C63/C63S AMG
Misfire or Knock
Old Feb 4, 2022 | 06:41 PM
milan25's Avatar
C63 s Edition 1 Sedan
Misfire or Knock
Hey everyone, wondering if you guys can help me diagnose a problem, I have 85k miles stage 2, the problem got worse after new spark plugs. When should coil packs be replaced? What else could it be? There are no codes btw, Thanks
File Type: mov
Old Feb 4, 2022 | 06:43 PM
milan25's Avatar
another vid
File Type: mov
Old Feb 5, 2022 | 01:35 AM
Ksun_w205's Avatar
W205 C63 S
Definitely not engine knock, you will KNOW when engine is knocking lol. I think there was a thread about something similar ways back but cant remember the thread name. I think it may be your exhaust flaps causing the sound but it does not sound anywhere serious or catastrophic.
Old Feb 5, 2022 | 10:39 PM
36EGMA's Avatar
C63s
I am experiencing this same exact sounds with my car. Only happens while car is idling and doesn't affect car performance at all. I haven't changed plugs yet and I'm around 44k.
Old Feb 7, 2022 | 12:14 AM
milan25's Avatar
Im taking it back to the shop this week and ill have it checked
Old Feb 8, 2022 | 03:43 AM
deanoo's Avatar
2019 C63S
One of my friends is going through the exact same issue
we changed spark plugs but still had a slight miss fire at idle, he will take it for a spin if it continues guess it will be a coil pack
Old Feb 8, 2022 | 08:41 AM
miamiboy's Avatar
C63s Sedan
I have 35k miles, had a misfire in cylinder 1 & 2, and error code for low fuel rail pressure. Doesn’t help that I’m stage 2, so I changed the coil and the 2 spark plugs underneath to test out the problems and the misfire and error codes went away.
Old Feb 19, 2022 | 09:50 PM
Jimmy_c63s's Avatar
Same issue
Got this as well. No CEL but code is there for Misfire in one of the cylinders and I just did all 4x coils 6 months ago for $2400 and new plugs.
Like the video I get the occasional "skip" when the car is idling in Park.
Thing is mine only did it after retune adjustment so my money is on spark plug gapping or an injector. It's definitely one of those two.
I'm gonna sus mine out this week & will report back.
Old Feb 19, 2022 | 10:37 PM
miamiboy's Avatar
C63s Sedan
I had a misfire after changing sparks + coil, forgot to gap them to about 0.22-0.24, no problems since then.
Old Feb 19, 2022 | 11:16 PM
milan25's Avatar
I changed my coil packs and plugs but the skip is still there. Mine could be injectors but the shop didnt have time to check
Old Feb 19, 2022 | 11:34 PM
Jimmy_c63s's Avatar
Cheers bro that really helps. Going to use those gaps tomorrow 🙂
Definitely injectors man. Your plugs are gapped alright? 0.22 to 0.24 like Miamivice?
Old May 16, 2022 | 12:25 PM
Jimmy_c63s's Avatar
Was it your injector mate?
Old May 17, 2022 | 06:01 PM
TeraPatrick's Avatar
C63 AMG
Anyone fix this issue?
I've had the Mexican jumping bean sound ever since I ran a burble tune (2 years ago). I've just given up after taking it to 3 different muffler shops and 2 different Mercedes mechanics. Although it did go away temporarily when I installed NGK spark plugs...but it came back about 2 weeks after. I just call them baby burbles now and dealt with it. It's only on idle anyways.
Old May 19, 2022 | 02:25 AM
Jimmy_c63s's Avatar
Was the sound "crick crick crick" when accelerating hard out of a corner? If so, that's the same issue that @George_1992 has. I've driven his car and it's like a click sound when you're next to a wall as you accelerate. He's is a prefacelift coupe.
