Knock Limit Exceeded - Check Engine Light
So just to make a long story short. I drove my car on comfort and the check engine light went on. I went to my mechanic and ran the OBD Handheld and it stated knock limit has exceeded on multiple cylinders. Now this is the second time this has happened to me and I had my mechanic reset the Check Engine Light. It happened twice in my car's lifetime and they were about 3-4 months apart from each other when the check engine light went on for the knock limit exceeding. My car currently has stage 1 DME tune and Catless downpipes. I contacted DME and they told me this issue isn't common with C63's with the same tune.
I just recently replaced the spark plugs to NGK's.
I was talking to my mechanic, DME, and some of my friends about this whole situation and we are all almost positive it's because I let the car go pass a 1/4 of a tank of gas. The check engine light did come on when my car was 1 bar left of gas in the dash.
Can anyone chime in to help solve this issue?
if you had bag gas or incurred bad gas , that would cause the knock etc. but i have run my tank down to it slurping for every oz.
no issues.
i as well dont fill my car up until its near empty (50 miles etc) more so out of laziness ..
no issues.
I just can't figure out what would cause this because I only put Chevron, Mobil, or Shell in my car (Premium 91). I asked if my car was tuned for Cali 91 gas and DME said it was.
And then some people wonder why, we get frustrated when people ask questions and think we somehow can just magically know all the details.
I saw a thread on here about were all the "POSTS" have gone etc, and this is part of the problem, for the OP to make QUESTION he did, is 360 degrees from what is actual issue is.
I guess some people dont realize that , like myself dont work here, nor get paid to read post, or reply or to research to try and assist.
The reason I do it, is because when I did have a question before, there were people that helped me out alot, and I thought that "wow" if this person took the time to help me, then at least I can pay it forward and help as well.
But then you get questions like " My car makes a noise, whats the problem ? " -
Hey OP, why wouldnt/didnt you just copy and paste the more detailed question from your OTHER AMG group, so atleast we had the info ? (just curious)
1) more garabage etc at bottom of tank, and risk clogging or bad gas
2) If your running a heavy tune/mod , and you get "less" gas or run dry on a pull, you can get engine damage from it
3) on WOT , and drag pulls etc, the g's will push the gas around enough, that if you are low on fuel, then refer to #2 above.
But yes, your post here definitly was confusing to most, as that crucial part was left out :-). hope your whip is all good now, and no more issues....
She runs normal as of now.
