
Old Apr 6, 2021 | 04:14 PM
user33's Avatar
For the approx. $4-6 x2 bolts, I wouldn't risk it. Brakes are pretty fundamental safety items and these cars are heavy. Engineers spec'd the one-time use for a reason.
Old Apr 6, 2021 | 07:45 PM
LessIsMore's Avatar
2017 AMG C63
I have replaced the brakes on countless cars and never change the caliper bolts. But ... if the ones on this car are one time use bolts then yes you should, because after the 1st tighten/loosened, they will never hold the right torque again.
Old Apr 7, 2021 | 11:15 AM
Ftpohyeah's Avatar
GLC 63
Is this true also for the GLC 63?
Im taking delivery soon and will be changing caliper colors.
Old Apr 7, 2021 | 12:49 PM
ModalWorks's Avatar
SPONSOR
W205 C63
I agree with this statement. One time use bolts are generally "torque-to-yield" meaning the torque spec plus the additional rotation requirement permanently elongates the bolt. After this initial yield, the bolt will never be as strong as the first time use. This method is used in a bunch of different industries to guarantee a sufficient clamp load. If you are reusing the bolt, I would not do torque to yield again, as you will increase it's length again and further weaken it... which could be big trouble.
I'd personally get the new bolts, especially if you are upgrading something on the braking system and plan to add even MORE abuse than what the factory system came with.
Old Apr 7, 2021 | 01:02 PM
chassis's Avatar
2017 GLE350 4MATIC
WIS is the source for documentation that caliper bolts need to be “renewed” after removal.
Old Oct 28, 2023 | 08:37 PM
dmoneymaker's Avatar
2020 AMG C63S
2020 AMG C63S Coupe: Per WIS, it looks like the M12 bolts (2 below) are not torque-to-yield, however, the M14 bolts are. It looks to me like WIS indicates that the M12 bolts/screws should be removed for purposes of removing the calipers. That said, I plan to replace the M12s with new ones.
Old Oct 29, 2023 | 04:11 PM
koifysh's Avatar
2007 E350
Did not know that! What else in the suspension is one time use? Or is this the only one
Old Nov 6, 2023 | 07:46 PM
Spicywolff's Avatar
18 c63 s sedan
on our Vett the lower shock bolts are. Not sure about MB, but I could see it also being TTY
