Do my stock turbos look normal after 41k miles?
The housing does not seem scored from excessive shaft end play, or a worn journal bearing. You can always measure shaft endplay and other typical field checks with a dial indicator if you like. Here is a pic of a non-stock turbo, newly built and not installed yet, for our cars.. (C63s). The notches may be for a special proprietary tool to be able to remove the shaft end bolt for disassembling the turbo for rebuilding, or a stake to prevent the bolt from loosening at 40k rpm when those vanes are spitting out 17psi or more of boost, etc.. Really bad things happen when a turbo shaft lets loose or those vanes touch the housing at a very very high rpm, far above the engine RPM.
Kinda, Zac Motorsports said I needed their $800 catch can for the black oil/carbon buildup going into the turbos. I give the turbos a wipe down every time I take off the intakes.
That being said, my C63s has low miles, stock turbos, and the inside of the housing areas look spotless. Perhaps higher mileage cars or ones with turbos weeping a bit of oil past the seals might benefit, but our cars seem like a pretty clean setup.
pics of coyote engine, 800+whp. Catch cans on both right and left sides of the engine one recirculated back into the intake. NA required only one on the passenger side.
Knew there was something off about them from the start with their unknown ZAC company insignia plastered all over their products..... 🤮🤮🤮
Bin/sell the intake and get something else if possible. If not just whack on the stock intake for now until u find a better intake bro.......
I'm going to put the stock intakes back on to see if it works better with my ecu tune and blowoff valves.
