C63/C63S AMG
Shell Gas - Full Tank "Yellow Chck Engine Light"
Old Jul 30, 2021 | 07:22 AM
ShaneN.'s Avatar
2018 e63s edition 1
Originally Posted by Jimmy_c63s
I topped it right up though, where it pretty much overflowed and apparently is not recommended.
It threw this code for me when I did it P2097 Post Catalyst fuel trim, bank 1 - TOO RICH. I cleared the code and it never came back.
Just scan the code and if it's the same as mine, clear it and give her a good thrash.
This is the first thing I thought of. When filling up, the first time that pump stops on its own, you're done pumping. Don't try and round up to the nearest dollar even. I believe its even warned about inside the fuel door. Figured this out when crossing the border for cheap gas on 2 occasions with my old car.
Old Aug 20, 2021 | 01:05 AM
Ianbiz's Avatar
BMW F30 335 M sport
I had a similar problem, after filling up I would have a slightly rough idle, check engine light would come on but car would run fine once on throttle.
Long story short: replaced both vacuum purge valves and it solved the problem. Plus my start up idle at all times is way better.
Old Aug 20, 2021 | 01:07 AM
Ianbiz's Avatar
BMW F30 335 M sport
I’ll pull my service folder and get the part numbers for you guys.
Old Feb 27, 2022 | 10:19 AM
Jimmy_c63s's Avatar
More details please
Aye mate was it these two you replaced - part numbers A2054708701? Or the hoses too?
Old Feb 27, 2022 | 11:15 AM
FromV4_to_C63's Avatar
2021 AMG C63 Coupe
Mine was a internal part failure , fixed under Warranty
Old Feb 27, 2022 | 11:54 AM
Jimmy_c63s's Avatar
What happened to yours? Sorry I'm a bit confused bro
Old Feb 27, 2022 | 12:38 PM
  #32
George_1992's Avatar
C63 S Coupe
Did they tell you which internal part failed?
Old Feb 27, 2022 | 06:52 PM
  #33
2021 AMG C63 Coupe
Was a [Bad Water Pump] ,
After repair ... no CEL and temps stays at 183
Old Feb 27, 2022 | 11:52 PM
  #34
Jimmy_c63s's Avatar
Christ that's not good for a young car like yours but I'm glad they actually looked after you.
Thanks for the update.
Old Mar 2, 2022 | 02:46 PM
  #35
2021 AMG C63 Coupe
That is life i Guess, was fully covered under warranty , Plus I have a great relationship with the Dealership.
All in all it worked itself out , been good times ever since .
I raised a stink , for like 1 day . after that it was back to life .... no car is worth me getting stressed out over.
