C63/C63S AMG
OEM M177 Intake Mod
Old Nov 1, 2020 | 08:32 AM
Dany1337's Avatar
W205 C63 AMG
OEM M177 Intake Mod
Hey Guys,
i am currently modding the oem intake. A colleauge of mine hast already made huge measureable improvements by cutting a hole in the bottom of the box in a special place (constantly 0.2 sec faster 100-200 kp/h on Stage 2! = that means about 18-20 hp)
Now we try to get our the max. of the oem Intake. I did on my own Carbon Fiber intake spacers (see picture). But in the upper part of the airbox there is a strut in the middle above the air filter. The upper part of the intake is already
so thin that i think, removing this strut would help a bit for the airflow. Did anyone of you already removed this strut? (see picture 2) The only thing i worry a bit, that the strut is need for stability, that the plastic does not wrap because of the heat. What do you think, can i remove the strut?
Old Nov 1, 2020 | 09:28 AM
skratch77's Avatar
2005 E55
So what hole are you talking about?
Old Nov 1, 2020 | 09:45 AM
Dany1337's Avatar
W205 C63 AMG
Problem is that the OEM intake is so restrictive that at high rpm there is a negative pressure in the intake. By adding a hole it can take air from the enginge compartment.
if anybody now says: "hot air comming into", that does not matter at all. The m177 has water cooled intercooler wich cool down the air perfectly. And the construction of the m177 is a "hot V", so all the heat is inside the V and the airboxes are outside. but that is a other theme i will explain soon here in the forum. I am just new here.
My Question is, if the intake get unstabel by removing the strut.
Old Nov 1, 2020 | 12:53 PM
PaulC63s's Avatar
PFL C63s EC Stage II
I think it should be fine 🤷‍♂️ . Where did you make that hole? I might try it.
Old Nov 2, 2020 | 05:46 AM
answer223's Avatar
w205 c63s
interesting...
Old Nov 2, 2020 | 07:26 AM
Jimmy_c63s's Avatar
Im in
Old Nov 2, 2020 | 07:37 AM
PaulC63s's Avatar
Originally Posted by Jimmy_c63s
Im in
I will take mine apart when i have a chance. I'm guessing the hole has to be drilled somewhere pre filter
Old Nov 2, 2020 | 07:46 AM
Jimmy_c63s's Avatar
Sweet. I wonder how big the hole has to be? And how many holes?
It should be a size that can be able to be plugged up again too with a rubber grommet in case.
Old Nov 2, 2020 | 08:06 AM
PaulC63s's Avatar
Got this pic from a google search it seems like the m177 intake already has holes in it. I guess extra one won't hurt
Old Nov 2, 2020 | 04:19 PM
user33's Avatar
Originally Posted by Dany1337
... if anybody now says: "hot air comming into", that does not matter at all. ...
These people have done research, measurement and development that shows the under-hood temperatures DO matter:
https://www.eventuri.net/products/me...c63s-amg/#tab5
Don't get me wrong, I think that kind of expenditure for that small amount of horsepower should only be done after other mods that have a much better "boost per dollar" ... but I you're "going all out" ...
Old Nov 2, 2020 | 05:03 PM
ModalWorks's Avatar
SPONSOR
W205 C63
Most of the gains come from increasing the cross sectional area post filter. As long as all the air is flowing through the pancake style OEM tube you will be severely limited.
Old Nov 4, 2020 | 07:48 AM
Dany1337's Avatar
W205 C63 AMG
Sorry but you are wrong. First of all in the clip of eventuri you can see what i said, the enginge is pretty hot because of the "hot v construction" and outside the enginge the temperatures are low. So i dont unterstand how you want to refute my argumentation with this?
And 2nd even if the whole engine compartment would be hot if would say nothing on a picture with a infrared camera. You need to log the temperature after the air intercooler. Once with closed intake system then with open intake system. And if there would be siginficant changes you can say anything about it is good or not. After the air intercooler there is less then 1°C difference. The eventuri system is well known, but not worth the money.
Ofc you are right, intakes without the pancake style tube are better. But here in Germany you cant get "TÜV" on these, so it is not legal to use them.
But i have to contradict your first Statement. There are some restrictions in the OEM Intake, that is true. But the all biggest restriction is before filter and not after! The area under the filter is not big enough and because of this, there is a under pressure at high rpm. And that is the most hardest restriction in this system. That has already been logged and verified by some serious tuners and developers. If you can can solve this, you can get huge gains of hp. If the filter gets enough air, the turbos will soak it even through the thin oem upper intake tube. But of course a bigger tube to the turbos will also help. Here in Germany most of the guys use the OEM intake system with BMC Filters up to 800hp.
PS: I will pm you for your downpipes. I saw you are shipping to germany.
Old Nov 4, 2020 | 07:54 AM
Dany1337's Avatar
W205 C63 AMG
Old Nov 4, 2020 | 08:00 AM
PaulC63s's Avatar
@Dany1337 Can you share what you did?
Old Nov 4, 2020 | 08:08 AM
Jimmy_c63s's Avatar
Agreed. Where's the hole and where's the pics! 🥱
Old Nov 4, 2020 | 08:17 AM
PaulC63s's Avatar
Someone on facebook groups posted this
Old Nov 4, 2020 | 08:33 AM
Jimmy_c63s's Avatar
Christ! That's terrible.
Old Nov 4, 2020 | 09:14 AM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
Old Nov 4, 2020 | 02:16 PM
user33's Avatar
Sorry but you are wrong. ...
... You need to log the temperature after the air intercooler. ...
Prove it ... post some real data. FYI, intercoolers are not "absolute" ... they only reduce the air temperature. Feed them hotter air and you'll still have hotter air going into your engine.
If you do some searching, you'll find that there are aftermarket intercooler radiators that improve the M177's intercooling ... which implies that the stock intercoolers could do better even with the outside-the-engine-bay air.
Old Nov 5, 2020 | 08:37 AM
Dany1337's Avatar
W205 C63 AMG
Only because upgrade intercoolers are sold they are not necessary There is so much crap you can buy in the internet that does absolut nothing. Just to bait people to spend their money. On road use the stock intercoolers are more then enough.
So because so many asked here are some Picture:
1. Mods
  1. Removing the strut in the upper part of the intake
  2. Using bmc air filter (they are the most flat)
  3. 21mm intake spacers
  4. Holes in the front and on the outside of the intake (away from the enginge)
  5. A little hole in the bottom.
2. Results
  1. heavy suction noise (you can hear inside the car, how the enginge breath. really sick!)
  2. throttle response is way more agressive
  3. And the most important thing: Yes, it makes the car faster! Especially if you are on full throttle and high rpm (5000+)
  4. 100-200 km/h you can see impreovements of 0.25 - 0.3 sec compared to only BMC Filter!
3. Picture
Old Nov 5, 2020 | 09:19 AM
FLC63s's Avatar
Kinda wanna say Hmmmmmmm
Old Nov 5, 2020 | 09:46 AM
PayKoHan's Avatar
AMG C63S T-Model
have you a pic from the hole in the bottom?
Old Nov 5, 2020 | 12:07 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I have air box spacer in stock.
Old Nov 14, 2020 | 04:35 AM
Dany1337's Avatar
W205 C63 AMG
Measured what i expected. Stage 1 Tune with OEM Airbox Mod 100-200 kph: 6,57 --> 6,63 sec.
The environmental conditions were very bad: 515 m obove sealevel, 961 hPa, 10°C, DA: 903
Old Nov 14, 2020 | 07:16 AM
PaulC63s's Avatar
Good job thats a great time 👏 Which tuner?
Do you get more turbo sounds with the mod?
