C205 C63 Exhaust pop/Rattle
First post here but been snooping around this forum for a little while until I finally had an issue myself. Now I understand this has been brought up one or two times and everyone points at the butterfly valves but mines seem to do it regardless if my performance valves are open or closed, when closed it is slightly quieter which I demonstrate in the attached video.
Car had its B service back in the end of Jan with a sparks and gearbox fluid change also but I've only noticed this issue last few days.
Everything runs fine, no engine lights or warning, performance is still perfect with no issues and my question is do I need to worry about this? Do I need to get it recitifed or just live with it?
The car only has 16k miles on the clock and it's a 2016 plate with pretty much every option, it's a coupe c 63 amg as the title so silly yes 😂
Any ideas would be appreciated 😁
Thank you all!!
I would rather avoid a visit to the dealer if I can as I don't have any extended warranty and last thing I need is to replace a very expensive exhaust as the other post said there was no fix and his exhaust was full replaced.
I'm thinking if it's o2 sensor surely my engine light would be on?
Would it be bad if I just leave it and wait till the issue develops?
When was the last time you had them replaced?
Sorry mine wasnt it :/
