W205 C63S camber inquiry
w204 c63, w205 C63s
Hello,
I have the w205 c63s sedan with 20 inches wheels( front 9J ET30, back 10J ET50), front tires 255, back 275.
Currently lowered my car with H&R lowering spring and the driving quality is good enough, but the camber is way too negative( front -2.47,-2.29 rear -2.35, -2.20).
I'm trying to adjust the cambers but wondering does anyone have any suggestion of ideal camber range for this car?
Thank you
Thank you
It's more personal preference imo.
If you want longer tire life then probably something like 1.5-1.8 for the front and around 1 for the rear.
I'm lowered on eibachs and the front didn't change too much from stock after so just left it but the rears I got adjustable camber arms and set it to stock camber angle. My toe is front 0 rear 1 as toe in/out wears tires out way more quickly than camber.
FLC63s (05-26-2021)
I'm curious what the OEM range values are.
As mentioned above, you may need adjustable bushing kit for proper alignment and to bring camber back up. When lowered the camber will naturally become more negative and the stockers don't allow much adjustment. There's a few threads on the Kmac adjustable bushing kit thats available.
SPONSOR
Costly, Premature, Inner Edge Tire Wear.
Comes down to the basics - “that OEM there is no longer Camber (or Caster) adjustment”. Only Toe “directional” adjustment !
All to do with cost cutting and the ever increasing speed of OEM assembly lines.
NEW CAR INDUSTRY'S BEST KEPT SECRET. OWNERS GOING FROM ONE DEALER OR ALIGNMENT SHOP TO THE NEXT ONLY TO ADJUST, RE ADJUST “TOE SETTINGS”
(OR CONTINUALLY CHANGING TIRE BRANDS).
Excess Camber (visually identified – front or rear wheel squat) “Camber adjustment” is essential. Allowing to change, fine tune tire contact angles. Spread load more evenly. Excess edge load also leading to higher impact, ruptured side walls, rim damage.
While front “Caster” adjustment allows to compensate for Camber change, along with the ability to correctly resolve steering pull and improve directional control.
WE SAW THE NEED TO FIX IT RIGHT THE 1ST. TIME – BY RE-INSTATING FROM THE EARLY 90'S FULL FRONT AND REAR ADJUSTMENT
(NOT ONLY FOR DAY TO DAY COMMUTING - ENCOUNTERING HIGH CAMBERED ROADS OR ALTERED HEIGHT OR FITTING WIDE PROFILE TIRES. BUT ALSO FOR “TRACK DAYS” - IN THE PURSUIT OF FRONT ROW OF THE GRID LAP TIMES).
KMAC has the experience of resolving such OEM suspension shortcomings since 1964. Not with relabelled imports, but “in-house” manufacture allowing both total control over quality and rapid, ongoing development. Then combined with competition proving – All ensuring to be at the forefront re very latest design breakthroughs. See website “About Us”.
FRONT C63S KITS:
1. #503316-1G Priced right at $295 (Both Sides)
(less then the cost of one high performance tire).
This popular kit allows precise single wrench adjustment providing front “Camber” (lower arm inner bushes). Up to 1.5 degrees Positive or Negative. More then enough to resolve most premature tire wear issues. Includes bush extraction tool allowing fitment without arm removal.
2. #503316-2J Also Priced right at $395 (Both Sides)
Both “Camber and Caster” adjustable. Alternative – or extra adjustment for Track days. Again fit without need for arm removal – bush extraction tool included. Replaces the 4 upper arm inner bushings. Up to 1.5 degrees Positive or Negative. Unlike welded fabricated upper arms kit allows the security of retaining the OEM hi strength forged alloy arms.
3. #503316K Ultimate kit $480 (Both Sides)
Both Camber and Caster adjustable. Replacing all 4 lower arm bushings (the highest wearing). Camber (#1.) and the forward facing thrust arm bushes for Caster.
Caster bushes are Monoball / 2 Axis replacing the OEM soft rubber, oil and air voided bushings. Still allowing arms to travel through their required suspension arcs without binding, locking up. Yet significant improvement to brake and steering response. Outperforming spherical bearings having more then twice the load bearing, impact area.
Unique patented design allows precise, single wrench adjustment, accurately (under load) direct on alignment rack.
REAR SUSPENSION – C63S
#502326-1K $480 (Both Sides)
You can purchase (inaccurate one offset position) Camber plates for the lower arm inner mounts. KMAC design breakthrough / upgrade here is “precise single wrench” adjustment and “doubling” the existing adjustment range (plus kit includes “extra Toe adjustment” to cater for the Camber change). These KMAC (performance bushings) also include bush extraction tool allowing fitment without need for arm removal.
4. #502226-3M $595 (Both Sides)
Replacing the “Upper arms” providing Camber adjustment (also extra Toe adjustment to compensate) NOTE: Keep in mind lower arms retain important clearance “top of tire to outer fender” when wanting to resolve premature inner edge tire wear. While upper arms reduce this clearance !
5. #502628K $480 (Both Sides).
Another popular kit (replacing the '6' multi link rear arm bushings). Provides less rear end twitch, flex, loss of traction. Especially when applying power to lane change / overtake.
Delivery $40 one kit ($20 each extra)
1888 844 9099 (24/7) Worlds Largest Range (Street or Track) Front & Rear Adjuster Kits – Audi to Volvo
I would of considered purchasing front and rear sets since it's aussie made but every thread I have searched looking for info on lowering and camber I see his posts which are like force feeding someone something they may or may not want which just turns me away from their products completely.
Yea he may be trying to help but at this point and from what I've seen it's way too excessive (thought vendors have their own threads to spam).
Received 3,417 Likes
2012 CLS63
SPONSOR
Do apologize to all. We being over enthusiastic. It was all about after more then 20 years of design and development finally achieving the goal of Camber and Caster adjuster kits not requiring any mods for virtually every model.
Campaign certainly did help to awaken many owners to the fact “full” front and rear alignment (even a C63'S') is only Toe adjustment.
End of the day we are only small niche dedicated aftermarket suspension manufacturers. So again apologize for any upset. Even though would like to see some frustration directed towards the highly profitable new car industry re costly, edge tire wear and.... “is within factory specs”.... ”there is nothing more we can do”, putting the onus back on owner to fund premature tire purchases.
Very best regards Kevin
KMAC Mercedes Catalog
Well, just got a call from my shop and they want 8h install time each side for the K-MAC front bushing kit. Ouch. Explained they have to remove control arm, remove bushings, put it all back together and so forth. Anybody has an estimate what it should take? Seems excessive and for sure install cost is many times than the deceiving cost of parts.
I also tried a few. Most don’t want to touch it and the one who does quotes by the book as they have never done one of our models. So, in addition to being ridiculous expensive to install (even though they told me they will charge just actual time once they get going) I am not sure I want someone who has never done it install it. I read too many issues about wrong installs causing issues with the K-Mac kits. So, for now, I just had toe adjusted and that’s it. My camber is between -2.7 to -3.1…i know that’s a lot but I am pretty low (maybe 5mm top fender gap).
SPONSOR
The hi-performance C63 ‘S’ OEM not having front Camber and Caster or rear Camber (only front and rear Toe “directional” adjustment) is a concern.
At KMAC it’s all about providing front and rear kits to provide adjustment to reduce costly / premature edge tire wear or to be able to change settings for track days in the pursuit of front row of the grid lap times.
Yes the criteria is SIMPLEST POSSIBLE fitment, Ease / Quickness of adjustment, competition proving for strength / reliability.
SO FOR THE C63 ‘S’ HAVE PRODUCED ‘3’ Front kits and ‘2’ Rear kits.
(Have attached all instruction sheets)
Most popular Front kit:
#503316K $480 (Both Sides)
Replaces the 4 lower arm highest wearing inner bushes for Camber and Caster. Precise single wrench adjustment.
Forward facing thrust arm (Caster bushings) are Mono ball / 2 Axis significantly improving brake and steering response. Outperforming spherical bearings having two and a half times the load bearing impact area.
#503316-1 $295 (Both Sides)
Is above Camber (only) adjustable bushes.
Extraction tool included for both above Camber P/N’s allowing fitment without need for arm removal.
While actual adjustment is simplicity. Last 40 or so years it required the time consuming trial and error need to remove and replace a bushing at a certain setting.
KMAC patented design revolutionized this. Now bush is inserted in any position and precisely adjusted accurately (under load) direct on alignment rack.
PROBLEM WITH INSTALLERS IS HOW CAN THIS POSSIBLY WORK. Where is the chart to indicate bush setting placement !
....but once they get their head around it they realise the simplicity (often said simplest design is the best design).
#503316-2J $395 (Both Sides)
Extra adjustment or alternative. Replaces the 4 upper arm inner bushes. Also with bush extraction tool allowing to fit without arm removal.
This KMAC design also has the security of retaining the OEM hi-strength forged alloy arms. Not replacing with welded, fabricated arms.
FOR THE REAR:
#502326-1 $480 (Both Sides)
C63 ‘S’ lower control arm inner bushes you can purchase inaccurate / one offset position Camber plates.
While KMAC design provides “precise” single wrench adjustment and “doubles” the adjustment range plus also includes extra Toe adjustment to compensate.
#502226-1M $595 (Both Sides)
Upper turnbuckle adjustable arms (plus extra Toe adjustment to compensate). Chrom Moly hi-strength tubular arms not soft extruded aluminum.
NOTE: Advantage of lower arm adjustment is that it retains important clearance top of tire to outer fender when wanting to resolve premature inner edge wear.
Also track days increases track width. Upper arms reduces this outer fender clearance.
502226-3M 502326-1K 503316-1G 503316-2J 503316K
FOR THE REAR:
At KMAC it’s all about providing front and rear kits to provide adjustment to reduce costs / premature edge tire wear or to be able to change settings for track days in the pursuit of front row of the grid lap times.
Replaces the 4 lower arm highest wearing inner bushes for precise single wrench adjustment.
Forward facing thrust arm (Caster bushings) are Mono ball / 2 Axis significantly improving brake and steering response. Outperforming spherical bearings having two and a half time the load bearing impact area.
FOR THE REAR:
FOR THE REAR:
SPONSOR
1. Did provide instructions for the '3' front and '2' rear options manufactured.
2. As pointed out performance vehicle yet no front or rear adjustment ex factory.
3.Role of the “aftermarket” is to make up for and design, rectify these OEM shortcomings
4. Criteria:
Design so no structural mods needed
Design so no special tools required
Minimal fitment time
Accuracy and quickest adjustment
Maximum adjustment range possible
Competition proving for strength, durability and ongoing development
Apologize, but doing our best Kevin
4. Criteria:
1. Did provide instructions for the “3 front and 2 rear” options manufactured.
4. Criteria:
Accuracy and quickest possible adjustment
Strength and durability.
Competition proving for strength and durability
4. Criteria:
nbennettksu (07-27-2021)
Why not just get camber arms? Simple install and adjustment.
Read a few threads on the kmacs both good and bad but just from the few that mention install and post issues would put me off camber bushings.
I've had rear camber arms installed with 7000km on them so far with no issues or noises at all and the roads here are trash. Still haven't found front camber arms that I like yet except for the carbahn ones but I'm having a hard time trying to get them.
Curious what your camber and toe numbers were after lowering.
I will be able to take a look at my tires in 2 weeks when the car goes in for an exhaust.
Couple notes after reading this thread:
1. KMAC jeez you guys are brutal. Can't follow any of your posts with all your clutter and copy/paste bull****. It would be much more pleasant if you contributed posts with something relevant to the topic. And from a marketing standpoint - keep it simple and more personable with actual written out answers.
2. @ShaneN. Tires don't look bad at all. Do you by chance have your alignment specs you can share with us? Toe and Camber specifically?
3. I plan to lower on KW HAS, what would be best option to keep camber/toe within stock specs? I cant understand anything KMAC posts is there any other options out there that are both ideal and somewhat cost effective? (dont mind spending the extra dollar if it's worth it, just dont want to by a whole kit if its unnecessary. I don't track the car, just mostly spirited driving).
I am on KW HAS and lowered to pretty much the max with my tire/wheel spec (less then 5mm gap between tire and fender). I just had my alignment checked when I tried to install the KMAC and my camber varies between -2.7 to -3.1 across all 4 corners. My front tires last about 5k miles with that....rear is about twice as much. My front may had been made worse as toe was off too. So, I now have new tires and toe is all good - will see how long the front's last now (I am on PS4).
I have a KMAC front camber kit for sale ...
How far off was your toe?
