C63/C63S AMG
60-130 times
Old Jun 22, 2022 | 03:21 PM
miamiboy's Avatar
C63s Sedan
Originally Posted by cls5504matic
hptuners is pretty easy to use to log. Some tuners you can just use openport 2.0
can it measure knock and ignition timing for Mercedes?
Old Jun 24, 2022 | 09:08 AM
ModalWorks's Avatar
SPONSOR
W205 C63
Yes it can, their beta version can actually log a ton of stuff
Old Jun 25, 2022 | 05:55 PM
noremaC's Avatar
17 C63S Coupe PTG1000
Does anyone get wheel spin without the TC light kicking on (sport traction and TC off)?
I put 100oct in at the track yesterday and on the way home it was spinning at ~80 in 3rd at WoT (TC light coming on). It will do it with pump gas but won’t trigger a light in sport traction at ~70 in 3rd - the tach will jump forward about 1k rpm then come back but no light).
I’m trying to figure if I’m spinning on 93 and that’s the cause of my slower 60-130.
Old Jun 26, 2022 | 08:14 AM
AMGMD's Avatar
2012 C63 Coupe P31 OE Tuned/ROW Airbox/K&N filters/Quaife LSD/MBH LTH, Race Cats, Midpipes, Xpipes
@noremaC Trying lowering the tire pressure and make a 60-130 Dragy pass after the tires are warm. The lower pressure will help with traction and you should see an improvement in your times if you are spinning. I had to do this when I was logging and tuning last during last winter to avoid wheel spin to get clean logs. If you lower tire pressure and get better times on 93 octane then maybe you were spinning and TC was kicking in. If you keep the same tire pressure and get better times on 100 octane then you may have been knock retard and timing pulled while on 93. Ultimately if you are able to datalog you will be able to see exactly what is going on. If you cant log with Verstand, I highly recommended HPTuners. If you cant get HP tuners you can also use the Torque app and an obd2 bluetooth dongle (Not that accurate bc of low data capture) but better than nothing and will give you an idea of what is going on.
Jeff
Old Jun 26, 2022 | 05:10 PM
noremaC's Avatar
Jeff
yup, all good points. Tire pressure is something I need to play with. Tires hover around 48psi, so probably need to lower the rears.
Even with 5gal of 100oct, the car buries the tach a lot quicker in 2-4 gears, so I feel like its something to do with my tune. Data logging will be the next step.
Old Jun 26, 2022 | 05:19 PM
miamiboy's Avatar
C63s Sedan
Do you know which product specifically logs timing and knock?
Is it the main product "MPVI2+" ?
https://www.hptuners.com/mpvi2plus/
Thanks in advance.
Old Jun 26, 2022 | 09:20 PM
  #32
cls5504matic's Avatar
C63 Vert
Thanks in advance.
yessir that will log it. And you don't need any further credits. Here is a video I made to show you the channels to log. I guess I have to show how to add the channels??? But it should get you started:
