C63/C63S AMG
Downshift from 4th to 3rd?
Old Oct 30, 2021 | 09:43 AM
matt2008's Avatar
C63 AMG
I've had my used 2018 (pre-facelift) non S estate for a couple of months now and have noticed that on occasions, when in sport+ in manual mode, changing down from 4th to 3rd gives a bit of thud and doesn't seem to rev match properly.
It doesn't happen that often but enough to make me notice it.
Is this normal or worth getting looked at as its under 'Used MB warranty' still.
Old Oct 30, 2021 | 09:45 AM
chassis's Avatar
2017 GLE350 4MATIC
How many miles/kms and in which market are you located? Does this have an MCT box, 7G or 9G?
Old Oct 30, 2021 | 09:46 AM
matt2008's Avatar
C63 AMG
29k miles in the UK and has the 7 speed box.
Old Oct 30, 2021 | 10:29 AM
George_1992's Avatar
C63 S Coupe
Normal..... my coupe does it in Sport+ & Race especially worse when in actual manual mode and coasting to a stop as the gears automatically change down by itself it'll thud hard from 4th to 3rd
Old Oct 30, 2021 | 01:21 PM
chassis's Avatar
2017 GLE350 4MATIC
Agree with normal. The 7G is clunky shifting into and out of 4th gear, mostly downshifting. For example 5-->4 and 4-->3. It's likely related to clutch K3 which is overworked in the box design. K3 is engaged in all gears except 4th. Actuating K3 with negative (braking) torque seems to be the problematic condition. I chalk it up to another MBAG design error.
Old Oct 31, 2021 | 08:39 AM
Jimmy_c63s's Avatar
OP yes all normal with our 7G trans. Coupe owner and I'll almost always get a thud in Manual mode from 4th down to 3rd as it downshifts itself coming to a stop without my input. This is when I always get it.
It happens here and there in Sport Plus or Race mode using full Automatic mode too but in full Manual mode it always happens from 4th to 3rd.
Top info mate, learnt something new cheers 👍
Old Oct 31, 2021 | 04:26 PM
Wexlax732's Avatar
2017 C63S AMG
With your mileage, it’s about time to do a trans flush and have the transmission relearned at your dealership. I recently did this service (purchased trans flush kit from FCP Euro and dealer did service)/trans relearn and the car drives like new.
Old Oct 15, 2023 | 07:56 AM
Mangion88's Avatar
S205 C63S
Hi Matt,
Did you eventually rectify the issue?
having the same problem
Cheers
