🚑 [Pic] Warning to Coupe owners with Optional RXC Forged Wheels & 38 PSI tyres
If you have the optional forged leightweight rims on your coupe and running your front tyres at or below 38 PSI fronts and below 34 PSI rears they will crack and bend..........
Should have listened to old mate @Jimmy_c63s ......... 🤦♂️🤦♂️🤦♂️
I spoke to management at AMG Sydney about this because I have seen over five other instances of this happening on social media posts............
Here's the kicker::: AMG Sydney reckon that the tyre pressures on the fuel door are actually only recommended for the STANDARD C63S mesh and star type of wheels...............
NOT THE OPTIONAL RXC black with polished silver lip lightweight forged pieces of shet which are made by APPTECH in Italy 👎👎👎
AMG explained these wheels are so bloody light, they are lighter than carbon counterparts. Not sure about that statement but okay.............
And being so light, this is why they CRACK and BEND if you run tyre pressures lower than 38 PSI on the fronts and 34 PSI rears.
The whole Mercedes experience is something I'll probably never go through with again tbh. But whilst I'm stuck with this lemon i find it a responsibility to share my experience.........
Mine buckled driving in Sydney streets which aren't even that bad. No bad potholes and im not married anymore so no wife to blame............
Please take my advice if you have these wheels............. ☝☝☝
44 PSI FRONT and 39 PSI REARS is what you should be filling them to (COLD) if you have these particular wheels on the Coupe.
All other C63S AMG factory wheels are fine at lower pressures.
Can you spot the buckle?
Regards,
George Lisciandro
Ever since mine cracked last year running 36PSI front 34 PSI rears it cost me $4000 AUD for second hand set which luckily were in good condition. Mercedes wanted $11,000 for a set. Sh*t c*nts.
I've seen heaps of guys crack theirs too on social media.
Of course AMG know about this but are trying to keep quiet about it 👎
Doesn't surprise me though. They're always ducking and diving when it comes to addressing things.
But any more than that the fronts will really tramline.
The coupe fuel door actually has 44 PSI/39 PSI listed for carrying people etc.
If I had the spoke mesh wheels I'd be able to run much lower pressures. Argh.
My tire shop did 40 psi all around after a swap and the ride was so harsh that i could not take it. Had to pull over and deflate so thats why I was a little surprised to see 44psi but i mine doesnt have the same rim as orininal poster so maybe its that
PS: I run 40-44 cold all around (depends on outside temp) ...not racing and just because of 30 profile tires. When I put them down to 32 I can see the bulge and that's not a good "look" on 30 profile tires.
Only applies to the wheels pictured above which are the forged RXC 767 lightweight wheels.
The optional forged lightweight RXC coupe 19/20" wheels weigh:
Fronts 8.27kg (18.2 lbs) each
Rear 9.88kg (21.7lbs) each
Not the multispoke mesh type in your first picture. Those are a bit heavier and are not prone to easily cracking and the bending issues.
Ah man. No, I'm only talking about the RXC Forged twin 5-spoke 767 Apptech ones. They are the ones that crack with low tire pressures.
Here's a photo of the wheels George and myself are talking about (on my car):
I really like the RXC wheels which is why I got another set when both my front ones were damaged.
One cracked at the spoke, got welded but cracked again. And the other side got buckled so ended up buying another set.
You'll be happy with yours man, they are great wheels 👍
