C63/C63S AMG
Wheel Offset Question
Old Dec 4, 2020 | 02:22 PM
Drisso88's Avatar
Veteran: Marine Corps
Current: 2017 C63S Prior: 2016 CLA45, 2015 Evo X Final Edition
I currently have stock 19" AMG wheels on my 2017 C63S Sedan, and am looking at getting a new set put on with a wider rear wheel, either 20x10 or 20x11. How do I know what offset I will need on the new wheels? I tried looking up calculators, but I can find any that are car specific. Is there a formula for this? Any help would be great, thank you.
Old Dec 4, 2020 | 06:37 PM
4dr.no's Avatar
2019 AMG C63
I use this online calculator but there are many others out there.
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
Old Dec 4, 2020 | 06:55 PM
Drisso88's Avatar
ok, thank you. Where can I find the stock sizes?
Old Dec 4, 2020 | 07:11 PM
SimMB's Avatar
C63S
Stock forged cross spokes are 20 x 10.5J ET57.
I use willtheyfit.com as it has the visual comparison.
Old Dec 4, 2020 | 07:25 PM
4dr.no's Avatar
2019 AMG C63
19s and 20s have same width and offset
Old Dec 4, 2020 | 07:28 PM
SimMB's Avatar
C63S
The same rear wheels on my estate had 19 x 9.5J ET56
Old Dec 4, 2020 | 07:40 PM
Drisso88's Avatar
Yeah everything I've looked up says my 2017 C63S Sedan has 19x8.5 front and 19x9.5 rear.... is that incorrect?
Old Dec 4, 2020 | 08:12 PM
Drisso88's Avatar
At the end of the day, I'm trying to do make a more aggressive stance than stock. Want to go a little wider in the rear, but doing all of these calculations is making my head hurt.
Old Dec 4, 2020 | 10:01 PM
4dr.no's Avatar
2019 AMG C63
Didn't realize you had sedan (glad I didn't buy your rims!).
Your sedan is indeed 19x8.5 ET38 and 19x9.5 ET56
There are some who have fitted wider coupe rear rims on sedans.
Old Dec 4, 2020 | 10:04 PM
Drisso88's Avatar
Perfect! That’s what I was looking for. And just to sanity check myself, a lower offset will lead to a wider stance, correct? Or is it the opposite?
Old Dec 5, 2020 | 08:25 PM
tobeit's Avatar
AMG C63s
...yes, assuming all other spec equal.
btw, I have a sedan too and run
front: 20x9.5+35 on 265/35
rear: 20x10.5+57 on 285/35
I am also lowered on KW and fitment is about as tight as you can do w/o rubbing and still have a daily drivable car - JMO. Others have fitted 305 in rear for racing use but don't recommend for daily.
Old Dec 6, 2020 | 10:36 AM
Drisso88's Avatar
Nice! Your ride looks great! Thanks for the info, it helped me out a lot!
Old Dec 7, 2020 | 07:24 PM
dctwc63s's Avatar
2019 C63S Sedan
I will be running 19x9.5 et35 265/35 front 19x10.5 et54 285/35 rear and also lowering on eibach pro kit on fl sedan.
Since its been raining where I am for the past week and forecast says more rain for another week or more so I haven't had them fitted yet so cant show you any photos.
Old Dec 8, 2020 | 10:48 AM
Drisso88's Avatar
Ended up going 20x9 ET35 w/ 255/35/20 front and 20x10 ET35 w/ 295/35/20 rear. Will update when they come in!
Old Dec 8, 2020 | 09:08 PM
tobeit's Avatar
AMG C63s
Uhm, who adviced you on that? The rear offset is way too small at +35! That paired with 295/35 will stick our/poke 27mm more then my setup. Compare pics and judge what that would mean but doubt you want that on your car.
Old Dec 8, 2020 | 10:51 PM
Drisso88's Avatar
sorry, fat finger on my part. +45 on the rear
Old Dec 8, 2020 | 10:54 PM
tobeit's Avatar
AMG C63s
Thats better but still likely too little and will poke quite a bit. You may go narrower, little stretched fire to make it not rub but that setup would not be my choice. If you are lowered it will hit your fender.
Old Dec 8, 2020 | 10:56 PM
Drisso88's Avatar
I’m not lowered, it’s a stock suspension. Stock offset is 56, which means I’m only sticking out about 3/4” over stock unless I’m missing something....
Old Dec 8, 2020 | 11:19 PM
tobeit's Avatar
AMG C63s
Sedan is a 9.5” rim with 265 tires.
Old Dec 8, 2020 | 11:21 PM
Drisso88's Avatar
Right. I currently have 285 on my stock 9.5” wheel, and am going to a 10” wheel with 295’s. That really shouldn’t make too much of a difference and I wanted my stance to be a little wider in the back like the coupes.
Old Dec 8, 2020 | 11:29 PM
tobeit's Avatar
AMG C63s
With that 295 tire you move 16mm further out compared to the 285 and stock rim setup you have now, which is already 10mm more than stock. That’s a lot of poke. I would recommend take a look first with the 285 and then see if you really want to go 295 and 45 offset. But, hey, your car, your choice.
Old Dec 9, 2020 | 12:51 PM
SimMB's Avatar
C63S
This is the difference from stock:
Old Dec 9, 2020 | 12:55 PM
SimMB's Avatar
C63S
And compared to a coupe 10.5J wheel with ET57 which I have fitted:
You'll stick out further than this by 5.7mm, which is quite a fair bit in my view, especially with the 295. I've got 285 in that pic, if you go for PS4, they have a bit more rim protection too.
Old Dec 9, 2020 | 01:00 PM
SimMB's Avatar
C63S
To put it into perspective, I had the coupe fronts machined by 7mm as they looked ridiculous, it made all the difference.
Old Dec 9, 2020 | 02:18 PM
Drisso88's Avatar
Ok, thanks for the info. I'll definitely look into it and report back with the results
