C63/C63S AMG
How often do you change brake pads on this car?
Old Jun 21, 2022 | 07:13 PM
AMG82's Avatar
2020 C63s Coupe
I took my 2020 C63s to dealer for 2nd year service B last week and they told me that I have to replace both front and rear pads as they only have 2mm left before triggering the sensor.
My car is daily driver with no tracking and it only has 14,000 miles on it.
I am kind of surprised that the pads went through so quickly. I think my previous BMW M3's performance pads lasted longer than this.
Anyway, I declined the service and made appointment with indie to get both front and rear replaced with original MB C63s pads for $600 cheaper than quoted.
Old Jun 21, 2022 | 07:34 PM
superswiss's Avatar
2019 C63CS
Got ~18k miles from the first set. You can wait until the brake sensor triggers.
Old Jun 21, 2022 | 07:44 PM
AMG82's Avatar
2020 C63s Coupe
Thank you. I guess I will be fine for another 1-2k miles on it. I made appointment for mid July anyway so I think I will be close to triggering sensor by that time.
Old Jun 21, 2022 | 08:06 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
I got 25k on the rear and 35k and counting on the front. The light haven’t come on yet on the front.
Old Jun 21, 2022 | 08:42 PM
AMG82's Avatar
2020 C63s Coupe
Oh wow. Are you driving mostly on freeway?
Most of my driving are local with a lot of stop and go which may explain why my pads are worn out quick. Still cannot believe I have to replace pad just after 14k miles.
Old Jun 21, 2022 | 09:01 PM
Klinh's Avatar
Yes. My M4 with 28k miles front and rear pads still original.
Old Jun 21, 2022 | 09:57 PM
dctwc63s's Avatar
2019 C63S Sedan
About 30k km on my rears and still on first set of fronts with 40k km
Old Jun 21, 2022 | 10:26 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
Couldn't tell you because as soon as I was able to install new pads I did just that. Now, 16k later, I'm still running EBC Red Stuff (ceramic) at all four corners. Love 'em. Stops good cold, no noise and minimal dust.
Old Jun 21, 2022 | 11:02 PM
jj18's Avatar
2019 C63S Coupe
Front brakes 16,500 miles and rear brakes 18,000 miles. Both times the Check Brake Light came on.
Also had the front and rear rotors replace at the same time the brakes were replaced.. Front rotor measured min thk 33mm and actual 34.1mm and 34.3mm. Everything done at the Dealership.
Did the Dealership advise the measurements of the rotors?
Old Jun 21, 2022 | 11:58 PM
Jimmy_c63s's Avatar
I haven't changed my brake pads or rotors in over 2 years and my wife and I make it a habit to drive this thing every single day. I drive it like a goon.
I'm on the stock S red brakes using OEM Mercedes pads too so you shouldn't be changing any pads for at least 3 years.
Also, others mentioned that keeping ESP on Sport or Off helps with rear brake pad consumption but I don't see that effect because i've kept the ESP to always On or sometimes in Sport this year as we've had non stop rain here for the past 6 months etc. and pads are good.
Mine is just a prefacelift btw...
Old Jun 22, 2022 | 01:45 AM
Klinh's Avatar
Why don’t you list the mileages on your car? My wife and I drive every day too 😁 She drive to work 10 mi one way = 6720 mi per year and I drive to work 65 mi one way = 21,840 mi. You guess the point, right? You’re gonna shoot me for this.
Old Jun 22, 2022 | 02:34 AM
AMG82's Avatar
2020 C63s Coupe
I believe they checked rotor during service. They did not suggest replacing it, yet.
I always drove my car in esp sport mode… but I guess that did not help conserve my brake pad much.
Old Jun 22, 2022 | 06:07 AM
Jimmy_c63s's Avatar
Because I didn't think anyone would give a sh*t about what I wrote let alone read my post seeing as this place is half dead now. But I'm on 56,000 miles and it's driven 20-25 miles per day and if I drive it I'll make sure to give it a few good hits here and there.
Good to hear you drive yours each day too, I thought your car was a garage queen.
Old Jun 22, 2022 | 06:32 AM
hyperion667's Avatar
2012 CLS63
My car is a 2012, bought new.......has 70K miles, still have the same front and rear pads from delivery
Old Jun 22, 2022 | 08:13 AM
superswiss's Avatar
2019 C63CS
There isn't any magic to brake longevity. Brake wear is proportional to how much they are used and some driving is harder on the brakes than others. Daily stop&go driving gradually grinds down the pads, because they operate in what's called abrasive mode when they are cold, whereas once they have some heat in them they rely more on the layer of pad material on the rotor for stopping power. Daily driving actually scrapes off that layer or doesn't build it up in the first place resulting in more wear and noise. Occasionally giving it the beans on the open road also doesn't mean you are using the brakes, unless you end up doing some hard high speed braking. On the open road one can do more engine braking for example. ESP Sport or Off is also largely a myth, especially on the FL S models. The 9-stage TC relies mainly on precise engine torque management and the faster reaction of the improved e-diff to control traction before too much wheel spin occurs in the first place that would require the brakes to slow down the spinning wheel. On the other hand the new AMG DYNAMICS system in the FL uses the rear brakes to help the e-diff torque vector around corners. So a lot of hard cornering wears the rear brakes more than driving mainly in a straight line. My brake wear mainly came from hard high speed braking on the German Autobahn during my ED trip, and some laps around the Nürburgring, followed by regular canyon carving back in the States. Not much stop&go driving for me. I'll see with the second set how much of a difference the lower speed highway driving resulting in less hard braking in the USA will make. I'm expecting a bit more mileage out of the current set. On the other hand I have DISTRONIC, which uses the rear brakes more to gradually slow down.
Old Jun 22, 2022 | 08:17 AM
untamedd's Avatar
2019 AMG GT R
sounds about right. i daily drive my car in rain, snow whatever and with 76000 km currently, im on my 3rd set of brake pads and 2nd set of rotors with 90% of my driving being in the city
