C63/C63S AMG
Schroth Racing Harness
Old Mar 10, 2021 | 09:20 AM
W213e63s's Avatar
2019 C63s
Since a few of your have messaged me inquiring about my 4-point harness, I thought I would start a thread for those with the AMG Performance Seats looking for a harness for track days. I called Schroth last year and they directed me to one of their distributors, HMS Motorsports in Mooresville, NC. Called HMS and told them what I had and they said the only harness that would work is the Schroth Rallye Cross (bolt on).
I’ve had 4 track days with it and love it. Simple install as well. Just make sure you disconnect the battery otherwise the airbag sensors that you need to disconnect when moving the seat around will throw codes. You don't need to remove the seat from the vehicles. Simply unbolt the four hex bolts that hold the seat to the floor and disconnect the airbag sensors so you can move the seat freely. Remove the plastic cover on the side of the seat to access mounting points - where the seatbelt and buckles each connect to the seat.
For the rear, remove the seat cover, pull from the front and it pops out quite easily. Same process as the front - I used the left-most mounting points for where the seatbelt and buckles attach. I also bought a buckle dummy off of Amazon for when I'm at the track. Hope this is helpful.
Old Mar 10, 2021 | 12:27 PM
magno.amg's Avatar
C63S coupe ed.1
this is sick!! What was the price per harness? I’d like to see them in yellow!!
Old Mar 10, 2021 | 01:48 PM
W213e63s's Avatar
2019 C63s
$200 for the harness, $46 for the shoulder pads and $16 for the adjusting pull grips
Old Mar 10, 2021 | 05:47 PM
EkS's Avatar
EkS
C63
Welcome to the club. I did mine a little different and added a fire extinguisher.
Old Mar 10, 2021 | 06:11 PM
W213e63s's Avatar
2019 C63s
I like that!
Old Mar 11, 2021 | 08:38 AM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
Were are the rears mounted too ? Would like to see a pic of that :-)
Old Mar 11, 2021 | 02:52 PM
user33's Avatar
Thanks for posting. I noticed that the "Schroth Installation Checklist" PDF states "The shoulder belts will cross over when anchor points are located more than 450 mm (18”) behind the seat back rest." but that yours come straight back to the back-seat anchor-points.
Old Mar 11, 2021 | 04:24 PM
EkS's Avatar
EkS
C63
To the anchor points in the backseat, but the belts cross.
Old Mar 11, 2021 | 10:16 PM
W213e63s's Avatar
2019 C63s
I’ll take a few pics this weekend when I fix mine so the belts cross! Thanks for calling this out guys - it never occurred to me and obviously I looked over that part of the instructions. Typical
Old Apr 22, 2022 | 05:34 AM
Iridium.C63s's Avatar
16' C63s, 22' RAM 1500
Glad I found this thread! I've been wanting to get a harness for my track days. Installation looks easy too
Just ordered the Rallye Cross directly from their website.
Old Apr 22, 2022 | 09:58 PM
mpowell's Avatar
2019 C63S Coupe
Do you have any pics on how these are installed into the back seat of the coupe?
Old Oct 2, 2025 | 10:59 PM
Spicywolff's Avatar
18 c63 s sedan
I do autocross and this amazing info. I’ve been looking for how to do this set up. Thanks for it. Any idea what the part numbers I need are?
