Question about the secondary cat delete
You are definitely out of the MB engine sound at this point.. just will be loud exhaust sound per say..
Respectfully disagree. The car sounds amazing and not fart-canny at all. Should have come this way from factory.
The name of the game, is for you to like it, and screw everyone else's perception, its your car :-) but man.. just has to be a loud one...
I have AWE Switchpath, and on a stage 2 with this and that, but all Cats are intact and its loud AF..
I had a shop make me an awe track type setup (as mentioned is really only straight pipe stepped up to 3 inch) and also did secondary delete at same time. It sounded good and was fairly loud at idle and low rpm, but it almost seemed to get quieter/ not as loud as I wanted under throttle & WOT, so I ended up putting my stock exhaust back on and went catless downpipes. I'm finally happy with how it sounds. To get these cars to make some noise under load, you really need to do catless downpipes. I think even a high flow catted downpipe setup would also almost be as loud.
I'm hearing this new EPA thing going on makes it harder for people to get second cat delete.
