C63/C63S AMG
Still having misfires after changing coils and spark plugs
Old Mar 16, 2022 | 01:30 AM
miamiboy's Avatar
C63s Sedan
I was getting these codes after I went with Stage 2 PTG tune and changed the coils and spark plugs (gapped to about .23)
Ran some fuel injector cleaner and it was fine for a while but yesterday, the same codes popped up again when going WOT from 4th gear. I only run 93 pump from Shell or Mobil.
About to pull the trigger on replacing:
Fuel pump sensor
OEM Fuel Pump
The 2 fuel pressure sensors in the engine bay
Car has about 40k miles.
Anyone have an idea whats going on?
Old Mar 16, 2022 | 02:00 AM
Jimmy_c63s's Avatar
Fuel pump sensor
OEM Fuel Pump
Don't start buying all of those things yet. Let's start with the obvious ones first.
If that was my car:
  • I'd change the coil pack with a brand new one from Mercedes (only 1 required) which controls Cylinder 1 & 2. I'd then fill with good gas and test for misfires.
  • If I'm still getting misfires, i'll be onto the injectors next.
But I pretty much guarantee it's your coil pack that controls Cylinder 1 & 2.
You can ignore the U0100 code as it's benign.
PS: Our coils start playing up easily especially after tunes and re-tunes. Having had my car tuned twice in 3 years, I've had to replace all coil packs TWICE within the last 36 months at $700 AUD each.
Old Mar 16, 2022 | 02:03 AM
George_1992's Avatar
C63 S Coupe
Fuel pump sensor
OEM Fuel Pump
aye mate when was the last time u changed coil packs especially cyl 1/2 coil?? like jimmy said start with that coil first cos these things are really shthouse
u can also remove coil pack from cyl 7/8 & swap it into cyl 1/2 then test and if cylinder 7/8 misfires its a million percent your coil
Old Mar 16, 2022 | 02:14 AM
miamiboy's Avatar
C63s Sedan
If that was my car:
I replaced that coil pack first week of Feb 2022. I will swap em around with 7/8 tomorrow and see if it continues.
Old Mar 16, 2022 | 05:08 AM
Jimmy_c63s's Avatar
Did you replace all of your coil packs? Or the one on Cylinder 1 and 2?
Old Mar 16, 2022 | 09:47 AM
noremaC's Avatar
17 C63S Coupe PTG1000
Are you tuned on Dimsport or Verstand?
I was tuned on an older PTG Dimsport tune and had misfure issues. Replaced all spark plugs with 1-step colder + replaced the coils with updated coil pack on the cylinder that was misfiring. Still had a misfire issue. Had PTG update my tune on Verstand and the issue has gone away (had to buy a Verstand license).
TLDR; reach out PTG and ask them to update your tune.
Old Mar 16, 2022 | 12:51 PM
miamiboy's Avatar
C63s Sedan
just the one on 1 & 2
Verstand. I messaged him yesterday afternoon but they are kinda hard to get in contact with. I’m still waiting.
Old Mar 16, 2022 | 04:35 PM
noremaC's Avatar
yeah they can take a while to respond but they hit. Hit them up on What’sApp and wait from them to get back to you.
Old Mar 18, 2022 | 08:58 PM
domjansson's Avatar
C63 amg edition 1
Fuel pump sensor
OEM Fuel Pump
check evap solenoid and purge valve solenoid. That was my issue. Dealt with misfires for months finally narrowed it down after replacing VVT solenoids, spark plugs twice, running octane booster, all new coil packs, and a new fuel pump. Mine only happened at WOT near 5500-6k rpm to redline.
