VRP1000 Billet Turbo Upgrade Customer Results!
Our customer's 2015 C63s hit 910 RWHP / 837.1 RWTQ with a set of these bad boys installed!
The VRP1000 turbos boast large factory housings capable of a direct fit installation. Inside, it contains a large 55mm turbine wheel, 55mm inducer, and 74mm exducer to ensure maximum power gains in your M177 AMG engine.
> Turbos Available Here <
> Check out our customer's build <
Supporting Modifications:
VRP1000 Turbos
VRP Heat Exchangers
VRP Heat Shield
UpgradedIntake Manifold
Port Injection
RPA adapters
Air flow ducts
Upgraded Exhaust
Xtreme DI high pressure fuel pump
Spool Performance low pressure fuel pump
Teejay Engineering titanium intake
Haltech ECU
Golabworx Tuned
How does one put that kind of power down to the ground on daily driven street tires?
I would think highway pulls are where its at.....
*Anything* can and will break eventually. If the car has street tires and has issues with traction, the loss of traction kind of acts like a fuse of sorts and helps the transmission live longer. Better traction via more meat on tires, proper surface prep at a launching pad with VHT, etc... will put a lot more input stress on the transmission and it will probably fail earlier than on the street, on regular street tires typical as on these cars that just blow them off the rims due to traction loss. Other platforms that use traditional torque convertors need anti-ballooning plates and really nice furnace brazing, etc.. to keep them from grenading their fins internally and just destroying the rest of the transmission. A wet clutch system is a nice option, and if fed good and copious amounts of clean fluid should last a LOT longer.
There are *lots* of things that can be done to the 722,9 transmission to make it handle pretty much whatever you put in to it, but the failure point then becomes things not the transmission and something else once you start approaching 900-1000hp (flywheel).
"Hold this type of power?". Yea. "How long?" not long if you are hard on the car, race a lot, etc... Street driven car with regular tires at that power level will probably break something else first related to fueling, or leaning a cylinder out, detonation, etc... The higher the HP and Torque, the lower the margin before something breaks becomes. The C63s 4.0 motor is very overbuilt for its stock power level. The 722.9 transmission which I am somewhat familiar with is really really nice - I'm not that familiar with the newer 9 speed tranny and cannot comment, but assume it could be made to handle whatever as well but even stock was probably designed with some reserve to insure it doesn't just break at typical street HP and Torque bolt on mods folks put on their cars, within reason.
