C63/C63S AMG
$3000 for replacing one fuel injector???
Old Jan 19, 2021 | 07:30 PM
jhkim83's Avatar
AMG C63S
Dealer diagnosed the cause of my sporadic cylinder #2 misfire was due to a bad fuel injector.
they quoted $3000 to replace one injector because they said the engine has to be unbolted to roll the engine to be able to get the injector out.
Does this sound right? Does the engine really need to be unbolted to get the injector out?
Old Jan 19, 2021 | 07:38 PM
skratch77's Avatar
2005 E55
I thought your car was under warranty
Old Jan 19, 2021 | 09:04 PM
jhkim83's Avatar
AMG C63S
I wish. It’s a 2015 with 70,000 miles
Old Jan 19, 2021 | 10:26 PM
theprototype's Avatar
24 AMG GT55
Don’t know the answer to that question but I would never take my AMG to a dealer for repairs once the warranty’s done. Plenty of second party euro specific auto shops that do great work I’d go to first.
Old Jan 21, 2021 | 09:36 AM
AlexZTuned's Avatar
2017 Porsche 911 C4
A new fuel injector costs about $165. Part number is: 2560700187
https://www.fcpeuro.com/products/mercedes-fuel-injector-bosch-2560700187
Unless they anticipate 18 hours of labor at $150/hr to replace a single fuel injector, sounds like you need to find an Indy shop or different dealership... or DIY.
Old Jan 21, 2021 | 10:30 AM
skratch77's Avatar
2005 E55
Change coils and plugs first and run a bottle of injector cleaner.
Old Jan 21, 2021 | 12:33 PM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
I have no IDEA if this site is even close to accurate but here goes :
https://repairpal.com/estimator/merc...placement-cost
Best of luck and let us know how it goes...
Old Jan 21, 2021 | 12:59 PM
tobeit's Avatar
AMG C63s
Interesting, when I put my model year and zip code into that link it comes up with $1385-$1631 for replacing ONE of them.
Old Jan 21, 2021 | 07:18 PM
jhkim83's Avatar
AMG C63S
I called another local shop that specializes in Mercedes, and they quoted me a similar price.
I thought about changing it myself, but I don’t have xentry to re-code the injectors.
Both the dealer and local shop won’t just do the coding if I did the replacement myself.. they said they would need to do the injector replacement AND the coding.
Old Jan 21, 2021 | 07:49 PM
blowoff's Avatar
S205 C63s
Option, buy the part and install / code yourself using Autel MaxiPRO MP808TS for under 1k USD. It will give you full [size=13px]details[/size] including logs of injectors and [size=13px]duties.
If a coil is out or even a plug it will tell you.[/size]
Have had this tool for a few months now and does about 80% of what xentry will do.
With my estate being so modded this scan tool has already paid for it's self. Highly recommend it.
Old Mar 16, 2022 | 06:22 AM
anwar_hamoude's Avatar
2016 C63 AMG
CODING IS ALL HUFF!
I haven't changed out my injectors but so far I haven't needed to code any repairs. Coding parts is all huff to deter people from fixing their own vehicles. Unless we are talking transmission rebuild. I bought MaxiSys MS906TS. Which is a really cool thing to have but most cheap OBDII scanners can clear codes. MaxiSys can reprogram modules.
I can't for see that an injector wouldn't be plug and play.
Dealerships charge premium price and perform substandard work; they're thieves.
Old Mar 16, 2022 | 01:41 PM
Jimmy_c63s's Avatar
That's a pretty full on kit there but looks promising. Can the MaxiSys MS906TS find and reset soft codes such as soft limp mode or exhaust flap malfunctions? Seems like a good bit of kit.
OP the injectors are $700 each in Australia from Mercedes so whoever told the you $3000 in the US for a single injector plus labour is fkn dreaming 😂
Old Mar 16, 2022 | 05:37 PM
2016 C63 AMG
MaxiSys MS906TS has programming functions. ECU can be reset/reprogrammed. If a code is cleared from the vehicle and the physical problem still exists the code will come back.
Old Oct 30, 2023 | 06:17 AM
WVM's Avatar
WVM
C43 AMG
Did you fixed the problem my friend ???
