C63/C63S AMG
W205 C63S camber inquiry
Old 06-17-2021, 06:41 PM
tobeit's Avatar
AMG C63s
Originally Posted by dctwc63s
That is some epic camber right there!
How far off was your toe?
Camber is not really by choice...I don't mind if it would not be for the edge wear.
Front toe was 0.03/-0.11 now adjusted to +0.15/0.13 but I need to go back to check again as they messed up and punched the wrong car (AMG GT vs C63) into the computer. Front camber was and is -3.1/-2.8 and rear is -2.7/-2.4.
If you look at it on the street it does not look all that much camber...picture below is before the KW-HAS settled a bit though.
my front tires after 5k miles
Old 06-17-2021, 07:27 PM
deftronix's Avatar
17 C63S coupe
I have the same issue. I'm on H&R VTFs and about as low as you Tobeit. Go through a pair of sport cup 2's every 5k in the front as well on my coupe. Rears last about twice that. What a waste of good rubber!
tobeit (06-17-2021)
Old 06-18-2021, 02:31 AM
ShaneN.'s Avatar
2018 e63s edition 1
Tires still look like they have plenty of life still. More than double the kms on my current tires and your on hr springs too.
Curious what your camber and toe numbers were after lowering.
I will be able to take a look at my tires in 2 weeks when the car goes in for an exhaust.
Originally Posted by 1slick_c63amg
2. @ShaneN. Tires don't look bad at all. Do you by chance have your alignment specs you can share with us? Toe and Camber specifically?
This is my first set since being lowered and I've been checking them religiously waiting to find camber wear after reading all the stuff on this site, but they're still wearing evenly. If I recall I was at - 2.9 front (could that be right?) after lowering but can't find my print out from that day. He mentioned he fixed toe at that time. The only thing I can come up with, and it's probably pretty unlikely, is that it rains about half the year here so maybeeee less friction is easier on them mixed with having to actually drive the car more conservatively as well. I could see that making a tire last longer in general but I can't really fathom it stopping the inner wear.
Old 06-18-2021, 08:20 AM
dctwc63s's Avatar
2019 C63S Sedan
It seems to me that there are some that are lowered and don't get excessive tire wear and some do.
I just stuck my head under my bumper to take a closer look at my front tires and they seem like their fine.
My springs should have settle so I'll get my alignment checked again when I get my exhaust installed and share the before and after specs. Also curious to see how my rear camber arms held up.
Old 06-18-2021, 08:21 AM
mischief's Avatar
W205 AMG
the inside tire wear you’re seeing is going to be caused by the car being too toe out (negative toe). Getting your toe set more neutral (closer to 0) will aid in solving your inside tire wear.
Old 06-18-2021, 09:16 AM
tobeit's Avatar
AMG C63s
Did you read what I wrote about my toe incl measurements?
Old 06-18-2021, 09:30 AM
  #32
theclutch's Avatar
C8, FF, C63S, 911 C4S, GTI, E350, Boxster S, 355, Esprit S4, Vantage, S5, Z4, M3, Miata, A4, 325is
OUCH at 5k miles!!! Could it be that it's your TOE setting that's causing this? It's supposed to be set as close to zero as much as possible. Some people say (I'm skeptical) that it's primarily the toe that kills tires vs camber.
Old 06-18-2021, 04:46 PM
  #33
mischief's Avatar
W205 AMG
sure did. Prior to your car being aligned, your total front toe was -0.08. That promotes the inside tire wear your were seeing. After your alignment you are now toe-in. This should promote more outside tire wear.
the actual toe measurements wouldn’t change with the incorrect vehicle selection. Only the target values would.
tobeit (06-18-2021)
Old 06-18-2021, 04:55 PM
  #34
theclutch's Avatar
I'm skeptical.... How the hell can positive toe-in affect the outside edges of the tire when he's got almost -3 degrees? Oh nevermind... you wrote outside wear vs outside edge wear...
Old 06-18-2021, 05:14 PM
  #35
mischief's Avatar
W205 AMG
It’s definitely possible. I had a friend tear up the outer edge of a set of sport cup 2’s on the front on his E92 M3 with a large negative camber and toe-in setup after a day and a half at the track.
It all has to do with dynamic loads. The reason you run a lot of negative camber is because under cornering loads the outside tire will flatten out and you’re trying to prevent rolling onto the side wall. The toe-in (positive toe) will cause the out edge of the tire drag and this would be a bad mix especially when accelerating out of the corner.
Old 07-24-2021, 07:28 PM
  #36
Phorte's Avatar
2015 C63S
Originally Posted by K-Mac
It took me a while to sift through all the text but finally found what I needed - pasted right at the end of the post above are specific install instructions. Doesn't look like it should be too bad! My car is going in on Tuesday to get Eibach springs and KMAC 503316-1G (front only) installed.
RS MAMBA (07-26-2021)
Quick Reply: W205 C63S camber inquiry
