C63/C63S AMG
Modalworks M177 Hybrid Turbo: quick spools with big power
Old May 5, 2022 | 12:26 AM
ModalWorks's Avatar
SPONSOR
W205 C63
Product Link
The Modalworks stage 2 hybrid turbo (dubbed the MW2) packs a big punch yet looks completely stock from the outside. Our design doesn’t just swap the compressor wheel, but also extensively machines the exhaust side to fit a large 9 blade turbine wheel. Our specific combination of turbine and compressor upgrades make for an extremely balanced hybrid turbo.
These MW2 turbos spool consistently spool as fast or faster than pure 900s but flow like pure 1000s. This design yields a setup without tons of turbo lag and still packs massive top end power.
- Made in the USA 🇺🇸
- Custom designed 5 axis point milled billet 6+6 compressor wheel
- CNC machined and ported compressor cover
- Oversized Inconel 9-blade turbine wheel
- CNC machined turbine housing
- Coated exhaust manifold for rust prevention
- Completely rebuilt CHRA with Borg Warner OEM bearings
- Entire assembly high speed balanced and professionally assembled
In stock and on sale now, get the best of both worlds with a quick spooling turbo that has big flow potential.
Old May 13, 2022 | 01:29 PM
ModalWorks's Avatar
SPONSOR
W205 C63
The product page HERE has a image of the dyno showing that we were able to hit 736whp and 723lb-ft of torque on an "unoptimized" tune on a standard dynojet. If you look at the chart you can see the torque at 4000rpm is higher than nearly every other hybrid turbo with published data (yes this is very tune dependent, but we point this out to show that the turbo itself has the capability to deliver tons of power down low as well as up top). Everyone is running a different set of hardware with different tuners, so what we want to emphasize with the data shown below is that our turbo is able to produce significant flow throughout the RPM band with a very fast response.
Prior to the dyno, we compared Pure 900s to our turbo directly on the same vehicle, as well as reviewed numerous logs from customers with their Pure1000 to give a comparison of how the hardware compares as seen below.
What this means is that our MW2 responds incredibly fast with tons of upward flow potential. We accomplish this by not just shoving the largest compressor wheel possible in the housing. Other companies advertise very large wheel sizes above 72mm with a small to medium sized turbine wheel around resulting in a compressor to turbine ratio of 30+% (not great). We don't think this is the best approach because you inherently create a mismatched turbocharger... our main focus was to create a balanced setup that spools fast and keeps producing all the way till redline. Most turbo design guidelines recommend the ratio to be within 10-20%, exactly where ours lies.
Additionally, in the graph below we are easily able to maintain 29psi all the way till redline while hovering in the 66% WGDC regime. Plenty of untapped flow potential.
We plan to take this car back to the dyno once the trans is built and push the turbo to the limits, but for now we are exceeding the torque capacity of the 7sp transmission.
Old May 13, 2022 | 07:40 PM
AMGMD's Avatar
2012 C63 Coupe P31 OE Tuned/ROW Airbox/K&N filters/Quaife LSD/MBH LTH, Race Cats, Midpipes, Xpipes
Any 60-130mph dragy times?
Old May 13, 2022 | 08:27 PM
noremaC's Avatar
17 C63S Coupe PTG1000
What are you finding as the torque capacity of the 7spd?
Old May 14, 2022 | 10:57 AM
MaxVO2's Avatar
2018 C63s
*****The 722.9 Transmission will handle up to 1000 N.m of power, or approximately 737.56212117 Lbs/ft of torque, assuming the fluid is in good condition and the clutches and bands are not glazed or worn. This is intermittent, and not constant - as in a race start with the wet clutch engaged and with decent traction, etc.. The transmission can be upgraded with better quality steels, clutch packs, and bands available from various transmission shops. In addition, the pressure regulator valves can be upgraded, as well as the front pump, and other typical upgrades for performance to help the transmission survive higher input torque as well as repeated high torque environments. These type of modifications will keep the bands and clutch plates from burning up by providing more fluid from the regulators to keep everything cool. If the transmission is modified in this manner with better steels, etc.. it is essential for longevity to install supplemental or higher capacity transmission cooler(s) as a higher HP motor will produce a LOT of heat through torque input to the transmission. Heat kills the transmission in addition to just too much input torque, dirty fluid, worn fluid, etc..
The 722.9 is a really nice transmission that can be essentially bulletproofed to whatever typical mods most folks do on these cars, within reason. The drums and casing itself are very very sturdy with remarkable reinforcement compared to lesser transmissions. You don't get something for nothing of course, and the additional reinforcements and use of better quality parts, steels and friction materials costs money as well as someones time to put it all together, etc... In addition, the additional reinforcement will somewhat increase drag on the mechanism and contribute to additional parasitic losses at the driveline depending upon what is done. Same flywheel HP at motor, but less WHP due to greater losses, contingent upon how much is done.
Anyway, hope this helps.
Old May 16, 2022 | 02:44 AM
SJGetsome's Avatar
W205 C63 AMG Coupe
What's with the oscillation on the top end of the dyno chart, above 5k RPM?
Old May 16, 2022 | 07:17 AM
ModalWorks's Avatar
SPONSOR
W205 C63
This is tuning related and will be addressed once we are back on the dyno. Our plan was to have it dialed in before sharing results, but as mentioned above the transmission isn’t holding properly. Once the new trans is in we will have better numbers to share.
Old May 16, 2022 | 05:23 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
I look forward to seeing the finalized results.
Are you all installing a new transmission or installing stronger components?
Old May 19, 2022 | 08:37 PM
ModalWorks's Avatar
SPONSOR
W205 C63
Rebuilding original trans with stronger components.
Old May 26, 2022 | 04:02 PM
Spazdoc's Avatar
C63S, 2004 S4, 2001 S4 Avant
Is the data obtained above using your Stage 2 intercooler/radiator, or would you recommend different intercooler/radiator for these turbos?
Old May 26, 2022 | 05:29 PM
ModalWorks's Avatar
SPONSOR
W205 C63
All data taken was using our 3 piece radiator set. We think these are the best radiator solution with the most data to support the IAT improvements, especially when running more boost.
Old Oct 13, 2022 | 02:00 PM
ModalWorks's Avatar
SPONSOR
W205 C63
2 sets left in stock at a discounted price! We can also provide custom powder coating in your choice of color:
We recently did some logs with an aggressive tune and were easily holding 35psi with moderate wastegate duty cycle, so these turbos can move some serious air. Remember, these have upgraded compressor and turbine wheels unlike some products that only touch the compressor wheel.
https://modalwork.com/collections/tu...2-turbocharger
