C63/C63S AMG
Hybrid Turbos, who’s running them??
Old Nov 10, 2021 | 12:10 PM
C63 stealth's Avatar
C63 AMG W205
Hi all
Anyone running Hybrids and if so what other mods are you running?
Is anyone just running the hybrids without supporting cooling modifications, ie larger intercooler/radiator or meth?
Appreciate any info you can advise!!
Cheers
Old Nov 10, 2021 | 02:47 PM
raphman's Avatar
'16 C63s
Old Nov 13, 2021 | 09:03 PM
dlefty's Avatar
/////PRO
The PTG1000 turbos are performing reliable and seem to be creating the fastest C63 and GT platform cars.
The Pure900 and Pure1000 are by far the two most popular stock housing upgrades.
Either way, you are fueling limited unless you put in new HPFP and/or meth injection. Neither is NEEDED, only if wanting to go beyond standard 93pump power levels.
Additional cooling isn’t a road block for 93oct pump power levels. If you are doing a bunch of track days in hot temps, maybe, but haven’t seen it being an issue yet.
My own personal thing is go the PTG1000 route, good and linear, adds tons of top end power vs ANY factory housing turbo. Small factory housing turbos need to run more boost and run hotter than a larger housing turbo like the PTG for similar results, but they still lack the top end.
Also, another problem I find with factory housing upgrades, is they are “punchy” and “torquey” because the power delivery is lower to mid in power band, and traction is hard enough in these cars.
If I were suggesting a route to go withOUT adding additional fueling, I’d go:
*Any intake / high flow air filters that are not pulling in hot under hood air
*PTG1000 turbos
*Red Star downpipes with your preference on heat shield/no heat shield, cats/no cats
*ECU tune
*TCU tune
These simple mods will probably net you over a second cut off your 60-130 times with no additional cooling/fuel.
Then hold on and have fun after 4,000rpms because things get nuts!
Old Nov 14, 2021 | 09:55 AM
noremaC's Avatar
17 C63S Coupe PTG1000
Agreed on the above post. The one thing that is missing from that list is a good tire. On 295 PS4S with PTG1000’s and catless DPs, I will spin at 80mph in 4th gear, sport handling mode (PFL car).
The recommendation I got from PTG on the TCU tune was unless I was going to implement meth, a TCU tune wasn’t a huge value add. 93oct and the 1000’s is okay for the stock TCU tune.
Old Nov 14, 2021 | 10:19 AM
skratch77's Avatar
2005 E55
Thats what I like about ptg. They are not trying to sell you things you don't need. I asked about buying a tcu tune and said I don't need it. The car can't put power down first 3 gears anyway so what is the point.
Old Nov 14, 2021 | 10:27 AM
noremaC's Avatar
the one of the potential benefits I see is a faster shift time.
Old Nov 15, 2021 | 02:10 PM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
We have stage 1 and stage 2 available!
> Click here <
Our Stage 1 features a billet compressor wheel and here are the results from our run
Before Turbos:
  • 548.6 WHP
  • 751.4 WTQ
Supporting mods: VRP Downpipes, AFE Filters, VRP heat exchangers, VRP methanol injection, and VRP tune.
VRP900 Turbos:
  • 653.8 WHP
  • 814.3 WTQ
SPECS:
Compressor Wheel Side:
  • Exducer – 73mm
  • Inducer – 47mm
Old Nov 15, 2021 | 02:41 PM
C63 AMG W205
Thanks for the reply guys, the above posts have helped out a lot as i was concerned about cooling, the car will be road car only!
Im from the UK so not much information on Hybrids on the C63 so any advice helps.
I will be going factory housing route as a lot less costly.
My Turbos have just been rebuilt to Hybrid spec as following:
Re-profiled Compressor Cover to fit larger Billet Compressor Wheel (Extended Tip)
CNC work to re-profile Exhaust Housing to fit larger Turbine Wheel
Cut back turbine Blades
Fit 360 degree thrust bearings and larger thrust washers and collars
Fit staggered gap oil seals
I already have MTC downpipes on the car.
Hybrid turbos go on end of the week then off to GADTuning to get filters and mapped.
As for Tyres im running Pzeros at the moment.
I will post an update in the next few weeks with how the car gets on when getting mapped on Dyno.
Cheers
Old Nov 21, 2021 | 09:14 AM
dlefty's Avatar
/////PRO
> Click here <
Before Turbos:
  • 548.6 WHP
  • 751.4 WTQ
VRP900 Turbos:
  • 653.8 WHP
  • 814.3 WTQ
SPECS:
  • Exducer – 73mm
  • Inducer – 47mm
Not a negative criticism….the dyno graph displayed shows exactly my point on the factory housing turbo upgrades. A huge “punchy” torque spike which makes the car a handful in certain acceleration situations, not fun when unexpected, as well as they still run out of breath up top.
The larger housing turbos will still be climbing in power delivery at redline, and not have that huge torque punch / spike low in RPM range of which can cause lots of wheel spin or you having to climb all over the steering wheel to keep it focused and not step out on you.
Old Nov 21, 2021 | 09:56 AM
ALFAitalia's Avatar
Alfa 159
I would have expected a bigger turbo to have an even bigger and more sudden torque wave due to the extra time taken to spool up flatters the bottom end response......then it comes in hard. Fast response is why they fit smaller blowers in the first place and on the street that what I would prefer....high torque at low revs. On the dyno chart above even with stock housing torque has been sacrificed sub 3250 revs....exactly where a street car needs it.....I would not want to lose more at the bottom to gain unusable power at the top by going bigger on the turbo......Race car? (as in drag drip not race circuit where you still need the low punch!).....of course that a different set of requirements!
Old Nov 21, 2021 | 10:45 AM
skratch77's Avatar
2005 E55
That is tuned that way for a reason. You will bend rods and blow your engine if you allow max torque sub 3000 rpms.there is huge stress on the pistons making 900ftbs at 2400 rpms
here is a car that you would love on the street but guess what? That thing blew up lol but man the low end must of felt nice.
Old Nov 21, 2021 | 10:49 AM
skratch77's Avatar
2005 E55
Old Nov 23, 2021 | 12:13 AM
roadtalontsi's Avatar
10 C six trizzle
that tuner seems to be known well for blowing up bmw's as well which they "specialize" in lol. I've heard rumors of a number lawsuits.
