C63/C63S AMG
Mode race: low gear changes!
Old Aug 12, 2021 | 07:57 AM
jmfabr2rc's Avatar
c63s amg sedan 2017
Help friends, when I put the car in race mode (with traction handling or esc totally off) the car usually changes from 2 to 3 at 4500-3000 rpm, it also does it from 3 to 4 at the same revolutions, it does it once in every run, this never does it on s +. . I have 1 month with the car, it is a 2018 c63s, does anyone know what is happening? I have tried in all ways and it always does the same only in race mode. . Thanks!
Old Aug 12, 2021 | 10:35 AM
Jimmy_c63s's Avatar
Let me understand this a bit better. You put the car in RACE mode, gearbox is in Auto, and it's automatically changing gears for you at 3000rpm?
That shouldn't be happening.
In RACE, the gears never automatically change up until much higher in the rev range.
Sounds like your car needs a proper gearbox re-adaptation done in Xentry by a specialist indy or the dealer.
Have you got warranty? Take it to the dealer mate. Get them to sort it out.
Old Aug 12, 2021 | 01:31 PM
djprov431's Avatar
2021 C63S Coupe
Foot to the floor in ANY mode is red line shifts in automatic I'm quite sure.
Old Aug 12, 2021 | 04:02 PM
Xec's Avatar
Xec
IG: @amg.svr
This is correct - foot to the floor engages kickdown
The kickdown pedal is at the very bottom of the accelerator pedal (if you gently push the accelerator all the way down, there is one more press that you can do at the very bottom and it is for kickdown)
Old Aug 12, 2021 | 04:42 PM
jmfabr2rc's Avatar
c63s amg sedan 2017
yes friend in race mode and manual. . I thought there was something I could do on the broadcast set or that it was "normal". . what do you recommmend me to do?
Old Aug 13, 2021 | 01:33 AM
Jimmy_c63s's Avatar
So even in MANUAL your Race mode is still automatically changing gear at 3000rpm sometimes?
It shouldn't not be doing that in MANUAL mode. Personally speaking that never happens in my car. In Manual I can be in 7th gear and floor past the kickdown and the car will not drop gears and shift by itself.
Only when coming to a stop and slowing down should the car downshift by itself in Manual or Auto Race mode.
Can you video this so we can better understand what is happening? And book it in with a dealer if you still have warranty.
Old Aug 13, 2021 | 07:37 AM
jmfabr2rc's Avatar
c63s amg sedan 2017
ok, i'm going to record the video today and show it, i'm new to mb so i don't deny you that before i take it to the dealer i want to treat it on my own. . I'm out of warranty with 59,000 mi
