C63/C63S AMG
W205 C63s RPM issues?
Old Apr 14, 2022 | 08:13 PM
Daniel Tajali's Avatar
W205 C63s Sedan
Hi all,
I recently got the c63s and it’s been great. Randomly today when I started it and put it in reverse the revs starting jumping really high and low and I was stationary, and I mean to the point the car was shaking. I just the car off immediately and turned it back on and it was fine. Has anyone experienced something similar?
Old Apr 14, 2022 | 08:24 PM
superswiss's Avatar
2019 C63CS
RPM instability can have a number of causes:
  1. Faulty fuel injectors
  2. Faulty spark plugs
  3. Defective fuel pump
  4. Defective air flow sensor
  5. Dirty air filters
  6. Vacuum problem
  7. Faulty electrical components
You could probably also add poor fuel quality and possibly other reasons. First step would be to read out the codes and see if anything got logged.
Old Apr 14, 2022 | 08:26 PM
W205 C63s Sedan
Thank you,
it hasn’t happen again and I use only 98. My rpm’s have always been stable and normal. This has happened once on startup and didn’t happen again. I’m puzzled.
Old Apr 14, 2022 | 08:27 PM
superswiss's Avatar
2019 C63CS
Originally Posted by Daniel Tajali
Thank you,
Possible that something is on the brink of failing and starting to be on the fritz.
Old Apr 14, 2022 | 08:28 PM
W205 C63s Sedan
Hmm what do you reckon it could be?
Old Apr 14, 2022 | 08:32 PM
superswiss's Avatar
2019 C63CS
Any of the above. As said, read out the codes and hopefully it'll point you to the cause. For reference my previous car developed cold start misfires around 35k miles out of the blue. Never got it resolved until I sold the car. Doing a carbon clean improved it, but never went away completely, but it was clearly partially caused by carbon deposits on the intake valves. I would also get violent shaking after cold starting the engine, and then I immediately turned it off and usually on the second start it was fine. Also it happened primarily with winter fuel blends. Never really happened during the summer months.
Old Apr 14, 2022 | 08:35 PM
W205 C63s Sedan
Thanks,
Mine is on a stage 2 tune, but I bought it like that. It’s got 25,000kms (15,500ish miles). I’m talking it for a service tomorrow so they can read the codes.
Old Apr 14, 2022 | 08:36 PM
superswiss's Avatar
2019 C63CS
Thanks,
Well that throws another twist at it. Common issue with tunes are fouled spark plugs.
Old Apr 14, 2022 | 08:38 PM
W205 C63s Sedan
What does that mean? I did boost it a tad drove home parked it up and then 15 minutes later started it and then that’s when I had the issue. Hasn’t happened since
Old Apr 14, 2022 | 08:42 PM
superswiss's Avatar
2019 C63CS
Means your spark plugs are shot. Covered in substance like oil, fuel or carbon or blistered from running too hot. Tunes overwork the stock spark plugs and they don't hold up for the expected stock interval changes. You'll have to change them more frequently or use aftermarket spark plugs that hold up better.
Old Apr 14, 2022 | 08:45 PM
W205 C63s Sedan
You’re an absolute legend, it that common to happen? My service is due tomorrow so everything will be checked over. I believe it’s the stock plugs, it also had a dyno run 3 weeks ago so it’s probably fried them? What I’m confused about is why the problem when away when I turned it off.
Old Apr 15, 2022 | 10:16 AM
BL4DE's Avatar
2017 C63S
Old Apr 15, 2022 | 12:30 PM
MaxVO2's Avatar
2018 C63s
*****When in doubt, pull a plug or two out and check them. This will verify their integrity. A banzai dyno run on a modified car with stock plugs can potentially cause pre-ignition or other byproducts of combustion to fuse themselves on to the plugs themselves. The plugs sometimes clean themselves a bit with additional driving but occasionally a porcelin breaks in the plug itself from a bit of detonation due to bad gas, too much boost, or a weak coil on that bank, etc.. It happens. Pull to verify. Good luck.
Old Apr 15, 2022 | 03:40 PM
W205 C63s Sedan
@BL4DE
it could have clipped to neutral, it that common to happen if it does? I purchased it turned, and I haven’t had the issue again. It’s going for a service in the next couple of hours so maybe they can tell me something.
Old Apr 15, 2022 | 04:03 PM
rmarchigiani's Avatar
C63s Coupe
@BL4DE
Yes its possible. if you don't push the shifter hard enough into reverse, it will go into Neutral. I've done that a few times and the car will rev, as you described.
Old Apr 16, 2022 | 09:56 PM
W205 C63s Sedan
Update - had the car looked at by my local Mercedes dealer and absolutely no issues.
Old Apr 16, 2022 | 10:34 PM
C63s Coupe
Maybe you did exactly what you said.....hit it into neutral vs reverse.
Old Apr 16, 2022 | 10:35 PM
W205 C63s Sedan
Maybe..
Old Nov 23, 2023 | 10:32 PM
stock_c63s's Avatar
c63 S amg
my car is also doing this but when idle it will do hard shake that lasts about a second and it will do it multiple times. I posted a video below where u can hear it.
any ideas???
File Type: mov
